Removing "Yellowing" From Beige Case Plastics
This is a sticky topic.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    I've been trying experiments with some 'household remedy' chemical yellowing removal, and after a few tries, I found a winner!!
    Before:
    After:
    More to come as I refine this process.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • keeney123
    Lauren
    • Sep 2014
    • 2536
    Re: Removing "Yellowing" From Beige Case Plastics
    That worked good.
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      Ive been on this trail too. Old vintage Mac keyboards and Model M/F PC boards
      What is your current process?
      Follow the white rabbit.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        https://en.wikipedia.org/wiki/Retr0bright
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16959
          Knew all about retrobrite....the home remedies are the same thing for pennies. Oxy-based cleaners.
          Team : 49813
          Join in!!
          Team Stats
          • junktv
            • Nov 2010
            • 3065
            TSP (trisodium phosphate) and dawn or any household cleaner spray works ok. Always alcohol but it can be hard on the painted stuff.
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              this is not nicotine build up.
              its yellowing from bromine based flame retardant.
              • junktv
                • Nov 2010
                • 3065
                My bad I was just speaking from experience.
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16959
                  I think I've found my happy place!! I tested it on the worst case I had, came out looking new!!
                  Before:
                  In progress, in my super duper bromine yellowing reversing soup...
                  some other whatnots added with this batch.
                  After:
                  I'll post up the ingredients soon. I don't have proportion measurements yet, as its still kind of experimental....but I have the ingredients narrowed down after a few weeks of experimenting...
                  Team : 49813
                  Join in!!
                  Team Stats
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    Nice work I wonder if the ingredients will be available in the uk ?
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16959
                      It's all grocery store items, nothing crazy, illegal, or hard to find.
                      Team : 49813
                      Join in!!
                      Team Stats
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        Cool, I look forward to the recipe.
                        • Topcat
                          The Boss Stooge
                          • Oct 2003
                          • 16959
                          Ok, time to let the cat out of the bag. Here's the key ingredients:
                          1) Oxy-based detergent
                          2) Hydrogen Peroxide
                          3) Water
                          4) Intense UV source (sunlight can't be beat)
                          I've tried quite a few oxy-based cleaners, this was the best one. This one (unlike most) doesn't foam up. If there's a layer of foam floating on the surface, it blocks the sunlight. Strong UV is the catalyst that makes the whole process work. The hydrogen peroxide is introduced to speed up the process. The process works without the peroxide, but it takes a long time and will require a few treatments if its really yellowed. The 'soup' loses its potency after about 5~6 hours, and 6 hours in direct sunlight with this combination will do the trick. This nasty yellow enlight case was restored after just one 6hr treatment. Other similar yellowed items took 3 to 4 treatments without the peroxide, so its definitely a key ingredient.
                          Unlike 'retr0brite', which is more of a paste, and has to be reapplied when it runs off or dries out in the sun, the 'soup' works far better....and costs almost nothing. You just have to keep things submerged, which is why the rocks are there. You just have to shift them around periodically so to not get shadowing. Around 5~6 hours, you will notice its not bubbling/fizzing anymore, that's when you know the magic is all gone, and its time to remove & rinse off.
                          Ok, so the process is pretty simple. Mix the detergent with warm water in a pan and then add the peroxide, then place your items in the mixture yellowed side up. Then place it in direct sunlight for 6 hours. You may need to place heavy objects on the items to keep them submerged. If you do, be sure to rotate the heavy objects every so often so to not get shadows. That's basically all.
                          I am still working on proportions, I don't have measurements per gallon of water ratios yet....its like my spaghetti sauce, I add until it 'feels right'...but use generous portions of the detergent & peroxide.
                          The final pics of the yucky enlight case after I cleaned up the rest of it:
                          Nice home for a VP6
                          Where did this come from?
                          That's all for now...
                          Team : 49813
                          Join in!!
                          Team Stats
                          • Topcat
                            The Boss Stooge
                            • Oct 2003
                            • 16959
                            The case of the left....
                            Before:
                            After:
                            I love it when a plan comes together!
                            Team : 49813
                            Join in!!
                            Team Stats
                            • junktv
                              • Nov 2010
                              • 3065
                              Seems like we need a paper mache volcano for this.
                                • 31283
                                so it's Hydrogen-Peroxide and Baking Soda ?
                                • Topcat
                                  The Boss Stooge
                                  • Oct 2003
                                  • 16959
                                  its not sodium bicarbonate (baking soda), its sodium carbonate (aka soda ash)....which is the key in oxy-based cleaners.
                                  Team : 49813
                                  Join in!!
                                  Team Stats
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8706
                                    The need for UV is weird, as I thought it was the UV that caused the damage to begin with?
                                    How about using a blacklight? Or does it need to be of the germicidal type?
                                    What happens if you simply heat the solution instead of using UV light?
                                    • Topcat
                                      The Boss Stooge
                                      • Oct 2003
                                      • 16959
                                      The UV is the catalyst, so I understand from the people that know more about chemistry than me. Without the UV, the above described formula is useless. Blacklight did nothing. I did try a 400W metal halide 'grow light', that worked, but was slow going. the UV has to be extremely intense, sunlight is best. Ironic that yes, UV caused the yellowing (bromine offgassing) in the first place....and UV with the 'soup' will undo the damage.
                                      Team : 49813
                                      Join in!!
                                      Team Stats
                                        • 31283
                                        i wonder if a sunbed would work?
                                        that or - on a smaller scale, a germicidal tube from my eprom eraser.
                                          ASUS E410MA-BV190TS-CASE Notebook Specification for Upgrade or Repair
                                          This specification for the ASUS E410MA-BV190TS-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E410MA-BV190TS-CASE boardview and E410MA-BV190TS-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 10:50 PM
                                          ASUS 571GT-AL188R-CASE Notebook Specification for Upgrade or Repair
                                          This specification for the ASUS 571GT-AL188R-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 571GT-AL188R-CASE boardview and 571GT-AL188R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-06-2024, 11:05 AM
                                          ASUS X712FA-AU306T-CASE Notebook Specification for Upgrade or Repair
                                          This specification for the ASUS X712FA-AU306T-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X712FA-AU306T-CASE boardview and X712FA-AU306T-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          ASUS VivoBook X712FA-AU311R-CASE Notebook 17 Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook X712FA-AU311R-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X712FA-AU311R-CASE boardview and X712FA-AU311R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          ASUS ZenBook UX461UN-E1042R-CASE Hybrid (2-in-1) Flip Specification for Upgrade or Repair
                                          This specification for the ASUS ZenBook UX461UN-E1042R-CASE Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX461UN-E1042R-CASE boardview and UX461UN-E1042R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-06-2024, 07:07 AM
