please help me i need bios dump Apire es1 131.. ty
Apire es1 131 bios
Re: Apire es1 131
backup the old one, try this...(bios voltage 1.8v)Attached Filesif you find these attachements useful please consider making a small donation to the site
by AhariHi all,
I...-
Channel: BIOS & Schematic Requests!
by mkdjDear all,
I have a ASUS ZenBook UX480F with the following symptoms:
I suspect it is a BIOS issue. So I decided to try to clean the ME region. I followed the guide on win-raid, and I believe I have done everything correctly. My problem is: when I open the outimage.bin in ME Analyzer, it says that it is Extracted, and not Region, Extracted as it should be. Is it normal, or did I do something not correctly? This is my first experience editing BIOS files.
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
Troubleshooting Attempts:
Channel: Troubleshooting Computer Displays
Hello engineers 😀,
I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
🔧 Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
- EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
💀 Problem:😅
- Device shows “Administrator Password”...2 Photos-
by CityminHi all,
My Samsung Galaxy Book 2 Pro 15.6-inch laptop has no display and won't boot.
The charging red LED lights up, but the charging screen doesn't show any indication.
When I press the power button, the blue LED cycles on and off three times, then the screen doesn't turn on, and the device won't boot.
(I've tried removing the battery and resetting the device, but the issue persists.)
NoteBook Model name : Samsung NT955XED-KK51G(Galaxy book2 pro, i5-1240p, 15.6inch AMOLED)
PCB model name : Venus2-15-5G(REV1.2), Venus2-15 ADL NPC
S/N : 5RNK9FFT70...-
- Loading...
- No more items.
