ThinkPad Thunderbolt 3 Firmware
    • 21692
    ThinkPad Thunderbolt 3 failure: What's happening, why it's happening, and how to fix it
    https://www.notebookcheck.net/ThinkP....451207.0.html
    https://nadim.computer/posts/2018-10-26-thinkpad.html
    https://pcsupport.lenovo.com/ca/en/solutions/ht508988
    ThinkPad Thunderbolt 3 Firmware attached,extracted from lenovo updates,plus links to driver downloads.Some models have 2 different firmwares, TBT.bin and AssistTBT.bin for the models that support or have bios assist enabled. NOTE: All the FW will need padding out with zeros using a hex editor to the size of the chip.
    EDIT: There is a Thunderbolt tool project on Github, try it and give feedback to the author please Whale linguini --> https://github.com/whalelinguni/LenovoThunderboltTool
    Systems may experience any of the following symptoms:
    USB-C port not working
    Intel Thunderbolt controller not visible in the OS/Device Manager
    USB-C or Thunderbolt docking stations not visible or having connectivity problems
    HDMI output not available
    System battery not charging with a USB-C power adapter connected to the USB-C port
    Intel Thunderbolt pop-up error message
    Intel Thunderbolt safe mode error message
    BIOS Thunderbolt communication error or hang during POST
    These symptoms may occur after 6 to 12 months of typical usage.
    These models are affected
    P43s (Type 20RH, 20RJ)
    P51 (Type 20MM, 20MN) P51 (Type 20HH, 20HJ)
    P51s (Type 20HB, 20HC) P51s (Type 20JY, 20K0)
    P52 (Type 20M9, 20MA) P52s (Type 20LB, 20LC)
    P53s (Type 20N6, 20N7)
    P71 (type 20HK, 20HL)
    T470 (Type 20HD, 20HE) T470 (Type 20JM, 20JN)
    T470s (type 20HF, 20HG) T470s (type 20JS, 20JT)
    T480 (Type 20L5, 20L6)
    T480s (type 20L7, 20L8)
    T490 (Type 20N2, 20N3) T490 (Type 20RY, 20RX)
    T490 (Type 20Q9, 20QH) T490s (Type 20NX, 20NY)
    T570 (Type 20H9,20HA) T570 (Type 20JW, 20JX)
    T580 (Type 20L9, 20LA)
    T590 (Type 20N4, 20N5)
    X1 Carbon 5th Gen - (Type 20HR, 20HQ)
    X1 Carbon 6th Gen - (Type 20KH, 20KG)
    X1 Carbon 7th Gen - (Type 20QD, 20QE) X1 Carbon 7th Gen - (Type 20R1, 20R2)
    X1 Yoga 2nd Gen (Type 20JD, 20JE, 20JF, 20JG)
    X1 Yoga 3rd Gen (Type 20LD, 20LE, 20LF, 20LG)
    X1 Yoga 4th Gen (Type 20QF, 20QG) X1 Yoga 4th Gen (Type 20SA, 20SB)
    X1 Tablet 3rd Gen (Type 20KJ, 20KK)
    X280 (Type 20KF, 20KE)
    X380 Yoga (Type 20NN, 20QN)
    X390 (Type 20Q0, 20Q1)
    X390 Yoga (Type 20LH, 20LJ)
    Yoga 370 (Type 20JJ, 20JH)
  • brontobyte
    • Jul 2021
    • 85
    • Romania
    Re: ThinkPad Thunderbolt 3 Firmware
    Hello. I have a Lenovo T480s Type 20L8. I run in some troubles with it. In slow charges and the thunderbolt is not working. When the charger is conected it does not work on 20V. When i open the laptop and the charger is plugged in the laptop complains about the charger. The battery slowly charges when the laptop is off. I can`t manage to put your firmware on my bios. Can you please help? Do you think is a hardware or a software issue?
    Thank you in advance!
      • 21692
      The thunderbolt firmware is flashed to a different chip,not to the bios chip. You should test with another charger first. If you want more help with it start a new thread in the main laptop forum - https://www.badcaps.net/forum/forumdisplay.php?f=23
      • brontobyte
        • Jul 2021
        • 85
        • Romania
        Thanks! I will open a new thread.
        • brontobyte
          • Jul 2021
          • 85
          • Romania
          Hello friend, i need your help.
          I have a faulty lenovo thinkpad T480, usb type C not Working.
          i need 1 MB File to write on the firmware chip
          i attached the original file
          Please, can you help me? THANKS!
          • hoaca388
            Badcaps
            • Jan 2022
            • 12278
            ​https://www.badcaps.net/donate
            • brontobyte
              • Jul 2021
              • 85
              • Romania
              not working, i think is not the right file...
              • Dimuth Rubesinghe
                • Aug 2022
                • 7
                Hi i messed up my 25Q80 thunderbolt eeprom by thinking its the bios chip.
                I did make a back up of the original ( attached)
                but even when I flashed it back I still get the power adaptor not enough warning, so I think it didnt fix the issue.
                thinkpad x390 8th gen
                appreciate any assistance to get it back
                thanks
                  • 21692
                  thanks
                  https://www.badcaps.net/forum/showpo...70&postcount=3
                  • linxz
                    • Dec 2016
                    • 24
                    Hi Master,
                    Please help me,I have Lenovo thinkpad T480s. use full charged battery can wotking but power LED NOT On.when connect to power adapter
                    As PF2 has only 5V.No charging.They should bring it up to 20V. I try the docking port, PF1 5V. Check port no problem.I guess may be is U12 problem. firmwares problem.Pleaes tell how to flashe both TBT.bin and AssistTBT.bin to chip?thanks.
                    • brontobyte
                      • Jul 2021
                      • 85
                      • Romania
                      I have some issues with this model.
                      Lenovo Thinkpad x13 Gen1 Type 20ug sn:PC-28QECQW
                      The type c connector is not getting 20v, only 5v
                      The second one is working fine.
                      It's a firmware issue? Can someone help with the bin file?
                      • digitalpc
                        • Jun 2016
                        • 305
                        • .DLL
                        Anyone have file for Lenovo T15p
                          • 21692
                          Are you asking for T15p thunderbolt firmware ? .You havn`t provided enough info,can`t help without the laptop serial or model type.
                          • digitalpc
                            • Jun 2016
                            • 305
                            • .DLL
                            Yes i upload bin file, it charging with USB Pin and USB C just when is shut down
                            T15p Gen 1 (type 20TN 20TM)
                              • 21692
                              FW from the support page https://pcsupport.lenovo.com/us/en/p...%20Thunderbolt
                              Extracted with innoextract. 424KB FW padded out to 1MB using HxD.
                              If it doesn`t work try flashing the 1MB zero`s file at post #1 and -> https://www.badcaps.net/forum/showpo...70&postcount=3
                              • digitalpc
                                • Jun 2016
                                • 305
                                • .DLL
                                Same problem with both
                                  • 21692
                                  Maybe a problem with the charger,hardware or EC.Don`t know.
                                  • gsoft
                                    • Jul 2023
                                    • 38
                                    • Italy
                                    Hi, I have a T480 not charging batteries, I try another charger but the problem is not charger but I think is the thunderbolt. I follow some tutorial to flash the correct firmware by a ch431a. First I erase the chip, than flash with a null.bin and finally flash with the TBT.bin padded, but the laptop continue to not charge the batteries. The problem is the two batteries are empty and I can't boot the laptop. My question is: is necessary, after flashing, to boot the laptop to complete the process? So can be this the reason why the thunderbolt not charge batteries also with the new unbugged firmware?
                                    • zomi
                                      • Nov 2011
                                      • 510
                                      Just some help please, I have forgotten how to pad firmware files. Please could someone explain how to do this, spent last evening trying to figure it out, but I can't get my head around it,,
                                      thanks
                                      • Zalman
                                        • May 2020
                                        • 32
                                        • UA
                                        thanks
                                        I use HEX Editor Neo on Windows. Edit - Change file size - 1024kb - save. It will change the size and fill the rest with zeros.
                                        • Maxpower3
                                          Brand name and Model Type for Lenovo error 2202 product name is invalid
                                          by Maxpower3
                                          Info for error 2202 LenovoThinkPad models and type
                                          Extract from ThinkPad Maintenance Utilities Configuration File
                                          plnsrv.ini Version 1.01
                                          Some information that may be useful
                                          There must also be missing models, add them to the list if you know of any.
                                          Code:
                                          brand name
                                          20B1=ThinkPad Edge E445
                                          20B2=ThinkPad Edge E545
                                          20BC=ThinkPad Edge E145
                                          20BM=ThinkPad X140e
                                          20BL=ThinkPad X140e
                                          20A3=ThinkPad X230s
                                          20AH=ThinkPad X230s
                                          20AK=ThinkPad X240s
                                          20AJ=ThinkPad X240s
                                          02-21-2024, 10:27 AM
                                        • TheUser
                                          Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                                          by TheUser
                                          Hello to everyone ,
                                          This is my first post here, and i would like to share with you a small story in case you can help me.
                                          Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                                          All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                                          I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                                          02-10-2024, 02:07 PM
                                        • TamFishe
                                          Lenovo ThinkPad X1C6 thunderbolt firmware request
                                          by TamFishe
                                          Hi there, I have a ThinkPad X1C6 which I got cheap from a friend as I've mentioned before if you decide on checking my profile, but it has issues, including both the bios and thunderbolt firmware bricked. So far, I got a 20KG bios from indiafix, however, I still haven't figured out how to fix the thunderbolt firmware issue ( I feel like mentioning that I've never worked with FL1 and FL2 files or with any Lenovo product and I'd wish to not brick something beyond repair. ). Can someone with this same model of laptop give me a thunderbolt dump of the chip (Winbond W25Q80 ONLY) and compare my dump...
                                          08-24-2025, 03:08 AM
                                        • derar shuli
                                          X1 Yoga 4th Gen (Type 20QF, 20QG) Laptop (ThinkPad)
                                          by derar shuli
                                          X1 Yoga 4th Gen (Type 20QF, 20QG) Laptop (ThinkPad) no sound driver ...
                                          08-05-2025, 05:54 AM
                                          Lenovo ThinkPad ThinkPad X1 Titanium Yoga Gen 1 Notebook Yoga Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad ThinkPad X1 Titanium Yoga Gen 1 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkPad X1 Titanium Yoga Gen 1 boardview and ThinkPad X1 Titanium Yoga Gen 1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-07-2024, 04:10 AM
