Toshiba led tv 32P2305EE won't turn on
  • Nasha
    • Mar 2016
    • 25
    • Riyadh saudi arabia
    I hope you cant help me guys.
    I have this unit a year sens i purchase it. last 3 days ago it wont turn on even
    in manual start. he have a standby light indicator solid red and its also a 5v stand voltage. could you give me guys a suggestion if what parts it could be damage or what testing procedure i cant do to rectify the problem.
    Thanks,
  • TVRepairNoobie
    • Feb 2015
    • 158
    Re: Toshiba led tv 32P2305EE won't turn on
    Video below may get you started
    ShopJimmy Tech Video (Samsung LED TV Won't Turn On No Power & Does Have a Standby Light Basic Troubleshooting TV Repair)
    https://www.youtube.com/watch?v=T6FmYo1fACk
    • Nasha
      • Mar 2016
      • 25
      Thanks for the info.
      • Nasha
        • Mar 2016
        • 25
          Uploading good clear pictures of the boards and the whole back side of the TV so we can see how all the boards are connected together will be a great help for troubleshooting your TV.
          • Nasha
            • Mar 2016
            • 25
            This is the power supply board and main board
            Thanks.
            • comptek
              • Aug 2013
              • 606
              • uk
              well bugger me not vestel
                https://www.badcaps.net/forum/attach...6&d=1458575881
                Pictures is too out of focus to read the pin labels for the connector.
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 5096
                  • New Zealand
                  Can we get a closeup photo of the white 15-pin connector on the left side of the PSU board, next to the yellow capacitor? Need to see what the labeling is for those pins.
                  -David VanHorn
                  • Nasha
                    • Mar 2016
                    • 25
                    Apologize for the bad resolution of the picture.
                    I gonna try to send today a clear picture and also
                    For the 15 pin terminal.
                    • Nasha
                      • Mar 2016
                      • 25
                      Good day.
                      This is the clear copy picture psu board and
                      Symptoms
                      • Nasha
                        • Mar 2016
                        • 25
                        I found 2 diode supplying 5v was already. 1v
                        When I test in digital tester. But when you check
                        The standby voltage still giving 5vdc
                          Please report the DCV reading of each pin foe the connector CN803 when poweer switch is activated.
                          Please report in this format so it will be easy for us to see what are missing:
                          For example
                          13V = ??? V
                          13V = ???? V
                          12V(T-CON) = ??? V
                          • Nasha
                            • Mar 2016
                            • 25
                            Pin 1 GND
                            2 13V audio= 13V
                            3 13V = 13V
                            4 12 T-CON = 12V
                            5 GND
                            6 5V = 5V
                            7 5V = 5V
                            8 GND
                            9 POWER_TV = 3.2V
                            10 DC_ON OFF= 3.2V
                            11 GND
                            13 EXTDIM = .4V
                            14 NC
                            15 NC
                              Originally posted by Nasha
                              Pin 1 GND
                              2 13V audio= 13V
                              3 13V = 13V
                              4 12 T-CON = 12V
                              5 GND
                              6 5V = 5V
                              7 5V = 5V
                              8 GND
                              9 POWER_TV = 3.2V
                              10 DC_ON OFF= 3.2V
                              11 GND
                              13 EXTDIM = .4V
                              14 NC
                              15 NC
                              OK, so it has the correct Voltages and signals with an exception of the EXTDIM of only 0.4V. You may want to turn the TV off, then put the meter probe on this pin , then turn the TV on to see if the Voltage does jump up much higher than 0.4V and then goes down to 0.4V.
                              Did you see the LED backlights even flash on for second?
                              So far it looks like what you do not have are the backlights for you to see the images on the screen.
                              BTW, please stick to this thread so we do not have to follow the progress of the repair in two threads.
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                You've missed out pin 12? BL_ON
                                  Ah, good catch!
                                  • Nasha
                                    • Mar 2016
                                    • 25
                                    Pin 12 BL_ON OFF =0V
                                    also I found out this diode who's series in pin
                                    6&7 5V when I test in diode testing I get only .1v
                                    Supose to we get is .3V to 8V correct me if I rong.
                                    • Nasha
                                      • Mar 2016
                                      • 25
                                      .8V sorry
                                        OK, the main board is not sending the signal to turn on the backlights circuits, and also the dimming command is also very low.
                                        Your standby power supply is fine otherwise you will not have the PS-ON signal.
                                          09-06-2024, 05:27 AM
                                          09-06-2024, 05:59 AM
                                          Toshiba Satellite L635-10K Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite L635-10K Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L635-10K boardview and L635-10K schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                          Toshiba Portege Z30-C Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Portege Z30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30-C boardview and Z30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                                          09-06-2024, 05:33 AM
