Car Ammeter Circuit
  • barry wilkins
    • Aug 2009
    • 172
    Car Ammeter Circuit
    Hi a few years ago with my previous Honda Car I had a problem with the battery.
    I saw an idea where you could estimate the current flowing in the battery by measuring the voltage drop from the negative post of the battery to the chassis earth.
    Has any of you seen any circuit ideas to do this ? or would I have to start from scratch ?
    Barry Wilkins
  • petehall347
    • Jan 2015
    • 4427
    • United Kingdom
    Re: Car Ammeter Circuit
    what you are suggesting will only test the integrity of the grounding connections/wire .
    ideally shouldn't see any voltage drop there .
    you would be better fitting an ammeter inline on the suspect circuit .
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      Actually you can estimate it, the thing is that the voltage drop will be quite low if the cable is good. I'd guess it'd be no more than 50mV or so during starting, but not knowing the exact resistance of the cable, there's no way to accurately tell how many amps are going through.
      You'll need precision op amps with low offset to accurately measure 50mV.
      • barry wilkins
        • Aug 2009
        • 172
        The earth wire has an impedance in the order milliohms ,so when you turn the engine over with the starter motor a current passes through the wire and will generate a voltage .
        500 Amps and a resistance of 10 milliohms with equal 5 millivolts.
        Barry
        • petehall347
          • Jan 2015
          • 4427
          • United Kingdom
          but you have to consider integrity of cables and connections . i regard testing like this is rather useless . it would be better to check voltage drop of the battery . or simply using a tool designed for the job such as an inline ammeter or clamp meter .
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            Indeed, as in the other thread, a hall effect clamp meter is probably best. A discrete shunt based meter is the old fashioned alternative.
            Watch your amps. 500A * 0.01Ω (this is 10mΩ) = 5 volts, not 5 millivolts. I was guessing the cables to be fractions of a milliohm, not anywhere near single digit milliohms.
            • redwire
              • Dec 2010
              • 3910
              Using copper (wire or PCB trace) resistance for a current-measuring shunt, the temperature coefficient of resistance is very poor. +0.393 percent/°C, so 10°C is 3.93% error.
              A shunt is hard to keep well insulated and not short to the car body, and to take water.
              I think DC hall-effect sensors are the best. Might need a bi-polar power supply, as battery current can be +ve or -ve.
              Low-cost Winson DC hall sensors are on eBay and Ali, like WCS1800 modules (only 35A).
              • petehall347
                • Jan 2015
                • 4427
                • United Kingdom
                auto electrics are fun sometimes . i should know i do it as part of my day job . only time i look at potential differences is looking for bad connections .
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  When dealing with starter currents, a 5% error is not a big deal, plus you could temperature compensate by measuring ambient. Still not perfect but it's cheap... just that you'll need to make sure you get a quiet, low noise, and low offset op amp.
                  On the other hand, hall effect sensors also introduce error possibly due to magnetic leakage, wire positioning, etc. that may also generate an error. And these too may require a likewise op amp.
                  Now I'm curious how much of a voltage drop really occurs along the cable during starting... wish I had a meter that could hold peak voltage..
                  • petehall347
                    • Jan 2015
                    • 4427
                    • United Kingdom
                    smoke and heat applies more than anything with starters . never overlook tight engines . it can happen . not often but can catch us out . a faulty starter will draw too much current if faulty or too little current . cranking voltage drop on a good battery will tell you where to look at next .
                    • Curious.George
                      • Nov 2011
                      • 2305
                      • Unknown
                      No, 500A will develop 5 volts (5000mV) across 0.010 ohms.
                      Of course, that assumes the vehicle draws 500 cranking amps... (I think warmer climates and the little 4-bangers that are so common, nowadays, means the actual draw is probably much less!)
                      • Curious.George
                        • Nov 2011
                        • 2305
                        • Unknown
                        Don't connect to the circuit anywhere that would place existing connections (or anything else that could needlessly add variation) in the measurement circuit. E.g., make two dedicated connections to the ground wire and let something else worry about how the connections to battery and chassis degrade, over time. Then, you only have to worry about the characteristics of that wire.
                        Of course, you can also use high-side sensing (the '+' lead). In either case, you have to be aware that the current flowing out of the battery can (and WILL!) be negative -- regardless of where you measure.
                        [FWIW, I think most modern cars measure high side]
                        If you aren't as interested in instantaneous readings, you can use an integrating converter (which inherently works around some of the noise issues you face).
                        Regardless, be sure your design can handle the sort of load dumps that a car electrical system experiences (far more destructive than the "noise" from plugs, etc.) And, that it is powered off the ignition and not battery (lest it run the battery flat).
                        • Curious.George
                          • Nov 2011
                          • 2305
                          • Unknown
                          The OP may not be concerned with starter currents. So, focusing overly on them may compromise a design. A shunt/HE/current transformer could be sufficient for most of the data of interest. Use a Rogowski coil tuned to the starter "impulses" to cheaply handle the larger magnitude signals associated with starting.
                          Or, put different sensors in different places: something designed to measure starter current AT the starter lead and something designed to measure "everything else" at another point in the circuit that excludes the starter's load (so the ground strap would not be a good idea)
                          • redwire
                            • Dec 2010
                            • 3910
                            For a big V8 engine, 1ft. section of #4AWG wire at 500A gives 125mV (I'm using 0.25milliohms/ft).
                            Now, this 1 ft section of wire is dissipating 62.5W while cranking, it's going to heat up and cause errors. Something to think about.
                            Charging current of 10A is 2.5mV which is pretty small.
                            A 4-cylinder engine cranking current is much less, I think under 100A on a warm day.
                              • 31071
                              just get a UniTrend UT-210E DC clamp meter.
                              • Astonished
                                Fixing the Charge Circuit of the Batteries of the DC Motor
                                by Astonished
                                Hi friends of electronics
                                What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                                The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                                Please help me fix this circuit.
                                (the datasheet of the IC: https://pdf.datasheet.live/28...
                                01-28-2025, 06:24 AM
                              • Tarot Superstars
                                Short Circuit tester
                                by Tarot Superstars
                                Hello.
                                I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
                                The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
                                Link
                                The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
                                https://www.youtube.com/watch?v=0eixDdCpiO4
                                My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
                                09-25-2023, 09:11 AM
                              • Alimash
                                op amp circuit function?
                                by Alimash
                                I am repairing a ups which doesn't turn on ,it has the following ICs:
                                SG3525 used to drive inverter mosfets.
                                couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
                                A LM358 and TL074 for control mechanism and of course the uController.
                                The SG3525 is shutting down every time the ups is turned on.
                                I want your help to know the function of LM358 and TL074 in the system.
                                I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
                                07-31-2025, 07:45 AM
                              • caspian
                                Can Ammeter damage Power Supply?
                                by caspian
                                Dear Members,
                                My DC linear Lab Power Supply does not display the current and voltage correctly. Thus, I am going to connect an Ammeter/Voltmeter Module to the DC output of the power supply. Then, a load will be connected the takes about 1-5volts with 0.1-1.5Amps.
                                But I heard If I connect an Ammeter to the output of the power supply, then the Ammeter module is not isolated from the power supply so that the Ammeter can damage the power supply.
                                Is this true?
                                I have attached the photo of a sample Ammeter module that I am going to buy....
                                06-05-2022, 01:42 AM
                              • M1NEBLANK SHOW
                                MSI B250 Gaming M3 Short circuit in CPU power supply circuit
                                by M1NEBLANK SHOW
                                Hello. MSI B250 Gaming M3 board, short-circuit on the power supply. Found a problematic mosfet VQ1
                                (N-PK616BA_PDFN8-HF) soldered it out - short circuit is gone. I replaced VQ1 + VQ5 (N-PK632BA_PDFN8-HF). VQ1 was replaced with PK618. After starting attempt VQ1 is lit again. What can be the problem? In the driver?
                                Schematic and Boardview here
                                04-04-2025, 03:57 PM
