Laptop totally dead, where to start?
  • bicalov
    • Nov 2014
    • 294
    • Netherlands
    I have a next Sony VPCEB2SE1/BQ which is totally dead.
    19,5V present, but no 3V and 5V.
    Can somebody explain where the voltage rail starts and goes?
  • bicalov
    • Nov 2014
    • 294
    • Netherlands
    Re: Laptop totally dead, where to start?
    measurements: page 71
    PQ1 pin 1,2,3 = 18,92v pin 5,6,7,8 = 19,44V pin 4 = 18,89V
    PQ2 pin 1,2,3 = 18,91V pin 5,6,7,8 = 0V pin 4 = 18,91V
    PQ3 pin 1,2,3 = 0V pin 5,6,7,8 = 0V pin 4 = 0V
    Where to go from here? Do I look for short in the capacitors between PQ2 and PQ3?
    • dellxps15
      • Feb 2014
      • 1598
      • italy
      pu19 check voltage at pins: 6, 14, 27, 4, 13, 28
      • bicalov
        • Nov 2014
        • 294
        • Netherlands
        Thanks for your response.
        All pins on U19 show 0V
        Only pin 28 show 0,86V stepping down to 0V in 5 seconds
        • dellxps15
          • Feb 2014
          • 1598
          • italy
          u must have short on 19volt rail somewhere..... voltage at pq69, pc187,
          check also without power supply and with multimeter if there is short on that component.
          pc187, pq69.
          • bicalov
            • Nov 2014
            • 294
            • Netherlands
            Voltage on all pins 0V
            Multimeter in diode-position: pc187 both sides 0,00
            PQ69: pin 5,6,7=0,56 pin 1=0,40 pin 4=0,90 pin 8= 0,00
            Multimeter in Ohm position: pc187 both sides 0,00
            PQ69: pin 5,6,7=3k pin 1=100k pin 4= 85k pin 8=0
            • highpulse
              i hate HP
              • May 2013
              • 1490
              • portugal
              bicalov , you must follow in charger area (schematic) the starter mosfet , it will stop in one of them , on the mosfet that stops , simply bypass to chek what is in short
              specially it will be near cpu , as they usually blow easy (ceramic caps)
              • bicalov
                • Nov 2014
                • 294
                • Netherlands
                Thx highpulse.
                I did that in the start of this thread, but which one is the starter mosfet?
                And what is the best way to check the ceramic caps?
                • bicalov
                  • Nov 2014
                  • 294
                  • Netherlands
                  Value ceramic caps:
                  With multi meter resistance to ground in Ohm
                  PC152=0,5 pc163=8 pc167=8 pc199=2k8 pc203=10k pc208=16 pc212=15
                  pc238, 239, 240,241,244 = 75
                  • bicalov
                    • Nov 2014
                    • 294
                    • Netherlands
                    I desoldered PC152, pc163, pc167, pc168, pc169 and pc171.
                    None gives a short.
                    What to do now?
                    • bicalov
                      • Nov 2014
                      • 294
                      • Netherlands
                      Tried to bypass mosfet PQ2 , burt only the ATI GPU got warm. The power supply was switching on and of and when on 2,32Awent through the board.
                      Futhermore no hot component to find.
                      • dellxps15
                        • Feb 2014
                        • 1598
                        • italy
                        check if gpu coil is shorted.
                        edit: if u can u can also put back all mosfet, remove gpu coil and see if pc power on. if yes gpu need reballed-changed with new one.
                        • bicalov
                          • Nov 2014
                          • 294
                          • Netherlands
                          Sorry, forgive my ignorance, but what is the gpu coil ?
                          • dellxps15
                            • Feb 2014
                            • 1598
                            • italy
                            inductor pl7. check if it's shorted.
                            • bicalov
                              • Nov 2014
                              • 294
                              • Netherlands
                              PL7, 8,5 ohm to ground both sides.
                              Removed PL7 of the board, no change.
                              • bicalov
                                • Nov 2014
                                • 294
                                • Netherlands
                                measured PU3:
                                pin 1 = 3,28V
                                pin 4 = 18,86V
                                pin 5 = 2,75V
                                pin 6 = 1,16V
                                pin 8 = 2,7V
                                pin 10 = 3,28V
                                pin 11 = 3,28V
                                pin 12 = 1,05V
                                pin 28 = 18,86V
                                All other pins = 0V
                                • bicalov
                                  • Nov 2014
                                  • 294
                                  • Netherlands
                                  Hey, where is everybody???
                                  • bicalov
                                    • Nov 2014
                                    • 294
                                    • Netherlands
                                    A somebody pls take a look at the following pages?
                                    page 71, short(0V) after PQ2 pin 5,6,7,8 is connected to DCBATOUT (PC128 group is ok, but shows short)
                                    page 75, short measured at PC168,169,171 and again connected to DCBATOUT
                                    page 76, short on PC152, connected to +1_5VSUS, but with PQ57 also to DCBATOUT.
                                    page 80, low resistance (8 ohm) on PC163,,167 and via PQ43 also to DCBATOUT
                                    Can you pls give me a lead how to follow up on this issue?
                                    • bicalov
                                      • Nov 2014
                                      • 294
                                      • Netherlands
                                      The DCBATOUT seems not to be the case, on page 76, the +1_5VSUS get involved.
                                      When I disconnect PL6 on the right side (PC152), the system shows some reaction.
                                      When pressing the on/off switch, the power led and the battery led light up for a moment, while the power led blinks twice.
                                      On pin 5,6,7,8 of PQ57 is 19,46V , pin 1,2,3,4, = 0V. On PQ57, all pins are 19,45V.
                                      PU13 shows pin 5 = 0V, pin 8,9,10 = 19,45V, pin 5= 0,15V.
                                      Voltages show a little reaction (0,3V) when power switch is pushed.
                                      Power switch now has 3,28V. When I put back PL6, everything 0V again.
                                      Any advise will sure be appreciated
                                      • dj_ricoh
                                        • 2073
                                        • uk
                                        you got a short to ground.
                                        trace it. Continuity test
                                        a SVF15 and SVF14 one Hour both.
                                        found a short, injected voltage and found what was bad
                                        • max-power
                                          Dell E6540 laptop completely dead after dssasembly
                                          by max-power
                                          Hi, I disassemble my laptop to replace the speakers, to access them, you have to remove everything including the heat sink and fan, unscrew the motherboard, lift it up a bit to access the speaker wire.
                                          that was not the first time I dissasemble it, i did replace the same speaker a few year ago and I repaste it last year, so I had nothing to worry about. but when I put everything back together, its completely dead.
                                          After a bit of investigating, i found one pin of the status led ribbon cable that was unglued from the cable and bend touching another pin, I bend it back at his place...
                                          03-24-2025, 08:49 AM
                                          Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                                          09-06-2024, 09:30 PM
                                          Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-06-2024, 08:47 AM
                                        • RdeveLabs
                                          MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                          by RdeveLabs
                                          To all the members here...
                                          Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                          So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                          05-05-2025, 04:59 AM
                                        • Loli Popu
                                          DELL 5590 LAPTOP DEAD AFTER BIOS WRONG FLASHED
                                          by Loli Popu
                                          Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                                          12-13-2024, 03:28 AM
