Xbox Original 1.6 died while running then would not boot no lights no fan no nothing
  • triplefour
    • May 2014
    • 1747
    i have a soft modded xbox 1.6 that suddenly died on me while it was up and running, i was just about to ftp some files to it, and it just shut off. i tried to turn it back on and nothing happened. i have another working 1.6 so i used that to verify cables are all working properly. then i took both apart and swapped power supplies to verify that both PSU's are fine. i even swapped motherboards, thinking maybe if the switch was bad, but both cases/switches are fine. its definitely something on the motherboard, keeping it from booting up. i read everywhere that the 1.6 needs the clock capacitor to be there to work, and i did notice that the cap was bulging on the dead motherboard. so i swap the clock capacitor from the working motherboard to the dead one.
    NOW, i get the xbox trying to start up, but failing.
    it goes like this:
    press power -> green light and fan come on for about one second -> system shuts down. this repeats:
    then:
    -> green light and fan come on. light stays green for about 1 second, then green light switches to flashing green and red infinitely.
    the console stays on blinking like this just fine, but no video is displayed.
    i have tested the other 1.6 and it doesnt need anything plugged into the motherboard besides power and the switch, to at least display something (an error code) on the screen
    even though, i tested it with everything plugged in (dvd, hd, controllers) and it still does the same thing.
    i cant see any other damaged components on the motherboard, and none of the caps looked bulged.
    what can i do next to chase down the offending component and replace it?
    would a suddenly failed clock capacitor shut down my system and fry some other component like that? or is it more likely that some other component failed first, causing the failure of the clock capacitor?
    does anyone here still care about xbox original?
    its an awesome retro console, great for running emulators and xbox original games. its worth keeping alive in my opinion.
    Don't fear the repair...
  • triplefour
    • May 2014
    • 1747
    Re: Xbox Original 1.6 died while running then would not boot no lights no fan no noth
    forgot to mention that i replaced the cap in the good board with a 2200uf 6.3v cap i had laying around and it works fine...i read stj say that in one of the other posts that you could use any cap really for the clock cap.
      • Jul 2011
      • 6037
      You need to recap the mother board and would not hurt to recap the power supply and see that fix the problem you are having
      I would use (KY) , (KZE) or any cap having a low ESR value
      I hope this helps
      • Dan81
        SNES-powered
        • Oct 2013
        • 1865
        • Romania
        You'd have better results with a 3F 2.5v. Far more capacity to store the time.
        But just as sam_sam_sam said, replace the CPU caps as well, ESPECIALLY if they're Nichicon HM/HN. I had bad HM and HNs without visibly bulging. (just like some UCC KZG and Toshin Kogyo ATWY series)
        Main rig:
        Gigabyte B75M-D3H
        Core i5-3470 3.60GHz
        16GB DDR3-1600
        Samsung SH-224AB DVD-RW
        Delux MG760 case
        • Wester547
          • Nov 2011
          • 1268
          • USA.
          Yeah, occasionally, the 1F 2.5V Nichicon UC double-layer capacitor is known to bulge. At least it doesn't leak its contents onto the traces 99% of the time like the truly crappy 1F 2.5V Aerogel Powerstor B series "super" capacitor, resulting in catastrophic failure and turning the console into a fire hazard as the traces are destroyed by the highly acidic, leaked electrolyte.
          Well, this could *possibly* be your issue (a bad FET): https://youtube.com/watch?v=deSa6-yeY1I
          Seems to be a common issue with version 1.6 and motherboards that refuse to power on for more than a second can certainly be "plagued" by such an issue. The original Xbox motherboards had another issue where the traces going to the LEDs, eject button, and power-on button were either damaged by either the plastic stand-offs on the underside or too much residue and flux from the factory (hard to tell which because the plastic stand-offs seem to be too close to the PCB's underside for comfort), slowly eating away at the solder mask and traces, resulting in corrosion and oxidation.
          I completely agree with you. And yes, I do.
          Certainly, the original Xbox had its fair share of "issues", but because it uses wirebond rather than flip-chip BGA technology (for the GPU/Northbridge and MCPX chipset, the CPU does use flip-chip BGA technology but it's an Intel CPU and Intel seem to know what they're doing with their choice of underfill and solder bumps, much moreso than NVIDIA) and because it's mostly pre-RoHS, it's much more feasible to repair the first Xbox than any Xbox that came after. That said, the MCPX chipset has no heatsink and does run pretty hot, and it's still BGA, so there is a *slight* chance it may be the issue (but hopefully not - if worse comes to worse, you can install a heatsink on the MCPX chipset and see if that helps, if it's only overheating and isn't too far gone).
          And yes, it would help to know what the CPU VRM input and output capacitors are on this motherboard. Version 1.6 uses five 3300uF 6.3V 10x25mm diameter capacitors here, either Nichicon HM (2004-2005 datecodes), Sanyo (Suncon) WG, or Rubycon MBZ, all interchangeably. I've yet to see a WG or MBZ fail in this position on these consoles, but there have been many instances of the bad datecode HMs failing on these boards (and 1.2-1.5 boards as well, but that's for another topic), as you can imagine. As Dan81 said, bulging or not, if that's what's there, it's best to replace them and see if that cures your issue.
          • triplefour
            • May 2014
            • 1747
            thanks for the reply. yeah they're nichicon HM. so i guess replace those 5 and pray? will let u know. where should i buy them? here?
            • triplefour
              • May 2014
              • 1747
              oh yeah and i checked that transistor in the youtube clip and i was getting the normal voltage there so it should be fine
              • Wester547
                • Nov 2011
                • 1268
                • USA.
                The issue could be unrelated then. Hope the tracks on the underside aren't damaged.
                https://www.badcaps.net/store/produc...products_id=30
                Those should be suitable replacements for the Nichicon HM. You can buy them either here (by way of the above link) or from an authorized distributor such as Digikey or Mouser. But the replacements above are the closest match height and width wise and are a slight improvement upon the original capacitors with respect to the ripple and ESR rating.
                • triplefour
                  • May 2014
                  • 1747
                  thanks i ordered 5 from here. crossing my fingers!
                  • triplefour
                    • May 2014
                    • 1747
                    well the caps came in today and i did the job, but it didnt change the symptoms at all. still tries to boot up, shuts down, loop, on the 3rd try it stays on and flashes green and red...
                    what else can i look for?
                      • 30991
                      corrupt bios or a corrupt or badly fitted mod chip will do that.
                      • triplefour
                        • May 2014
                        • 1747
                        well i dont have a modchip... and if the bios is corrupted how can i fix that? it's soft modded...
                          • 30991
                          if that is the problem, fit a cheap modchip like this:
                          http://www.eurasia.nu/shop/product_i...roducts_id=266
                          • triplefour
                            • May 2014
                            • 1747
                            is there any way to tell if thats what it is before throwing more money at it?
                            12 bux is pretty cheap tho. if it didnt work i could just install it into another xbox?
                              • 30991
                              afaik the leds and related stuff are controlled by a microcontroller.
                              originally a PIC, and then a custom (or atleast it has a custom part number)
                              it probably just means the main cpu is not running as it should.
                              it could be something as simple as a small cap used to start the system.
                              i have a 1.1 doing the same thing i need to look at.
                              btw, on the 1.6 you can replace the supercap with a 220uf 16v cap.
                              on older boards you dont need anything there at all.
                              • TMTGTR
                                An Xbox One PSU Odyssey
                                by TMTGTR
                                Firstly I am not a tech. You guys may see mistakes or oversights in my methods so don't be bashful and feel free to post corrections/opinions.
                                =>Background:
                                I bought my son a used Xbox One original model: A12-220N1A Rev: 02 with original PSU & 2 controllers 7 years ago. I “modded” the unit placing a 4.5” 12V exhaust fan with a 9v wall wart adapter on top of the vent/fan of the unit. And plugged the Xbox PSU into a Tripplite LTR-600 voltage regulator. Also connected to the Tripplite are a 275w computer tower, an Xbox 360 PSU and a Westinghouse 52” LED TV. ...
                                06-17-2022, 05:40 PM
                              • ohren
                                Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                                by ohren
                                Hello!
                                I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                                Measured voltages with no load:
                                After rectifier diodes
                                12V: 6.17 V
                                5V: 5.67 V
                                Secondary transformer pins AC measurement (really don't know if this says anything)
                                12V: 2-2.5 V
                                5V: 1.04 V
                                I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                                03-18-2023, 10:33 AM
                              • tccyo22
                                Xbox One Original missing 12v enable signal
                                by tccyo22
                                Hi there, I have an Xbox One original in which I have all the 1.8v, 3.3v and 5.0v standby power rails present, however my 12v rail is not turning on and the enable signal PSU_V12P0_EN from the SMC to turn the power supply on is missing. There is high resistance on this line so it's not shorted directly to ground which leaves me with not many options.
                                Was looking at a schematic and see the enable is created by the SMC. I have 3.3v on SMC_RST_N_IN but I'm a little stuck on where to look next. Is it likely that the SMC has gone bad or am I missing something else (it's my first time with...
                                08-14-2023, 06:06 AM
                              • Tynan Dill
                                by Tynan Dill
                                Assuming...
                                11-22-2024, 01:46 PM
                              • bulkchart32
                                does anyone have a schemtaic for what circuit each cap is in on the original xbox?
                                by bulkchart32
                                i have a 1.1v and i am having issues with faint wavy lines on the screen that i am trying to make perfect so it will be my main xbox.. also have some 1.0v's that are doing it but to a lesser degree. i really don't want to do a full board recap, especially don't want to have to replace those smds, so i want to find which specific caps that filter the video signal. i have already replaced several caps and messed up one of them that caused a dead short(has been repaired). so i really don't want to just do all the caps. plus, those 1.1v boards have a lot of them. i'd really like to just focus on the...
                                05-16-2025, 07:33 PM
