Study R8A66983BG
  • capwizard
    • Jun 2016
    • 1991
    Study R8A66983BG
    System on a chip SoC : R8A66983BG
    A system on a chip or system on chip (SoC or SOC) is an integrated circuit (commonly called a "chip") that integrates all components of a computer or other electronic system. It may contain digital, analog, mixed-signal, and often radio-frequency functions—all on a single substrate. SoCs are very common in the mobile computing market because of their low power-consumption. A typical application is in the area of embedded systems.
    The contrast with a microcontroller, SoC integrates microcontroller (or microprocessor) with advanced peripherals like graphics processing unit (GPU), Wi-Fi module or coprocessor.
    A typical SoC consists of:
    a microcontroller, microprocessor or digital signal processor (DSP) core – multiprocessor SoCs (MPSoC) having more than one processor core
    memory blocks including a selection of ROM, RAM, EEPROM and flash memory
    timing sources including oscillators and phase-locked loops
    peripherals including counter-timers, real-time timers and power-on reset generators
    external interfaces, including industry standards such as USB, FireWire, Ethernet, USART, SPI
    analog interfaces including ADCs and DACs
    voltage regulators and power management circuits
    A bus – either proprietary or industry-standard such as the AMBA bus from ARM Holdings – connects these blocks. DMA controllers route data directly between external interfaces and memory, bypassing the processor core and thereby increasing the data throughput of the SoC.
  • capwizard
    • Jun 2016
    • 1991
    Re: Study R8A66983BG
    Most SoCs are developed from pre-qualified hardware blocks for the hardware elements described above, together with the software drivers that control their operation. Of particular importance are the protocol stacks that drive industry-standard interfaces like USB. The hardware blocks are put together using CAD tools; the software modules are integrated using a software-development environment.
    Once the architecture of the SoC has been defined, any new hardware elements are written in an abstract language termed RTL Register-transfer level which defines the circuit behaviour. These elements are connected together in the same RTL language to create the full SoC design.
    With the growing complexity of chips, hardware verification languages like SystemVerilog, SystemC, e, and OpenVera are being used. Bugs found in the verification stage are reported to the designer.
    In parallel, the hardware elements are grouped and passed through a process of logic synthesis, during which performance constraints, such as operational frequency and expected signal delays, are applied. This generates a logical netlist which is a file describing the circuit as a collection of connected silicon gate elements from a library provided by the silicon manufacturer.
    • capwizard
      • Jun 2016
      • 1991
      Renesas Electronics Corporation (ルネサス エレクトロニクス株式会社 Runesasu Erekutoronikusu Kabushiki Gaisha) is a Japanese semiconductor manufacturer headquartered in Tokyo.
      It has manufacturing, design and sales operations in around 20 countries. It was the world's largest auto semiconductor maker in 2014, and the world's largest maker of microcontrollers. It also makes mixed-signal integrated circuits and system on a chip semiconductors.
      Renesas Electronics Introduces Industry's Smallest SoCs for LCD Digital TVs with Full HD Support for the North American Market...........How about now?
      TOKYO, November 16, 2010 — Renesas Electronics Corporation , a premier supplier of advanced semiconductor solutions, today announced the availability of two new compact and power efficient system-on-chip (SoC) products, the R8A66983BG and R8A66980BG, that integrate in a single package the main signal processing functions, such as video and audio processing, and high-picture quality required in LCD digital TVs for the North American market. The R8A66983BG SoC supports full HD, and the R8A66980BG SoC supports WXGA.
      Renesas Electronics currently mass produces the R8J66977BG (with full HD support) and R8J66975BG (with WXGA support) SoC products for LCD digital TVs for the North American market. These SoCs integrate on a single chip the main signal processing functions and high-picture quality, from demodulation of the digital broadcast signal to signal output to the LCD panel, enabling more compact product design and also reducing the number of external memory (DRAM) chips required from two to one, due to their powerful processing capability. These SoC products also effectively lower the total system cost. And now, Renesas Electronics' new R8A66983BG and R8A66980BG SoCs deliver greater miniaturization while reducing both cost and power consumption even further.
      Main features of the R8A66983BG and R8A66980BG:
      Industry's smallest SoCs for LCD digital TVs with full HD support for the North American market
      By fabricating these SoCs with a 45-nanometer (nm) process, it is possible to reduce the package size from 23 mm x 23 mm to 17 mm x 17 mm while retaining the functions of the earlier products for which they are the successors. The R8A66983BG device is the industry's smallest SoC for full HD LCD digital TVs for the North American market. This makes it possible for the system boards used in the televisions to be more compact, thereby requiring less space within the design.
      pic4 : Yes It is the Japan's R8A66983BG : RCA 55120RE010C878LNA0-A1 Main Board for LED55C55R120Q
      • capwizard
        • Jun 2016
        • 1991
        R8A66983BG Applications
        RCA 50LB45RQ
        https://cdn.badcaps-static.com/pdfs/...b5abe81061.pdf
        Sanyo DP19241
        • BOSCHNJAK
          by BOSCHNJAK
          ABOUT ME INTRODUCTION FILE
          2
          024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
          2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
          2022 BEV, PROJECT ?
          2021 BEV, PROJECT ?
          2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
          2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
          12-28-2023, 02:09 PM
        • wolf1976
          is there any univarsal wifi motherboard that supports and digital tvs ?
          by wolf1976
          hi i want to convert my simple digital tv because the motherboard is dead to wifi motherboard but with the ability has and tuner for digital channels DVB-T compatible in europe
          is there ?
          do you have to suggest me one ?
          thanks on advance...
          01-05-2025, 04:29 PM
          Allwinner H5 Quad-Core OTT Box Processor Datasheet
          The Allwinner H5 is a highly cost-efficient quad-core OTT Box processor, which is a part of growing home entertainment products that offer high-performance processing with a high degree of functional integration.
          The H5 processor has some very exciting features, for example:
          • CPU: Quad-core ARM CortexTM-A53 Processor, a power-efficient ARM v8 architecture, it has 64 and 32bit execution states for scalable high performance ,which includes a NEON multimedia processing engine.
          • Graphics: The hexa-core ARM Mali450 GPU including dual Geometry Processors(GP)...
          10-23-2024, 02:24 AM
        • mon2
          A2141 Not powering on - case study
          by mon2
          This is a case study on a 'sudden death' A2141 unit brought in for service.
          USB-C meter is @ 5v with ~0A current draw.
          a) Disconnected battery. No power to the machine. Applied the Qianli Tail tester with the USB-C connector. Each USB-C power connector was green with the diode mode of testing. CD321x are not defective as originally thought.
          b) PPBUS_g3h is not shorted but is a low voltage due to the low INPUT voltage of 5v being boosted. On a random power up attempt, PPBUS_g3h was at the expected 12v63 range AND input voltage was observed to be @ 20v for...
          07-10-2025, 10:58 AM
        • dreamlayers
          Weird clipping on Logitech Z-10 speakers
          by dreamlayers
          I bought used Logitech Z-10 computer speakers. They can act as a USB audio device or accept line input, and they have a headphone output jack. Some music didn't sound right, so I played a frequency sweep and heard other frequencies and beat frequencies between them and the sweep. I uploaded a spectrogram of a frequency sweep. From the very start, some but not all odd harmonics are visible, indicating symmetric distortion. Then at higher frequencies there are descending images of those harmonics, indicating non-linearity and constant higher frequency noise mixing with the harmonics. The image of...
          05-22-2025, 11:41 AM
