Gigabyte GA-SINXP1394
  • AK0R
    • Mar 2005
    • 204
    I received this board from a co-worker to recap. The board had been in service for a couple of years, and one day, wouldn't POST. Calls to Tech Support ended up with him resetting the BIOS, which allowed it to boot for a few days, then the same thing again (no POST). Tech Support then "diagnosed" bad capacitors (over the phone, without seeing the board). This is an unusual board, with a Main and a Backup BIOS. Both are soldered directly onto the board, not socketed.
    I've inspected the board, and there is no visible sign of bad capacitors. The board has a daughterboard with several VRMs and caps on it. Most of the large caps on the motherboard, and all on the daughterboard, are on the "good" list: Sanyo WG, Chemi-con KZG, Panasonic FJ. However, there are:
    19 Nichicon HM(M) 1000uF, 6.3V (scattered all over the board)
    10 Teapo 100uF, 10V (scattered all over the board)
    2 G-Luxon 22uF, 16V
    I'm planning on doing a complete re-capping, but wonder what everyone else thinks. Replace just the potentially troublesome ones, or do them all?
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Gigabyte GA-SINXP1394
    i think you would get away with doing just the nichicon
    • bushytails
      Moderator
      • Dec 2004
      • 217
      and teapo and g-luxon if they have vents... I've seen the little 100uf ones pop just like all the others...
      --Randy
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • Hakuu
        by Hakuu
        Hi There,
        More Details
        TV Model - LG OLED77G1PUA
        07-12-2023, 02:37 PM
      • jb_Bak
        by jb_Bak
        CN6401
        Pin 01 NC
        Pin 02 NC
        Pin 03 "BL_ON": 0V
        Pin 04 "N/C"
        Pin 05 "STBY 3.3V": 3.5V
        Pin 06 "GND": N/C
        Pin 07 "AC_OFF"...
        09-27-2021, 04:52 PM
