Plasma cutting torch-chopper board miss communication
    • Jul 2011
    • 6070
    We have a plasma cutting machine that cut metal on a table bed
    We live in Florida and weather had been raining with 91 to 95 % humility
    Here is where the problem starts we had this problem for about 2 years off and on when the weather would be raining and humidity at 90 to 95 % sometimes the plasma would fire and run but not always it would fire but not cut the problem would not stay there to figure out what the problem was
    But when you would look at the trouble shooting screen on the machine controller it would not show any error message but the set point for the amperage that CAD program would say 200 amps the set point should be for the chopper should 100 amps for two choppers to = 200 amp but instead of showing the right set point it would show either 0 , 40 , 140 for each chopper which completely wrong
    Now last week Tuesday it was raining again with 90 to 95 % humidity and of course here we go again the plasma torch would fire but would not cut and was showing the wrong chopper set points
    So I called tech support and they logged in to our machine and technician that was helping with this problem
    try a few things which did not work which has been done in the past and this would make the plasma torch work again for a little while and then would do the same thing again
    So the tech that worked with me on this problem a few times before says I do not know what going on here
    So he had pull the communication cable from the machine controller to plasma controller and clean both ends of the connectors and reinstall them this did not help either
    This problem was going on it's second day being on the phone with tech support and not getting any where
    Now in the past when we have had problems with CON communication cards on the plasma controller before not communicating with each other but when that happens you get a communication error
    and that error would tell which card is having the problem-----****---- not always
    So I took the covers where these or cards are and look to see if the cards are communicating with each other they have two LED lights that blink if they are working
    I saw some of the card with a light amount of dust on them so I blew them off but that did not help
    The plasma torch still would not work so look a the status lights on the chopper boards there are two lights on each board there are four of them they are all ON the ones that should be ON
    There is some light dust on these board as well so I blew all four chopper board off as well
    Would you know it the plasma torch fire up and now it is cutting and the trouble shooting screen is now reporting the right settings
    Now who would of thought that a little bit of dust and very high humidity would cause all this trouble
    So I emailed tech support person that was helping me again and told him what I had found and what I had done and his reply was the photo below with Gremlins ?? Above the photo
    Which my reply was is there any cure for this
    His reply
    Bright Lights
    My reply was real funny
  • ChaosLegionnaire
    HC Overclocker
    • Jul 2012
    • 3266
    • Singapore
    Re: Plasma cutting torch-chopper board miss communication
    momaka warned me about this before. he said moist dust tends to stick and adhere to surfaces. this can form an insulating layer that can cause heatsinks to perform slightly worse than expected due to dust getting in the way of the heat being dissipated from the heatsink to the air. i guess the same applies to electrical conductivity as well not just thermal conductivity.
    i live in a humid tropical climate as well and often experience problems with pci-e, pci, agp expansion cards and dimms not being detected by the mobo. i have to clean the goldfingers on the cards as well as the mobo slot to get the stuff detected by the mobo again.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      the dust generated by a cnc plasma is conductive.
      thats why i got a samson 5x10 nearly free.
      had to clean EVERYTHING!
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        ^^Exactly.
        The dust contains metal particles.
        Same problems occur with laser cutting machines.
        Same dust created: just much less compared to a plasma since the kerf is not as wide...
        I've got a free APC UPS for the same reason
          • Jul 2011
          • 6070
          Update
          The plasma is cutting at 200 amps so the miscommunication problem is still there I give you an update when I figure out what this problem is the plasma will not cut 400 amps
            Hypertherm Plasma Chopper IGBT Module failure successful repair
            by sam_sam_sam
            I have several chopper units that need to be repaired but just repaired one of them to see if it could be done successfully which they can be repaired
            The company that makes the IGBT module have discontinued this part as 5/30/2020 which our company has bought 12 IGBT modules which will allow me to repair 6 chopper units ( one note there is no direct replacement availability )
            I am buying these modules directly from the manufacturer
            But there is a 8 week lead time
            Now you can find on EBay for half the price but I have a feeling that might be fake...
            06-07-2020, 11:08 AM
          • ArMaaN376
            Samsung PS51E550 Plasma TV
            by ArMaaN376
            I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
            Opened TV cover & observed foll
            a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
            b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
            c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
            How to confirm Y -Buffer board...
            06-19-2024, 04:05 AM
          • jm1234
            Panasonic plasma TX-P42ST50 - 6 blinks
            by jm1234
            anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
            It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
            I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
            I checked that board for any obvious faults...
            05-22-2024, 06:59 AM
          • KYBOSH
            Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
            by KYBOSH
            Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
            No picture but you hear the TV static (white noise) playing loud and clear.
            The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
            But it seems they didn't get too far and just left it.
            When I first took a look I was amazed at how pristine the inside looked.
            Its as if the TV had been in a time capsule.
            Caps looked like they were just pulled off the self.
            Copper coils had no sign of corrosion on...
            02-01-2023, 11:10 PM
          • Storyteller12
            Cutting new light diffuser question
            by Storyteller12
            I have a Samsung 40” NU series tv with the melted cracked diffuser I’m fixing. I replaced the backlights and I’m planning on cutting a new diffuser out of a 55” diffuser that just melted but didn’t crack.
            Question is do I have to keep the top edge factory for the diffusing to work properly or does it matter?
            only get one shot at cutting it so wanted to make sure....
            03-30-2024, 07:54 AM
