Panasonic TC-P50S2 7 blinks
  • jason123
    • Oct 2015
    • 1068
    Hi there,
    Yet another odd Panasonic issue. So I get 7 blinks on this TV. Followed the guide by shorting the jumper on the SC card and disconnecting the 3 connectors to the SU / SD cards. I still get the error by now 10 blinks.
    Impedance on the SS power pins is about 6.x M Ohm. ON the SC 1.7 K Ohm.
    Any thoughts what to look at next? Vsus doesn't seem to comp up at all. I'll keep trying.
  • jason123
    • Oct 2015
    • 1068
    Re: Panasonic TC-P50S2 7 blinks
    Now after taking few measurements, safely, it's showing 10 blinks
    • jason123
      • Oct 2015
      • 1068
      In reviewing the videos, the System was actually giving 8 blinks, not 7. Sorry about that.
      After I isolated the SC card from SD / SU and added the Jumper, I started getting 10 blinks consistently, even with all the connections are in place. Have I fried something??
      I disconnect sc2, ss11,p35, the 3 white ribbons attached to the A-board and the TV on , I get no errors. Someone suggests that issue is with SC board.
      I ordered the SC repair kit from ShopJimmy, but I"m afraid I have other damage on the SS board.. Any way to find if there is an issue with SS card?
      • jason123
        • Oct 2015
        • 1068
        Any help please?
        • nicholas1110
          • Aug 2012
          • 127
          • usa
          Hi, best bet is to check the fets on the sc board and ss boards. Most likely you only have a bad sc board. Check q661 on the sc board first.
          • jason123
            • Oct 2015
            • 1068
            Thank you.. I got the kit from ShopJimmy, and replaced all the shorted FETS.. Seems D482 is also shorted and that's not part of the kit.. so I ordered that today.
            Kit includes ICs and small Diodes and resistors that I didn't replace as they didn't seem shorted. Is it recommended to change them all out?
            • tvtimmy
              • Mar 2015
              • 1160
              • usa
              If the resistors and diodes check good you can leave them. I would change the ic drivers though.
              • jason123
                • Oct 2015
                • 1068
                Thank you... Replaced all dead FETs, Diodes, and IC Drivers. Is there a way to test the SC card alone? I'm afraid the damage on the SC is because of shorts on the SU and SD card. Do I install the jumper on the SC card and disconnect the 3 connectors to SU / SD card? Can I keep the SS card disconnected also? I've seen several posts with conflicting information. Thanks
                • tvtimmy
                  • Mar 2015
                  • 1160
                  • usa
                  Remove the 4 screws that hold the buffers down to the sc. Unhook the 3 connectors from sc to buffers. I take a paper sheet and slip it in between the buffers and the sc, just to make sure. Find sc50 on sc board and short both pins together, I use a small alligator clip. Turn on tv and if the green led stays on for 20 seconds, your sc is ok. Dont run it like this for more than 30 sec.
                  To check the buffers for shorts, put meter in beep mode. Thats when you touch probes together the meter beeps, telling you there is a short. Put one probe on one of the screw holes you removed for the sc test and take the other and rake across the ribbon connectors.flip up the latch but leave the ribbon in and sweep across all the pins on that side. No beeps means good buffer. ANY BEEP means bad buffer.
                  • jason123
                    • Oct 2015
                    • 1068
                    Perfect.. Thank you tvtimmy.. I'll try that shortly.
                    • jason123
                      • Oct 2015
                      • 1068
                      Hi again, reporting back.
                      Unfortunately, I must have missed a bad component. Upon testing the SC, I get the 7 blinks still, and the following components died again:
                      Q661
                      Q621
                      D641
                      D642
                      Any idea what I could have possibly missed? everything that came in the ShopJimmy kit was installed. Thanks
                      • jason123
                        • Oct 2015
                        • 1068
                        Anyone can please confirm what part number corresponds to what device? i took them all off to buy replacements, and I thought I could find them in the schematic, but the schematic only has Panasonic internal numbers and not manufacturer numbers. It probably helps to let you know what board I have
                        TNPA5105AB
                        • budwich
                          • Jul 2015
                          • 3097
                          once you have removed those components that you have found bad, recheck all "three legged" components / semiconductors for short to ground conditions. There are quite of few beside the four that you list. I thought I had found mine but forgot / failed to test others beside the "fets" that are normally pointed out... my board only lasted a few seconds before "pop".
                          • jason123
                            • Oct 2015
                            • 1068
                            Thanks Budwich. I thought I tested all the large 3-legged devices, but I guess I missed some. I replaced about 11 FETs and Diodes and before I plugged it in, all of these (Q661
                            Q621 D641 D642) were operational.
                            There has to be something I'm missing - a sense resistor or so.
                            Anyway, Now that I took these parts off.. I can't recall what goes where. I had them lined up on the table and my son came and moved things around.
                            Can you tell the part numbers for these components so I can buy replacements?
                            Also, finally, I was able to find a TNPA5105AD board. Is this usable in place of the TNPA5105AB?
                            Thank you
                            • tvtimmy
                              • Mar 2015
                              • 1160
                              • usa
                              The tnpa5105ad board is for a 42" tv. Im pretty sure it wont work.
                              • budwich
                                • Jul 2015
                                • 3097
                                in terms of your "dilemma" (parts off, where do they go?), see if you can locate a picture of the board on shopjimmy... you might get lucky. Further, beside the "short measurement", also check the measurement of the "feed resistors" going to the various "fets" to see if they all agree.
                                • jason123
                                  • Oct 2015
                                  • 1068
                                  Q661 rjp63f3a
                                  q621 rjp3034
                                  d641 rf2001 tm3sw
                                  d642 rf2001 tm3sw
                                  • jason123
                                    • Oct 2015
                                    • 1068
                                    Ok, I've gone component after another and I found R451 open. Could this be causing the above transistors and diodes to die after replacing with new ones? it seems that the resistor is in a totally different part of the circuit though? thoughts
                                    • tvtimmy
                                      • Mar 2015
                                      • 1160
                                      • usa
                                      Yes it could. When you find a bad part you MUST replace it or you can do more damage to the board.
                                      • jason123
                                        • Oct 2015
                                        • 1068
                                        Happy 4th to all!
                                        tvtimmy I plan on replacing it for sure. I'm just curious whether it can be the culprit, or am I still missing more bad parts
                                        Thank you
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                          11-20-2024, 08:52 PM
                                        • jm1234
                                          Panasonic plasma TX-P42ST50 - 6 blinks
                                          by jm1234
                                          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                          I checked that board for any obvious faults...
                                          05-22-2024, 06:59 AM
                                        • Alicat
                                          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                          by Alicat
                                          Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                          Model number is TH-50PZ85U
                                          Power comes on and the red power light stays on solid.
                                          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                          I also hear a few clicks.
                                          I also think my parents said there was a thunderstorm and the TV failed after that.
                                          Section 6 in the service manual talks about power and no screen,...
                                          10-30-2024, 10:09 AM
                                        • CrewmanRedShirt
                                          Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
                                          by CrewmanRedShirt
                                          Hello all,
                                          As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
                                          07-13-2024, 11:02 AM
                                        • nobbnobb1
                                          Panasonic TC-P50U50 Powers Off - 8 blinks
                                          by nobbnobb1
                                          I have a Panasonic TC-P50U50 plasma TV which powers on briefly, then powers off and flashes the power light with 8 blinks. This TV is infamous for this, of which the suggestion that the SS board has failed due to loose grounding screws and requires a replacement of the following components on the SS board:
                                          2x DG302 (Q16051)
                                          2x RF2001 (D16041)
                                          2x 5.6 ohm SMD resistor
                                          1x BD8694 IC
                                          I have already gone ahead and replaced these components, as well as cleaning off the ground connections on the SS board as well as the associated...
                                          03-21-2023, 08:33 PM
