TC-P50S30 TNPA5351 has failed twice in three days.
  • johnboy1313
    • Nov 2012
    • 1959
    I repaired this set a few weeks ago by replacing three 30f131 fets and sold it. After three weeks, it quit again. I opened it up and found the same three fets were shorted. I replaced them again and this time, used screws from an older Panasonic with lock washers when installing the SC. The owner picked it up around 9:00 last night. At 10:00 last night, I got a text saying it had blown again.
    Any guesses as to what I could be missing?
  • tw2005
    • Oct 2011
    • 6458
    Re: TC-P50S30 TNPA5351 has failed twice in three days.
    I don't have any great suggestions but which 3?
    The One I did needed 4 30F131. Q402,403,422,423
    • martino
      Not so "senior"
      • Aug 2013
      • 997
      • canada
      Replace all 4 : Q402,403,422,423 and also D401,421. And measure R402,403,422,423. Can't remember ohms on those but compare the 4 to each other?
      Edit: lol @ TW2005,you beat me to it again,haha
      Proud owner of dozens of broken TV's and many,many,many boards.
      Our website and passion:http://hollenhundshepherds.com/
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        All solder the SC power wires directly to the Pcb after replacing all 4 again.
          Why?
          • johnboy1313
            • Nov 2012
            • 1959
            If I remember correctly, if you are looking at the board, installed in the TV, it was the row of fets closest to the connector. The bottom one, the next one up, and the first one above the two diodes. I don't remember their location names.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Originally posted by tom66
              Why?
              Check Ali E's thread about possibly causes of failure for these and other S/C boards.
                You should always replace the transistors in the lower half when replacing the upper half.
                • Alastair E
                  Chief Womble
                  • Mar 2013
                  • 1963
                  • U.K.
                  Why?
                  Because I killed an SC in a 42" by merely Touching the cables and causing the (cruddy) two-pin plug to arc...
                  I solder directly all Panasonic SC and SS boards power-supply cables now, Both Ends ...
                  TELEFIX
                  • HI-ZEES
                    • May 2016
                    • 3
                    • NIGERIA
                    hello good day every one am new, don't really know where and how to post here but i would appreciate if someone will guide me.
                    here is my challenge
                    my hp elitebook 8440p core i5 flashes power light 8 times but refuses to on have tried doing a lot of troubleshooting like ready IC, capacitors, charging charger, memory etc. but still will not on. pls i need help
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      I think you have messaged the wrong forum.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Also doubt its a transistor fault, even if one was leaky they would blow instantly so something eles must be blowing them.
                          Hm, I always thought the connectors were decent - perhaps the contacts were worn from previous arcing events or something of that sort.
                            This isn't necessarily true as it's more than possible that a transistor could be wounded early on and then fail later. The energy dumped into it by a short circuit could cause damage to the die that may not show up on any tests except by using an electron microscope - so *always* replace the other transistor in any half-bridge.
                            • johnboy1313
                              • Nov 2012
                              • 1959
                              Already ordered the kit. I'll replace all four fets, and the two diodes and probably the four resistors as well.
                              • tw2005
                                • Oct 2011
                                • 6458
                                yeah , I'd do the 4 like Tom suggests. That's the same banks I replaced but did the 4 and I also used FGD4536 which are smaller package Dpak and it's been good for 18 months now.
                                • johnboy1313
                                  • Nov 2012
                                  • 1959
                                  Got the kit in yesterday and installed the whole 13 piece kit this evening. I even soldered the cables on both the SS and the SC. it just popped again. Time to part this one out. I'm done.
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    Tragic. Economic loss . It would bug me not knowing the cause. Thankfully the wins outweigh the losses. Know the feeling. I'm on day 4 on a 4782 . No worky no smoke 7 blink
                                    • ahmedtou
                                      HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                                      by ahmedtou
                                      Hi everyone,
                                      help me please
                                      I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                                      When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                                      I will share all the details with you, including the disc information.
                                      Code:
                                      HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                                      Current Profile: BD-R
                                      Disc Information:
                                      Status: Empty
                                      State of Last Session: Empty
                                      Erasable: No
                                      Free Sectors: 12,219,392
                                      Free Space: 25,025,314,816 bytes
                                      Free Time: 2715:27:17 (MM:SS:FF)
                                      Next
                                      08-27-2025, 08:49 AM
                                    • paparazzo79
                                      HDD in external enclosure failed, may I use external enclosure with other HDD?
                                      by paparazzo79
                                      Hello.
                                      I own Seagate Expansion drive which for me unknown reason has failed yesterday.When connecting to PC I am getting access denied message and whole partition in Disk Managment is in RAW format.
                                      So I dismantled the case thinking I may use the inside HDD as internal sata device in a computer but even like that I am getting access denied message.
                                      The drive is Sagate Exos.
                                      My question is may I use the enclosure with other internal drives (I own 3 internal 3.5 inch WD drives with 13TB capacity)?
                                      I mean maybe that is even not advisable since electronic card (from pic...
                                      10-28-2025, 01:01 PM
                                    • Lostdotfish
                                      KZG caps failed on a NOS motherboard - never been used...
                                      by Lostdotfish
                                      This is a new one on me. I picked up a new old stock DFI 865PE Infinity board recently. It's completely new, never used. While inspecting it I noticed some unexpected bulging caps...
                                      All of the 6.3v 1500uf caps had failed in place, despite the board never seeing use and being stored sensibly. I pulled the 16v caps that are the same series as a precaution and will replace them all.
                                      10-15-2025, 04:29 AM
                                    • modtool
                                      Lenovo Legion 5 15ARH05H, NM-D281 Rev 1.0, "BIInitializeLibrary failed 0xc0000185" and bios freezing
                                      by modtool
                                      Dear members,
                                      I have a problem with this machine that still I can't solve, I hope some of you can suggest me something.
                                      I was the first one to open the machine and touch the mainboard, in fact the Lenovo seal was intact the first time that I unscrewed all the internal screws.
                                      The ower told me that it was working very good until Windows kicked "something like a firmware update" (owner's words) then the system started acting weird.
                                      When you try to start it, some seconds after having pressed the power button, Lenovo splashscreen appears, then after 1 second, in the...
                                      01-15-2024, 08:56 PM
                                    • gurj1979
                                      Surface Laptop 1769 SSD Failed KUS040202M-B000
                                      by gurj1979
                                      Hey guys,
                                      I've got a Surface Laptop 1769 (the nasty cloth type palmrest) which has a failed 512GB Samsung PM971 (KUS040202M-B000).
                                      These are on BGA291, but I don't know which is equivalent to KUS040202M-B000.
                                      AliExpress has this but it's expensive.
                                      Can anyone help me find a reasonably prices equivalent which I can use as a replacement ?
                                      Or which NVMe can I remove it from ?
                                      02-17-2025, 04:02 PM
