Panasonic Plasma TH-P46U20A - dead
  • tw2005
    • Oct 2011
    • 6458
    Picked up a cheapy Panasonic Plasma TH-P46U20A.
    Symptoms- dead, no LED, no relay clicks etc. My expectations were this could be mainboard failure.
    Found no standby voltage, and no input A/C voltage on D501 standby rectifier.
    Fuse F501 T2AH250V was open. ( Panasonic # HU215002BEP )
    I did a quick probe around the standby cct and found nothing shorted so hoping it was a surge gave it the benefit of the doubt and pulled a fuse off a spare board.
    Powered it up and there was light arcing around the area of IC501, the fuse blew. Double checked and still no dead short but pulled the board right out looking for burns.
    In the shadows under IC501 I could see a bit of black between pins 2 & 3. So i pulled this IC out and also out of a good board. Between 1 & 2 the resistance was about the same, between 2 & 3 on the clean one it was 7 - 8 meg, on this sooty one it was about 2kohms.
    So I cleaned it up with acetone and scrapped off any residue and it changed to being 7-8meg again. So the IC MIP3E50MY (marked MIP3E5MY) had not blown just the casing had become conductive.
    I can only guess at the cause , either dust build up or even an insect got in there and burnt causing carbon tracking.
    So replacing the fuse, I swapped an IC into it from another board and it's all good.
    I've sleeved the legs with heatshrink on the old one and when I get some fuses I'll test it out.
    Also I believe these color banded fuses the OEM brand is SkyGate Co Japan, Littelfuse have a similar spec product.
    SG5063 series number 002 or SG5063002 for the 2Amp
    Littelfuse 0215002.MXEP, 0215002.MXESPP
    For a 2010 model, hardly used at 4400hrs. Not a bad picture too for an entry level FHD. This has the TNPA5105 SC in it.
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Panasonic Plasma TH-P46U20A - dead
    Good job! It's a nice tv.
    • BigPete
      • Jul 2012
      • 76
      • New Zealand
      Just thought I would add to this.
      I had similar problems with a TH-P46U20Z.
      Power supply board number is ETX2MM805MEH.
      TV was completely dead, no 5v Standby.
      No shorts or open fuses, nothing.
      Swapped in a similar power supply and the TV fired up.
      Replaced IC501 with a MIP3E40MY. No response.
      On a whim, I replaced all 5 optocouplers, PC501, PC502, PC504, PC201 and PC202 with some ET1102's, https://www.mouser.com/Optoelectroni...keyword=ET1102
      Installed board and TV fired up.
      Uninstalled board, replaced IC501(MIP3E50MY) with the original and reinstalled the board and TV failed to turn on.
      I have a MIP3E70MY on order.
      Very happy!!
      • badcappo
        Dead Panasonic Viera TX-P65STW50 Plasma TV
        by badcappo
        Hello, got a ST50 plasma TV for repair. No signs of life, not even blink codes. Opened it up to check the power supply, type MPF6914. Apparent issues from visual detection and measuring for shorts:
        Diode type G972s6 - D101 with a short
        Mosfet 06N90E - Q301 shorted
        Fuse T5AH 250V - F103 blown
        Diode D301 shorted
        Relay DG1U-17VDC II - RL001 blown
        I have not found a circuit diagram. Maybe someone here already dealt with a similar issue? Thanks for tips where else to check 😀...
        11-24-2024, 11:27 AM
      • jm1234
        Panasonic plasma TX-P42ST50 - 6 blinks
        by jm1234
        anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
        It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
        I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
        I checked that board for any obvious faults...
        05-22-2024, 06:59 AM
      • stecos
        Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
        by stecos
        Hi everyone!
        I happened several times, in the search for help from the web, to consult this very interesting forum.
        So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
        Having said that I come to the gist of my post on the forum as the title suggests.
        For my passion for technology I'm now collecting several...
        11-28-2022, 11:39 AM
      • cloo
        Panasonic ZT60 plasma tv with strange behavior and 8 blink code
        by cloo
        I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
        It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
        So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
        After doing a factory reset this problem was gone and the picture was back to...
        01-06-2025, 06:02 AM
      • Alicat
        Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
        by Alicat
        Stopped by this site trying to fix my parents Panasonic Plasma TV.
        Model number is TH-50PZ85U
        Power comes on and the red power light stays on solid.
        Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
        I also hear a few clicks.
        I also think my parents said there was a thunderstorm and the TV failed after that.
        Section 6 in the service manual talks about power and no screen,...
        10-30-2024, 10:09 AM
