HP 14-BS507TX bios needed
  • Romy2018
    • Sep 2018
    • 174
    • japan
    I need a working bios for this model HP 14-BS507TX board idA0P1BMB6D0 REV please
  • max7
    • Nov 2015
    • 69
    • sudan
    Re: HP 14-BS507TX bios needed
    Product number : 2LS24PA
    Product name : HP Notebook - 14-bs100tx
    Microprocessor : Intel® Core™ i5-8250U (1.6 GHz base frequency, up to 3.4 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
    DA0P1BMB6D0 REV
    • max7
      • Nov 2015
      • 69
      • sudan
      good luck
      • Romy2018
        • Sep 2018
        • 174
        • japan
        thanks but will this bios work? the laptop has core i3 7th gen and has RADEON graphics
        • Romy2018
          • Sep 2018
          • 174
          • japan
          I tried above bios not working here is my original bios file.can someone fix this dump please
            • 22159
            This is a new hp bios with your dmi included.If this bios doesn`t work the problem is somewhere else.
            228000 - 228030 W
            221000 - 223FFF D
            • Romy2018
              • Sep 2018
              • 174
              • japan
              now its turning on without the fan stops but there is no display CAPS LOCK blinking 5times then 3 fast blinks
              • on/off
                • Oct 2016
                • 333
                • Indonesia
                Just curios, when you ask/request bios dump, what exactly your laptop original problem?
                • Romy2018
                  • Sep 2018
                  • 174
                  • japan
                  the original problem plugged in charger fan starts then stops when i flashed with the bios of smdflea,now is turning on fan not stops but there is no display and caps lock blinking 5times then 3 fast blinks.
                  • on/off
                    • Oct 2016
                    • 333
                    • Indonesia
                    Before flashing did you check the motherboard, all voltages present on all grey big coils, even only momentary?
                    • Romy2018
                      • Sep 2018
                      • 174
                      • japan
                      i have attached the image of the board the r47 coil near the fan has no voltage and the other one coil the rest have voltages also vcore is present 1.05v
                      • on/off
                        • Oct 2016
                        • 333
                        • Indonesia
                        Check this: https://www.badcaps.net/forum/showpo...41&postcount=1
                        • Romy2018
                          • Sep 2018
                          • 174
                          • japan
                          still cannot figure out this problem anyone can help on this please
                            • 22159
                            HP error codes https://support.hp.com/us-en/document/c01732674
                            Try another bios chip , and flash the EC .
                            • String2016
                              • Nov 2015
                              • 2241
                              • philippines
                              does anyone have a working EC on this please share
                              • String2016
                                • Nov 2015
                                • 2241
                                • philippines
                                anyone can share a working EC BIOS on this please i need to flash the EC using svod
                                • on/off
                                  • Oct 2016
                                  • 333
                                  • Indonesia
                                  Try this, and give feedback!
                                  If you have problems when extracted, try use 7zip
                                  • String2016
                                    • Nov 2015
                                    • 2241
                                    • philippines
                                    ok thanks i will try your ec and give feed back soon
                                    • String2016
                                      • Nov 2015
                                      • 2241
                                      • philippines
                                      @on/off not working still the same issue as above 5blinks then 3fast. I have attached my original EC, can someone fix this please
                                        • 22159
                                        5.3 (blink) The embedded controller times out waiting for the BIOS.
                                        Flash the bios,the ec posted by on/off is ok ,if you have a scope check signals .
