The rar file is the original BIN file, kindly someone Clean me .. Thanks in advance
HP 15 DAY11AMB6E0 rev:E BIOS
Re: HP 15 DAY11AMB6E0 rev:E BIOS
Try and give feedbackAttached Files -
Hi lapfix, I almost forgot to repair this notebook. Yesterday only I saw this in my To-do list. Anyway I re-programmed the BIOS... Still no display. Upon testing further more, I measured all the required voltages & they all seem to be fine. VCore is fine too but why am I not getting any display. The CPU/GPU are getting normal hot.. Do you think the GPU chip is defective?? I replaced the LCD too with a known good one, still the same. Cannot understand, any more tips will be greatly appreciated. Thank you very much.Comment
Post your issue here : https://www.badcaps.net/forum/forumdisplay.php?f=23
we gonna try to give helpComment
Try this bios ,extracted from hp update, + DMI.Attached FilesLast edited by SMDFlea; 05-17-2020, 05:05 AM.Comment
100% working bios upload for uAttached FilesComment
DAY11AMB6E0 REV E hp 15-p045ne sn:5cd4212c75 problem late display anyone can help to fix this biosAttached FilesComment
TryAttached Files↵
https://www.badcaps.net/donateComment
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
I have opened the laptop and identified the main BIOS chip...2 Photos-
Channel: BIOS Requests ONLY!
by CityminHi all,
My Samsung Galaxy Book 2 Pro 15.6-inch laptop has no display and won't boot.
The charging red LED lights up, but the charging screen doesn't show any indication.
When I press the power button, the blue LED cycles on and off three times, then the screen doesn't turn on, and the device won't boot.
(I've tried removing the battery and resetting the device, but the issue persists.)
NoteBook Model name : Samsung NT955XED-KK51G(Galaxy book2 pro, i5-1240p, 15.6inch AMOLED)
PCB model name : Venus2-15-5G(REV1.2), Venus2-15 ADL NPC
S/N : 5RNK9FFT70...-
by m1ch43lzmHi everyone
I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
Programmer models: XGecu TL866II Plus / T48 / T56 / T76
Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
There's also an extra OTP Secu.R...-
by Forest79Hello,
I got a Lenovo ThinkStation P520 (Type 30BF) from a friend, asking me for a repair. Windows 11 offered a firmware upgrade as an optional update, and it failed.
The emergency flash procedure from the hardware manual has also failed. So, I asked an acquaintance with better skills to flash the BIOS directly.
However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
Channel: BIOS & Schematic Requests!
by maanee11Hello Everyone,
I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...-
- Loading...
- No more items.
