Delta DPS 320 EB missing power good signal
  • ultrasmurf
    • Sep 2017
    • 9
    • Singapore
    I'm troubleshooting this delta DPS 320 EB. Problem : PG Signal is at 0V. Leaky capacitor has all been replaced and could not help to think that the problem lies in the DNA1002 chip which from what I read is a custom IC by delta.
    I'm using the following schematic as it looks quite similar (not the same at all in terms of component value but more or less similar) : https://cdn.badcaps-static.com/pdfs/...2cdd095645.pdf
    Measurement at the output :
    5V : 5.15
    12V : 11.7
    -12V : -12.08
    3.3V : 3.37
    under load 5v drop to 5v and 12v line drop to about 11.45v. Values doesn't look too good but should still be within ATX spec (not sure about DNA1002 expected value).
    Measurement on DNA1002 pin shows similar number like the one on the simonwyss website, except pin 3 (PG : 0v expected 5v), pin 8 (Unknown : 2.6-2.7v expected 4.25v), pin 9 (5Vin : 5.15) pin 10 (12Vin : 11.7V), pin 14 (unknown : 2.6v expected 2.7v). Expected value is based on symonwyss number. All other pin are pretty much spot on with his measurement.
    Adding filtering capacitor on 5V and 12V lines does not help.
    Any ideas where could the problem lies ?
    Thanks for the help...
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: Delta DPS 320 EB missing power good signal
    Can you elaborate on that? Which capacitors were replaced and which weren't? The output capacitors (3.3V/5V/12V/-12V rails)? - All of them? What about the small capacitors near the control board(s)? Replaced those too?
    If there are any bad cap brands still left in there, there is no point to try and troubleshoot with measuring voltages and whatnot - you need to replace all capacitors (except the big primary caps). Otherwise, there is not telling if one of those small buggers may be messing up the whole circuit or not.
    Also, pictures of your power supply would be helpful.
    • ultrasmurf
      • Sep 2017
      • 9
      • Singapore
      Output capacitor are all tested good (surprisingly...). Primary cap is also tested good. Bad capacitor are mostly on the control path and bypass cap for the IC. 47uf and 4.7uf type.
      Capacitor testing is using oscilloscope and function gen set at 125khz square wave 250mVp for onboard testing, if it shows some high ESR then taken out and replaced ( for a 250mV signal i define it as questionable if it still shows a 5mV signal after connected to the cap ). Did a test adding 2200uF parallel cap on all the output cap and it does not fix the issue.
      Output voltage was observed with oscilloscope and ripple is well within ATX spec even without adding parallel cap to the output capacitor.
      Will try to add picture soon...
      • ultrasmurf
        • Sep 2017
        • 9
        • Singapore
        Picture of the PSU. Replaced capacitor is highlighted with red square. Additional note : This is PSU for B2600 HP Workstation, after replacing these bad capacitor workstation boots up and running for 3 days straight without issue. I also have a second workstation that I have replaced it with normal ATX power supply (swapping the pin around to match B2600 pin) and that is also running fine.
        Next plan is to blindly replace every single electrolytic cap for both secondary and primary side to see if that brings the PG signal back on ( saw other thread reply encountering same issue on different psu ). Just that it doesn't make sense to me as output signal shows good ripple in the scope...
        Few other additional note :
        I can hear a faint tweet tweet tweet sounds roughly about 1 or 2 in a second that changes slightly depending on the load I introduced in the 12v or 5v output. Couldn't really pin point where it is coming from... I don't really have the guts to put my ear too close to a live PSU... who knows when those cap or transistor decide to blow themself up.
        Adding a 12v100W halogen lamp load on the 3.3V line will make the PSU refuse to turn on ( a mere 7.5W load at 3.3V?), adding these load when PSU is running doesn't cause any issue.
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          As I thought.
          These small caps can cause lots of issues like this.
          It's probably the small caps if loss of PG signal is all there is wrong with the PSU.
          Don't just replace blindly - replace blindly every little capacitor. The big ones, not that important for now (if ripple is within spec).
          That said, try to use good quality low ESR capacitors rated for PSU use (and 105C). Don't use 85C general purpose stuff - that's no good, and you will be doing this recap again in the near future, because they won't last long in there.
          Halogen lamps have a very low resistance when cold - almost like a short-circuit. With the lamp connected before the PSU is turned ON, the PSU has to supply a large surge current to the halogen lamp and also its own output capacitors. This alone can be enough to trip the short-circuit, over-current, or under-voltage protections. Once the PSU is running and the output caps are charged up, they can provide that large surge current when the halogen lamp is cold, so that's why the PSU doesn't shut down once it's running.
            MSI Delta DELTA 15 A5EFK-008 Notebook 15 Specification for Upgrade or Repair
            This specification for the MSI Delta DELTA 15 A5EFK-008 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the DELTA 15 A5EFK-008 boardview and DELTA 15 A5EFK-008 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
            09-07-2024, 03:40 AM
          • cappernicus
            Acer Spin 5 - Lenny_ICL (19771-1) -- Dead - PM_SLP_S3# held low
            by cappernicus
            Laptop model: Sp513-54n-74V2
            Testing power rails (separated by chip) reveals:
            19V_DCBATOUT - (active)
            5V_AUX_S5 - (active)
            5V_S5 - (active)
            3D3V_AUX_S5 - (active)
            3D3V_S5 27Ω - (good) - enabled by Nuvoton chip
            1D8V_VCCIN_AUX - (good) - enabled by 1D8V_S5 PG signal -- (dependent on 3D3V_S5)
            1D8V_S5 41Ω - (good) - enabled by 3D3V_S5 PG signal
            1D05V_VNN_BYPASS - (good) - enabled by 1D8V_VCCIN_AUX PG signal...
            09-25-2024, 05:19 PM
          • Fernon@Repair
            MSI mpg b560m bazooka motherboard RSMRST# signal missing
            by Fernon@Repair
            I have MSI mpg b560m bazooka motherboard . this motherboard RSMRST# signal missing . i already reprogram bios but same condition
            My Motherboard this power stages are ok ...but 3vsb voltage have 4.17v (image added)
            VCCRTC ok
            RTCRST# ok
            ATX_5VSB ok
            SIO_3VA ok
            3VDSW ok
            DPWROK ok
            SLP_SUS# ok
            VSB_ENABLE# ok
            5VDUAL ok
            3VSB showing 4.17V
            PCH_1P8_VSB ok
            PCH_VCCIN_AUX ok
            RSMRST# No voltage
            this all voltages are ok but RSMRST# voltage is missing i did try to re program bios and change io but same...
            06-03-2025, 10:49 AM
          • Prott
            Surface 7 - missing S3 sleep signal, S4 present but weird
            by Prott
            Hey fellow Badcappers
            I am troubleshooting Surface 7 board (rev 1.0) which was working great until it experienced a short circuit due to a bad screen.
            Now it's missing SLP_S3 signal. Everything in the power on sequence works properly up until that signal.
            - The resistance to ground on the SLP_S3 line is >50 kOhms.
            - No shorts on any powerrails that I can find.
            - I get a proper clock signal on the RTC crystal (XTAL_2P) once the Surface gets power.
            - SLP_S4 is, suprisingly, present, but it looks very weird (jump up to 2 V for about...
            07-08-2023, 04:54 PM
          • Rayblaster
            HP RP7 RP7800 from 2012/2013 worst fault - has "character"
            by Rayblaster
            Hello friends, I've got a nice toy to play with - it is an HP RP7800 All-in-one POS system. I got it for free and it has one problem - it turns on very rarely, and just for a few seconds. After that it dies and doesn't come on if I don't leave it unplugged for at least 2 hours. I've repaired motherboards before, this is not my first one, but problem with these types of faults is that everything you check on the board will usually be fine. This is the case for me here.
            I dissassembled it completely, and got my hands on the motherboard. Model No. is PIQ67H/Higgins 11047-I 48.3GD02.011....
            12-30-2024, 06:28 PM
