#1 |
Deputy dood
City & State: Berwick, PA
Line Voltage: 120VAC 60HZ
I'm a: Hardcore Geek
![]() Was a bit surprised at this one. Board is fairly recent.
P4 3.0ghz WD 160gb SATA HD PCIe video card of some type Originally shipped from Dell 8/9/2004 ![]() The Nichicon on the cap got blurred by the coil reflection. ![]() All redone in panny FM's. Original bad caps was a single 2200 6.3v and then (5) 1000uf 10v. I replaced the 1000 10v with 1200uf 10v because that was the closest thing I had in stock. PC runs great now ![]() |
#2 |
City & State: dayton ohio
My Country: U.S.A!
Line Voltage: 12vdc,120/240vac,480vac 3ph on my bench
![]() hn/hm are known bad caps.
ala gx270 boards. 100% fail rate in a year for several big customers. |
#3 |
City & State: Orangevale, CA
![]() I know there is supposed to be a date range from bad ones, but I toss out all of 'em, no matter what.
#4 |
![]() 2004? That's not recent. In terms of computer stuff, that's "considered" old and I take advantage of that to get socket 478 boards and cpu rather cheaply so I can upgrade our shop's computers from ANCIENT PII/Celeron/PIII mix. My pc was Athlon 3000+ with A7N8X in 2004 and finally replaced with Asus P5K and E2200.
Toss boards with bad caps out? You mean swap the bad caps off with new caps? ![]() Cheers, Wizard |
#5 |
Deputy dood
![]() I hear ya, wizard. But with PCI-express and SATA native on-board, it's "new" to me. I'm still running a socket A AthlonXP system for my primary. With good old AGP! And, the only way I have SATA primary HD and optical is because I bought a controller card for them.
#6 |
![]() I'm still on Socket A also. MSI boards, 400 FSB, DDR-400, AGP8x.
This is changing, as I have an E8400, GA-P35-DS3, DDR2-800 on the bench right now. I'm tinkering with the ideal fan combination for the Scythe Zipang heat sink I got for this board. It's about ready to install the OS. I have to build this machine offline, as it is replacing my primary workstation. I cannot have this machine down for a few days while I build the new one. Push/Pull arrangement. As to the Nichicons... I recap them as a matter of course. Bye, bye. I've done a number of 8400s for my clients. Both dead and preparing to die. |
#7 |
![]() I ran into the same exact situation with a Dell Precision 370 (which uses the same motherboard as the Dimension 8400) so they aren't immune to the dreaded HN(M)s either.
#8 |
Deputy dood
![]() Just got another one of these in for recap.
#9 |
![]() Whoops, I meant my P5K is my home main PC, and my work pc here is Dell Dimension 8300, yes HM cap in a row were burst. Replaced and tested with prime95 passed. Now running 2.8C.
Eventually replace that one as well. It's kind of "feeling sluggish". Cheers, Wizard |
#10 |
City & State: Nowhere Land
![]() Hi dood. I have to recap an old Dell Dimension 8400 and would appreciate a cap list if possible. The computer is in service and I don't want to shut it down until I get the parts. Thanks for any help.
Why throw it away? I might need it in the next 40 years. ![]() |
#11 | |
City & State: Halifax, NS
My Country: Canada
Line Voltage: 120VAC 60Hz
I'm a: Complete Noob!
![]() Quote:
My gaming PC: AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3) ASUS M4A77TD AMD 770 AM3 Motherboard PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel) TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2) WD Caviar Green WD20EARX 2TB 3.5" SATA HDD ASUS Xonar DG 5.1 Channel PCI sound card Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply Antec Three Hundred Mid-Tower Case Microsoft Windows 10 Pro 64-bit Microsoft Windows 7 Ultimate SP1 64-bit |
#12 |
Black Sheep
City & State: Madison, IN
![]() yeah. a board with bad caps can be fixed, a board burnt up because someone didn't replace the caps is a paperweight. and a potential fire hazard
(Insert witty quote here) |
#13 |
![]() Board Rev Cap Mfg Series uF Volt ESR Dia Len Count
02U819 - Dimension 8400 A01 Nichicon VR 470 16.0 8.0 2 02U819 - Dimension 8400 A01 Fujitsu M Yellow-K 560 4.0 8.0 12.5 5 02U819 - Dimension 8400 A01 Rubycon MBZ 820 6.3 8.0 13.0 2 02U819 - Dimension 8400 A01 Rubycon ZL 1000 6.3 10.0 14.0 1 02U819 - Dimension 8400 A01 Nichicon HD 2200 16.0 12.5 25.0 2 02U819 - Dimension 8400 A01 Nichicon HM 3300 6.3 10.0 25.0 4 |
#14 |
![]() Thank you very much bgavin, this will save me a lot of trouble. I appreciate your help. The first cap in your list, Nichicon VR 470, what is the voltage or am I just missing something? Thanks again.
#15 |
Large Marge
City & State: Kalamazoo, MI
My Country: United States
Line Voltage: 0-120VAC 60Hz
I'm a: Hobbyist Tech
![]() its 16...wait...
#16 |
![]() Oh, I think I get it now. I might be too old and slow for membership on this board. Guess the "yoke" is on me, ha, ha. Bye.
#17 |
Black Sheep
![]() its ok. too bad this forum has no table function
#18 |
![]() My Dell Dim 8400 has a cap that looks simular to the one in the picture next to the coil. It has the same specs. Can you tell me were to get the same one. I have not seen any others that look like they are bulged.
#19 |
Black Sheep
![]() brand?
#20 | |
![]() Quote:
Thread Tools | |
Display Modes | |
