LED blacklight flickers at low brightness, PFC output voltage unstable. Help!
  • cmg
    • Dec 2016
    • 32
    • United Kingdom
    Hi All.
    I have a problem which is hopefully relevant for other readers of the forum and other monitors as it is concerning the PSU and LED backlight driver. The symptoms are that as the brightness is reduced using the front panel controls, the screen starts to flicker quite annoyingly. I believe this is a fault in the PFC circuit. The output voltage from the PFC circuit pulses in correlation with the flickering. This is on an HP ZR2740W 27" monitor.
    The PFC controller is a 28051 (see https://cdn.badcaps-static.com/pdfs/...898502619c.pdf), so I'm referring to the reference circuit for this. I don't have the schematic for the PSU but the components I have checked are identical to the reference circuit. The PFC circuit for this monitor is discussed in thread https://www.badcaps.net/forum/showthread.php?t=42498
    Observations:
    • no noticeable flicker when the monitor is at high brightness, and normal operation overall
    • as the brightness is lowered it starts to pulse periodically, initally at about 10Hz
    • as the brightness is lowered the flickering gets more pronounced and the frequency gets lower, to about 2Hz.
    • measuring voltage of the PFC output (C802/C807 in this PSU, C_OUT in the reference circuit) with meter (can't use 'scope - not isolated circuit)
    • PFC o/p measures 400VDC when the monitor is on (expected voltage)
    • when brightness is stable (high brightness), there is only approx 2V AC ripple on the 400V line
    • when brightness is unstable, this rises up to 25V AC. The meter has a bargraph which shows me that the AC is a slow pulsing oscillation coinciding with the backlight flicker.
    In this circuit the output power cap is two in series (C802, C807). I noticed the DC & AC voltages were quite unbalanced between these caps so I thought the caps were the problem and replaced them with nice low ESR ones, and added 100k shunt resistors. Well.. now the voltage is nice and even between the two caps but the flicker is the same
    I'm not familiar with these circuits so not sure where to check to what the cause of this is. For a start I'm not sure if the fluctuation in the PFC output voltage really indicates a problem in the PFC circuit or the load (the LED driver). I haven't worked out the circuit between the PFC and the stage which drives the LEDs. I'm also not sure how the brightness control works. Does anyone have a schematic for another monitor PSU which might be similar?
    Any suggestions on how to proceed?
    thanks!
    Re: LED blacklight flickers at low brightness, PFC output voltage unstable. Help!
    You can start by uploading good clear pictures of the boards and show how they are connected together.
    'In this circuit the output power cap is two in series (C802, C807)' Where are these caps?
    ' I'm also not sure how the brightness control works' LEDs are driven by constant current power supply, less current = less lights.
    • cmg
      • Dec 2016
      • 32
      • United Kingdom
      Thanks for the fast response Bud. The boards are the same as in
      this thread and this one. In fact i see you drew a helpful diagram of the LED driver a while ago.
      I've attached a couple of pics of my PSU board. (note:
      - wires soldered over C807 was to measure voltage on meter without holding it.
      - Cap over D803 was because C818 is a bit chipped. This is the VCC decoupling cap for I801. Didn't help.
      - pic shows replacement caps for C802, 807. I put tape on the top because they are wider than the originals and i thought may be close to the chassis. They are nichicon low-ESR ones for switch-mode PSU. 220uF/250V, same as orig.)
      In the PSU circuit I see:
      - the PFC - gives 400VDC regulated. I don't believe this is controlled by the brightness control (?). I801 is the PFC chip.
      - an LED driver circuit on the live side. Presumably chops the 400 VDC again to AC. I811 is the chip for this. Not sure what model of IC this is or how the circuit works.
      - transformers isolating the LEDs T802, T804, T805 followed by rectifiers and smoothing. There are 3 transformers and 6 DC outputs to the LEDs. No further control circuitry on this side of the transformers - just a rectifier.
      What i meant was that I'm not sure how/where the front-panel brightness control adjusts the LED current. The control comes into this board as a voltage level in the range 0-5V - i checked that.
      I have observed the 6 LED strips with a scope and i see that the voltages all oscillate the same. Hence, i thought the problem was further upstream, and not the smoothing in this final stage. See pic for scope trace. It shows the oscillation is a pulsing effect. This is @ 50ms/div so its about 10Hz at the time the pic was taken.
      Thanks!
      • cmg
        • Dec 2016
        • 32
        • United Kingdom
        Ah.. made some progress. The controller IC I811 is a TI 25600 type, so now i can see that this is where the brightness control is implemented.
        However, the whole circuit (PFC plus this DC-DC converter) will all be pulsing so I'm not sure how best to work out where the cause is.
        Thanks!
        • cmg
          • Dec 2016
          • 32
          • United Kingdom
          .. bit more progress.
          Firstly i looked at the AC output of the transformers which are driven by the DC-DC converter. When the monitor becomes unstable, the frequency is modulated and ultimately drops out. It starts off at about 150kHz. Because the frequency is unstable my view is that the problem is in the DC-DC converter or its control.
          I traced the control through the Opto-Isolator I812. This in turn is controlled by another TI chip - I810, a Z103WA. This is a dual op-amp with a voltage reference inbuilt. I guess the reference circuit in the datasheet is going to be similar to what is used here.
          The input to the Opto Isolator I812 IS oscillating (i.e. at around 10Hz) when the monitor is unstable.
          Next i think i will interrupt the feedback from the regulated output voltage to I810/I812 and see if that stops the instability. Maybe it will give some clue as to where it is starting. I suppose it means I need to trace the circuit around I810 as well... I won't have a chance to proceed for a week though.
          In the meantime if there are any ideas.. much welcome.
          • cmg
            • Dec 2016
            • 32
            • United Kingdom
            Finally! Got it
            It was the PFC controller IC. Will post some details later.
            • Alimash
              op amp circuit function?
              by Alimash
              I am repairing a ups which doesn't turn on ,it has the following ICs:
              SG3525 used to drive inverter mosfets.
              couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
              A LM358 and TL074 for control mechanism and of course the uController.
              The SG3525 is shutting down every time the ups is turned on.
              I want your help to know the function of LM358 and TL074 in the system.
              I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
              07-31-2025, 07:45 AM
            • Astonished
              Fixing the Charge Circuit of the Batteries of the DC Motor
              by Astonished
              Hi friends of electronics
              What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
              The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
              Please help me fix this circuit.
              (the datasheet of the IC: https://pdf.datasheet.live/28...
              01-28-2025, 06:24 AM
            • rddube
              Lenovo L490 Ram voltage circuit malfunction
              by rddube
              Hello friends,
              Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
              I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
              07-15-2025, 04:41 PM
            • Tarot Superstars
              Short Circuit tester
              by Tarot Superstars
              Hello.
              I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
              The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
              Link
              The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
              https://www.youtube.com/watch?v=0eixDdCpiO4
              My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
              09-25-2023, 09:11 AM
            • M1NEBLANK SHOW
              MSI B250 Gaming M3 Short circuit in CPU power supply circuit
              by M1NEBLANK SHOW
              Hello. MSI B250 Gaming M3 board, short-circuit on the power supply. Found a problematic mosfet VQ1
              (N-PK616BA_PDFN8-HF) soldered it out - short circuit is gone. I replaced VQ1 + VQ5 (N-PK632BA_PDFN8-HF). VQ1 was replaced with PK618. After starting attempt VQ1 is lit again. What can be the problem? In the driver?
              Schematic and Boardview here
              04-04-2025, 03:57 PM
