Sharp LC-40LE550U no Backlights due to bad connector
    I fixed this 2/6/2016, the connector for the LED strip PCB just came off the solder pads.
    • Jul 2011
    • 6037
    Re: Sharp LC-40LE550U no Backlights due to bad connector
    Now this is some real s**t for a TV set to be this new and you have to be fix already ---> really
    Do they make any thing good any more
    Did they at least use a good brand of caps in this TV set
      I fixed it in 2/2016 but I do not know what year it is built.
      • Eugenio1991
        • Aug 2017
        • 15
        • Monterey
        How did you open the LCD ? I've try to get to those parts and it's very difficult. Do you have a Guide?
        • Doc38343
          • Apr 2015
          • 402
          No specific instructs but they are all very similar and do not mix up the order of the diffuser sheets.
          Here are many videos on the subject.
          https://www.youtube.com/results?sear...ed+strip+in+tv
          • Eugenio1991
            • Aug 2017
            • 15
            • Monterey
            Thank you Doc38343.
            I was able to take it apart but none of the led's turn on.
            How could I test the power supply for this tv?
            When I plug it in a get the green light indicator but no pic or sound and no back lights .
            Any help will greatly be apriciated.
            • attainteddragon
              • Apr 2013
              • 764
              • australia
              you might be best off starting a new thread on your tv.
              you will need pics of the rear, without the back cover on and pics of each board and it will start things off quickly if you can also list the voltages on the wiring connector that runs to the main board.
              list it as
              pin no, pin desc, v in stby, v when powered on.
              we can then start guiding you where to look and what to test.
              WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
              • Eugenio1991
                • Aug 2017
                • 15
                • Monterey
                Will do.
                Thank you
                • pauldow
                  • Oct 2012
                  • 92
                  • US
                  I came across one of these too. Had the image on the screen if the flashlight was shining on it. I opened up the panel as you suggested, and two of those connectors linking the LED strips fell off in my hand.
                  Resoldered them, got it back together, and it lights up!
                  See, I do search here before posting a question. :-)
                  Thanks again.
                  Paul
                  • Tomylee
                    No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
                    by Tomylee
                    Hi everyone,
                    Sorry for the person who’s going to read all this !
                    I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
                    While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
                    During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
                    07-11-2025, 11:52 AM
                  • htv239
                    LG UH8500 Backlight Troubleshooting Help
                    by htv239
                    I am currently troubleshooting an LG 60UH8500 TV (2016 TV). Any help or suggestions would be appreciated.
                    Overall Issue: When TV is turned on, backlights all come on for about 10 seconds, then all go out. There is sound and there is a picture on the display (obviously hard to see without backlights, but it is there).
                    What I Have Done So Far: 1) Removed the back TV cover to expose the boards (Power Supply, Tcon, and Main), 2) blew out any dust and cleaned all connections, 3) Noticed that the LED backlights are fed from two separate connectors...
                    10-11-2021, 01:53 PM
                  • 5mall5nail5
                    Help identifying connector for ASUS 4090 Strix RGB LED connector
                    by 5mall5nail5
                    Hi All -
                    I had replaced my ASUS 4090 Strix cooler with a waterblock and put the stock cooler on the shelf. Was moving it and snagged my sweater on the connector and pulled the wires out of the pins on the RGB connector. I tried to get them back on but its too small so I opened the stamped pins and tried to solder but its not a good repair and the wire broke on reinstallation.
                    Looking to replace the connector on the cable side and get pins to crimp onto a new cable. Bought random JST and such but nothing is correct. Can anyone help identify the connector and possibly matching...
                    05-04-2025, 07:47 AM
                    LENOVO S510 + Office 2016 Home & Business i5-6400 Specification for Upgrade or Repair
                    This specification for the LENOVO S510 + Office 2016 Home & Business can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the S510 + Office 2016 Home & Business boardview and S510 + Office 2016 Home & Business schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                    09-12-2024, 01:58 PM
                  • bussincaps
                    MacBook Pro Mid-2014 A1398 Retina LED Controller Connector [First Repair (Disaster)]
                    by bussincaps
                    Hello All,
                    tl;dr: minimal electronics experience and my first repair, lifted 8 pads off the laptop display LED controller board when attempting a connector replacement, options are attempting pad repair or jump wiring.
                    Laptop Model: MacBook Pro 15 Mid-2014 Retina, A1398 MGXA2LL/A
                    eDP Display: Samsung LSN154YL01-A02, assembly sold as Apple part 661-8310
                    Soldering Equipment: Hakko FX-888D w/ T-18 tips (Chisel, Conical, Bevel types)
                    I needed to replace the 30-pin I-PEX Cabline connector (labeled J8300 in the Apple 820-3662 mainboard schematics),...
                    08-03-2023, 12:57 PM
