tp.ms1306.pb771 firmware
  • mazloum
    • Sep 2012
    • 499
    • Lebanon
    tp.ms1306.pb771 firmware please
    the tv is tcl LED32D2700S
    it works for 1 or 2 minutes then off even the led disappear
  • movsearch
    • Sep 2018
    • 3
    • Philippines
    Re: tp.ms1306.pb771 firmware
    i've encounter the same issue, the problem is not the firmware itself but the backlights. what I did, I change backlights strip and works fine.
    but if still need the firmware, click the link below
    http://prereheus.com/4TxW for TCL LED32D2700S
    http://whareotiv.com/2Dgn for TCL LED29D2700
    hope it helps
    • electronic500
      • May 2018
      • 3
      • eg
      https://www.4shared.com/postDownload...P-MS1306-.html
      • jesterace
        Samsung UE49MU6400 acts dead until disconnecting backlights, then works.
        by jesterace
        Hi everyone I have this TV which was dead one day when I tried to turn it on. I've had the cover off and there was just a pulsating/electrical clicking/ticking noise from the PSU. I disconnected the mainboard as sometimes this works to just fire it up with backlights on? That didn't help. Same noise. Then I disconnected the backlight cable from the PSU and the TV came alive. It appeared to respond to the remote and i'm pretty sure it's fully operational when there is no backlight connected.
        However, I am in a dilemma.
        I tested the backlight outputs with the lights disconnected...
        10-20-2024, 10:15 AM
      • TheUser
        Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
        by TheUser
        Hello to everyone ,
        This is my first post here, and i would like to share with you a small story in case you can help me.
        Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
        All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
        I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
        02-10-2024, 02:07 PM
      • zklgfs
        Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
        by zklgfs
        I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
        Yesterday, 02:14 PM
      • gurj1979
        Ubiquiti firmware help. US-8-150W POE
        by gurj1979
        Hi guys.
        I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
        Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
        So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
        Got New chip and writes good.
        THE PROBLEM...
        It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
        Does anyone have a Good Firmware I can have?...
        07-22-2024, 05:13 PM
      • sikocan
        NP930XED Samsung Galaxy Book2 Pro Laptop PD Firmware Loop
        by sikocan
        I hope this message finds you well. I wanted to share a recent experience I had with a laptop that had a Type-C Port issue, specifically related to a PD (Power Delivery) controller problem. After replacing the damaged PD controller chip with a new one I purchased from AliExpress, the laptop now charges properly and negotiates power as expected, allowing the device to power up. I've replaced this chip twice just in case.
        However, it seems that the laptop's BIOS is detecting an older version of the PD Firmware on the newly installed chip. As a result, it attempts...
        01-11-2024, 01:47 AM
