N551JM - cold CPU , CPU vcore present
  • magneh
    • Apr 2014
    • 616
    • Portugal
    Hi!
    ive been trying to figure out this Asus N551JM mobo problem.
    The motherboard turns on by herself when I supply 19V with PS.
    Goes directly to 390 mA , and rises a bit to 410 mA 1 min after or so.
    All VCC signals are present, CPU vcore 1.7V etc
    NVidia GPU warms up, but what surprises me is that the CPU does not get hot at all. The 3 coils of CPU VCC are warm, but not CPU.
    Measured a bit and taking a look at the repair guide I came to the signal H_CPUPWRGD who is 1.07V
    I was expecting a signal around 3V, but not sure.
    This signal comes from the PCH.
    While measuring the board shut down itself (I assume) and consumption went down to 67mA(maybe due to Nvidia chip getting too hot without the cooler) . Found out the 3.3V/5V IC controller getting quite hot.
    Left a board for a minute, supplied power and back to the same 390mA (and 3.3V/5V IC working fine)
    this could indicate bad PCH?
    Or just a waste of time and leave it for donor board?
    Thanks for any advice
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: N551JM - cold CPU , CPU vcore present
    History of the machine?
    H_CPUPWRGD is ok. Check BUF_PLT_RST#. If present, try to flash the BIOS.
    • magneh
      • Apr 2014
      • 616
      • Portugal
      Salut Piernov!
      Merci!
      Ive checked and indeed BUF_PLT_RST is 0.00V. Diode mode 0.5V to gnd.
      Going to flash the bios and see if something changes.
      • magneh
        • Apr 2014
        • 616
        • Portugal
        Just flashed the bios with a working dump for N551JM with N16P-GX-A2 Nvidia chip. and still the same.
        BUF_PLT_RST# 0 V
        cpu still cold
          • 21899
          BUF_PLT_RST# 0 V
          cpu still cold
          There`s a few things wrong with that bios you tried,apart from the extra code as it was backed up as an OTP chip. The boot guard profile configuration is set to unknown ,it should be set to 0 - no FVME. The PCH strap 2 has MCTP as 0x2B it should be 0x00 . You need to try another bios with clean ME firmware.
          If you have your original bios backup post it in the Bios Requests section for the ME sorting .
          https://www.badcaps.net/forum/forumdisplay.php?f=40
          • magneh
            • Apr 2014
            • 616
            • Portugal
            Original dump uploaded in bios section
            Thank you for the feedback on this OTP file
            • platinumsteel
              Macbook Pro 2012 CPU Vcore Present No Post
              by platinumsteel
              Hi guys hoping you can help me solve this issue. I have 3x 820-3115 boards. One fully working with CPU Vcore 0.8v and posting which am using to compare against the other 2...The other 2 has CPU Vcore stuck at 1.12v and doesn't drop down to 0.8v.
              PPBUS_G3H is 8.56v and all other rails present. They both do not post or give picture and no caps lock. Hoping anyone may have experience with this and advise me on a few things to try. So far the only thing i tried was a few different bios for this board and nothing changed same behavior persists I have the original backups saved.Thx...
              01-08-2025, 04:18 PM
            • magneh
              N551JM - cold CPU , CPU vcore present-Clean ME
              by magneh
              Ive been troubleshooting a N551JM mobo that turns on fully but cpu doesnt heat up at all, only the coils get warm
              Can someone clear ME region of my original dump so I can test to see if BUF_PLT_RST comes up and cpu starts to work.
              Post:https://www.badcaps.net/forum/showthread.php?t=82198
              Thank you...
              01-25-2020, 11:47 AM
            • barry101
              Apple 820-3662 VCore shorted to ground.
              by barry101
              Hi, Would appreciate some help.
              I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
              Get charger light but no fan spin or chime. No liquid damage.
              Found PPBUS and VCORE both shorted to ground. Other rails were ok.
              Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
              With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
              Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
              06-24-2025, 07:34 AM
            • rex98
              JS47A/JS57A/JS77A NM-E531 onboard ram disable
              by rex98
              hi i have this laptop IdeaPad 3 15ABA7 this is the boardview https://www.badcaps.net/forum/troubl...90#post3740490
              nm-e531 i tried all kinds of bios editing and it doesn't work. it doesn't have schematic but it has boardview with board ID details in it.
              maybe you could help me how to shift these resistors to disable its onboard ram.
              this is is the presents and not presents...
              10-07-2025, 03:39 AM
            • lapfix
              Lenovo Air 15ITL NM-D211 missing RSMRST !
              by lapfix
              Lenovo Air 15ITL.
              NM-D211
              This laptop won't power on , when power supply is on it takes 0.001 , button trigger on it becomes after a couple of seconds 0.061 amp..and nothing
              No heating (Of COURSE) , no short to GNd at all coils present , 3/5 valw is present , 3/5 vl present.
              With the power plane , at state 4 +1.8VALW and +3ALW_PCH must be present but no one due to enable signal is missing .
              when button trigger on , 3v dow to zero than 3v , the super io send BTN_OUT#_R to pch but no rsmrst ..0v.
              i follow his line , no short .
              10-21-2025, 05:53 AM
