Hello everybody,
I am new to this forum or at least a new member because I used to read a lot of useful informations since several months.
I am trying to repair on of my TV which the relay is clicking while I try to turn in on.
Thanks to the useful advices I have located the issue on the Z-SUS board and maybe on the Y-SUS on as well (I need to check it later).
The issues I have found on the Z-SUS board were two shorted IGBT 30F124 that I will replace with two 30J124 and also change the IC7 and IC8 on the board. I also noticed a short Zener Diode noted ZD2 attached to one of the 30F124 IGBT.
I have removed this diode but I cannot identify which replacement part I should use.
Could someone help me?
I have read somewhere that using a 20V SOD323 diode should be ok.
Thanks a million for your help.
