Samsung LN40B500P3F screen goes black every few seconds
  • mike_drz
    • May 2017
    • 43
    Hello folks, as the title states, the TV's picture will drop to a black screen every few seconds and the picture will come back intermittently. There is audio the whole time, and it's not a signal issue, as it does this in all modes even with the signal cables unplugged.
    I've opened it up and found that one of the inverter transformers was getting very toasty, it had black char marks (part QGAH02095). If I just replace this part is it likely to just fail again in the near future? Does it have anything to do with the light tubes? If I need to replace the tubes, how would I go about that, and where could I get them? Has anybody had the same issue, is it worth fixing? Pictures attached.
    Any advice is welcome, Thanks in advance,
    Mike
  • R_J
    • Jun 2012
    • 9625
    Re: Samsung LN40B500P3F screen goes black every few seconds
    I have seen this before, many times its the blue one that goes bad, sometimes it's just the transformers insulation that breaks down and it shorts, spend the $6.00 and replace it
    • mike_drz
      • May 2017
      • 43
      Thanks RJ! I'll give it a shot, worth a 6 dollar gamble. haha I'll check other components while I wait for the part to come.
      • neilc6
        • Nov 2015
        • 1550
        I've replaced this part before with no other issues. If you order the part from China, it could take 3-6 months to get past customs in Canada so would recommend that you purchase from a North American seller.
        Would also recommend recapping the 8 larger electrolytic capacitors.
        • R_J
          • Jun 2012
          • 9625
          I have never had any problems with customs and parts from China, especially with cheap parts, it takes a while usually a few weeks if they use postal service.
          • mike_drz
            • May 2017
            • 43
            Thanks for the advice. Canada customs can be crazy at times. Sometimes I get Chinese packages in 2.5 weeks, other times it's 4 months. All the north american sellers have this at $20 vs $5 from hong kong. I might need a backup TV in that time, hah
            • R_J
              • Jun 2012
              • 9625
              You can sometimes speed it up: this seller https://www.ebay.ca/itm/Inverter-Tra...-/251243358376
              Economy International Shipping 12-43 days
              $4.00 extra for Standard International Shipping 11-22 days
              I just ordered some parts from Laval QC, $60.00 shipping for under a pound envelope Puralator
              Digikey, from the USA next day $8.00!
              • mike_drz
                • May 2017
                • 43
                Thanks for this link, I ordered from an ebay seller that uses "speedpak" whatever that is, but customs still holds on to it just to be difficult sometimes. I LOVE digikey, I have digikey boxes all over the place here. lol
                Here's an interesting link regarding crazy shipping delays, Canada Post blames Customs, and customs blames Canada post.
                https://calgary.ctvnews.ca/canada-po...lays-1.3447438
                • mike_drz
                  • May 2017
                  • 43
                  I finally got the replacement part in today. I soldered it onto the board and put the board back in to the TV. No more flickering backlight, BUT now it sounds like an electric razor due to buzzing from the board whenever the backlight is on.
                  It's hard to tell which transformer it is coming from, but I used a non contact style probe to narrow it down a bit. The noise is loudest in the area's highlighted in yellow. The thermistors also get pretty warm, not sure how hot those should get. I let it run like that for 15 minutes or so and tapped all the transformers with the plastic end of a screw driver. It didn't change the sound. The transformer near the middle was warm to the touch but not super hot.
                  Yes I know it's been a while, but thanks to my country's postal service, they didn't get around to delivering my package for months.
                  • Chrissygizmo
                    by Chrissygizmo
                    02-10-2025, 12:33 AM
                  • Chrissygizmo
                    samsung galaxy ao2s very temperamental after screen replaced
                    by Chrissygizmo
                    Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                    Ive eventually managed to get it on and working but it's very temperamental...
                    The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                    05-26-2024, 12:05 AM
                  • JunkmanJimbo
                    Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                    by JunkmanJimbo
                    Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                    No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                    Please help. Thanks in advance!
                    08-12-2025, 11:45 AM
                  • Kiberge
                    Samsung LH82QENELGC/EN Help needed - Static line on screen
                    by Kiberge
                    HI guys!
                    I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                    I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                    the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                    This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                    04-22-2024, 11:28 AM
                  • Ryan.man
                    by Ryan.man
                    02-04-2025, 12:23 PM
