HP Elitebook X360 1030 G3 BIOS and EC unlock request
  • Kazik
    • Oct 2016
    • 53
    Can you remove the bios password on this HP X360 1030 G3, please? This bios looks different than on some older Elitebooks, so I can't do the unlock on my own. There are two dumps attached. 256Mb BIOS dump and 128Mb EC dump. I noticed the EC file contains some password hash information so I suppose it might need unlocking as well.
    Thank you.
  • RethoricalCheese
    • Mar 2013
    • 1519
    • Estonia
    Re: HP Elitebook X360 1030 G3 BIOS and EC unlock request
    Same as previous (newer) models.
    Thanks for the upload. My tool was unable to unlock this so I did it manually. Now I know what needs fixing in my tool.
    • Kazik
      • Oct 2016
      • 53
      Thank you for unlocking the bios. It works fine now.
      • jainath
        • May 2020
        • 2
        Thank you very much for this. I am new and was wondering if there is any instructions on how to use this tool. I appreciate your help.
        • jainath
          • May 2020
          • 2
          Will this work on any Elitebook 1030 G3?
          • AG Electronics
            • Dec 2016
            • 13
            • United Kingdom
            Thank you.
            Can you tell me which programmer you used to dump main BIOS chip?
            • peste
              • Dec 2016
              • 13619
              • ROMANIA
              tri this..
              https://www.youtube.com/watch?v=DWWigscuQDY
                • 21932
                If the bios chip is WSON8, flat with no legs then you`ll need an adapter as well, or alternatively you can solder wires to the gold pads.If the chip is SOP8 (with legs) you can use a SOP8 clip - https://www.badcaps.net/forum/showpo...63&postcount=4
                The supplied CH341A software is poor, it might not have support for the chip.Alternative software is available, NeoProgrammer ,AsProgrammer,Colibri and flashrom.
                https://www.badcaps.net/forum/showpo...04&postcount=7
                https://www.aliexpress.com/item/33025602016.html
                • AG Electronics
                  • Dec 2016
                  • 13
                  • United Kingdom
                  Hello Guys,
                  Thanks for your answers.
                  Peste the programmer you suggested does not support this chip.
                  It's WSON8 8x6 as SMDFlea says. To be specific it's MX25L25673GZ4I-08G.
                  From all of the programmers I have got, only two support that chip.
                  First is TL866II but it only supports one in SOIC8/16 casing and when I connect it trough the adapter it will always show that 5th pin has got bad connection( and it's properly soldered). The second one I have is DATAMAN 48Pro2 https://www.dataman.com/programmers/...rogrammer.html
                  but I need to buy an adapter https://www.dataman.com/dil8-qfn8-5-...sflash-1a.html
                  Before I buy it I was hoping for less costly solution ;-)
                    • 21932
                    See this thread,send him a PM ask how he solved it - https://www.badcaps.net/forum/showthread.php?p=933129
                    • Kirua08
                      • Feb 2021
                      • 1
                      • France
                      I'm sorry but i need your help please.
                      I have an HP Elitebook X360 1030 G3 with BIOS password (I bought it like this).
                      I have a Raspberry Pi 4 and i don't know what to buy for dump BIOS (chip clip), knowing that i don't have the material for desolder.
                      I believe that i have a WSON8 chip (see attached picture).
                      As you can see, there are two Chips, which one should be flashed ?
                      Many Thanks for your help.
                      • maxitaxi
                        • Jul 2021
                        • 11
                        • nedtherlands
                        Hi Rethorical, what is the newest version of your tool and where can i get it ??
                        Thank you in advance !
                        • qsenc
                          • Dec 2010
                          • 45
                          1030 g3 bios unlock if possible please
                          thank you in advance
                            • 21932
                            https://www.badcaps.net/forum/showthread.php?t=98539
                            • Montanatony
                              • May 2022
                              • 3
                              • france
                              Hi Friends ,
                              i have a 1030 g3 administrator bios pass locked , if i send the dump to you it's ok for unlock it ? thanks
                              • peste
                                • Dec 2016
                                • 13619
                                • ROMANIA
                                Originally posted by Montanatony
                                Hi Friends ,
                                read this..
                                at post # 14 you have everything you need to unlock the bios yourself .. use that program ... don't forget to make a copy of the original bios before writing the bios chip ..
                                • Montanatony
                                  • May 2022
                                  • 3
                                  • france
                                  ok thanks
                                  • livestrong
                                    • Jan 2023
                                    • 3
                                    Hi, I have a HP EliteBook 1030 x360 G3 with BIOS password. As far as I know, the Elitebook has a BIOS and a EC chip on board.
                                    Can anybody confirm, if I have to unsolder and flash both chips or just one of the 2 chips?
                                    At the forum is talked about 2 chips, this guy unsolder only 1 chip:
                                    https://www.youtube.com/watch?v=sI7P39iHQlU
                                    Would be nice, if anybody could share his experience?
                                    Thanks!
                                    • peste
                                      • Dec 2016
                                      • 13619
                                      • ROMANIA
                                      Thanks!
                                      I post both bios here and someone will help you,,
                                      • livestrong
                                        • Jan 2023
                                        • 3
                                        After some research I guess I have to flash the 256Mb BIOS chip, should be the MX25L25673G. So I am new in this field, I have to buy some hardware to flash.
                                        I guess the cheapest way to start is to buy the CH341A set:
                                        https://www.amazon.de/KeeYees-SOIC8-...language=en_GB
                                        But unforutnately the MX25L25673G is not in the supported chips list. So does it mean that I can't read/flash the chip with CH341A or does it just mean, that I need another software to read/flash?
                                          HP EliteBook x360 EliteBook x360 1030 G2 Hybrid (2-in-1) Specification for Upgrade or Repair
                                          This specification for the HP EliteBook x360 EliteBook x360 1030 G2 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook x360 1030 G2 boardview and EliteBook x360 1030 G2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 08:27 AM
                                          HP EliteBook x360 EliteBook x360 1030 G2 (ENERGY STAR) Hybrid (2-in-1) Specification for Upgrade or Repair
                                          This specification for the HP EliteBook x360 EliteBook x360 1030 G2 (ENERGY STAR) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook x360 1030 G2 (ENERGY STAR) boardview and EliteBook x360 1030 G2 (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-06-2024, 06:40 AM
                                          09-06-2024, 05:33 AM
                                          HP EliteBook x360 EquipoEliteBook x360 1030 G4 Hybrid (2-in-1) Specification for Upgrade or Repair
                                          This specification for the HP EliteBook x360 EquipoEliteBook x360 1030 G4 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EquipoEliteBook x360 1030 G4 boardview and EquipoEliteBook x360 1030 G4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-06-2024, 11:32 AM
