Bios Asus K556U
  • dylen
    • May 2017
    • 173
    • Mauritius
    Bios Asus K556U
    Hi. need bios bin file for Asus K556U pls. My dump submited.
  • peste
    • Dec 2016
    • 13661
    • ROMANIA
    Re: Bios Asus K556U
    try..
    • dylen
      • May 2017
      • 173
      • Mauritius
      Re: Bios Asus K556U
      Thanks sir, laptop now working.
      • peste
        • Dec 2016
        • 13661
        • ROMANIA
        Re: Bios Asus K556U
        Originally posted by dylen
        thanks sir, laptop now working.
        try..
        • lollo1988
          • Jan 2021
          • 1
          • italy
          Re: Bios Asus K556U
          Originally posted by peste
          try..
          sorry i flash thi bios the pc start but tell me password?
          what is the password?
            • 21984
            Re: Bios Asus K556U
            Maybe you`ve got a hard drive password,there`s no password in the bios .
            • mkdj
              ASUS ZenBook UX480F : need help with cleaning the ME region of my BIOS dump
              by mkdj
              Dear all,
              I have a ASUS ZenBook UX480F with the following symptoms:
              I suspect it is a BIOS issue. So I decided to try to clean the ME region. I followed the guide on win-raid, and I believe I have done everything correctly. My problem is: when I open the outimage.bin in ME Analyzer, it says that it is Extracted, and not Region, Extracted as it should be. Is it normal, or did I do something not correctly? This is my first experience editing BIOS files.
              I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...
              10-19-2025, 04:41 AM
            • razor_amd
              [TUTORIAL] fix asus bios with bios from asus web support (by razor_amd)
              by razor_amd
              With ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
              For example, you can have 3 similar ASUS motherboards, all being the same model, all of which will have different BIOS versions.
              I will give you an example and my version of preparing BIOS from ASUS website and in the process I am always cleaning Intel ME while doing it so you have fully cleaned BIOS, no DMI data, no password, nothing.
              This is the picture of 3 similar ASUS motherboards, all of them being X555LD...
              12-15-2020, 07:07 PM
            • pirati
              by pirati
              10-27-2025, 04:20 PM
            • DynaxSC
              Need real mobo dump of BIOS v402 for ASUS PRIME Z590-A - stock image no help
              by DynaxSC
              I have a serious problem to program the Z590 chipset SRAM with a Management Engine after replacing the chipset.
              The new chipset is factory new and is not containing any Management Engine. Any attempts to program it into the chipset under Windows ends with a failure (eg. Error 20: Management Engine Device not present, or something similar).
              Due to the lack of the ME several ports on the board, including all M.2 ports aren't working, booting OS works only on USB. So it's now other way, as to program the chipset with a ME.
              Usually on ASUS boards it worked...
              06-14-2024, 03:49 PM
            • Ahari
              by Ahari
              I...
              08-13-2025, 06:12 AM
