I have seen much posted on this website that Bestec is nothing but poorly designed mobo killer. Most of the problem has been attributed to 5VSB poorly designed. I have repaired two Bestec model ATX-250 12E psu that did indeed have poor 5VSB flaw. The pc board was discolored from overheating and components failed which allowed the voltage to go well above the 5 volt level.
On the other hand I have repaired two Bestec model ATX-250 12Z which have a 8 pin pwm chip (A6351A) for the heart of the 5VSB circuit. The 5VSB did NOT fail in either of these two PSU, and the pc board was not discolored from overheating on these two PSU. Perhaps the engineers have admitted the need to redesign - and the later model does indeed seem to have a much improved 5VSB.
Bad capacitors can still be a problem, but that is a problem on lots of PSU. Perhaps it is time to elevate the later better designed Bestecs to a higher level of quality, especially above PowMax (aka maximum bang). I'll post some photos of one of these later models, along with a drawing of this new chip design 5VSB.
Run Away! Run Away!
