LG R410 schematic
  • ravi_1617
    YY Solutions
    • Jan 2012
    • 350
    • India
    LG R410 schematic
    Hi! this board has display external fine.
    But not on LCD .there is a flash on lcd screen.
    I need schematic
  • bicalov
    • Nov 2014
    • 294
    • Netherlands
    Re: LG R410 schematic
    This suppose to be the one
    • Grouickman
      Hofmann geodyna 6300 Wheel balancer
      by Grouickman
      Hi there,
      First, I'm not sure it's the right section to post for this type of device, but could not think of something better.
      Ok, so my son (a mechanic) bought a faulty Hofmann Geodyna 6300 wheel balancer (which appears to be mostly a re-branded Snap-on wheel balancer).
      I'm looking for any resources (doc, manuals, schematics) that would be available for this device or anyone that would have any knowledge on this particular device (or its Snap-On equivalent).
      I'm trying to diagnose the fault(s ?), but I can't find any schematic (appart from the...
      03-31-2025, 05:29 AM
    • DqMagetz
      Acer Nitro 5 AN515-54. displays on the external monitor and works fine, the issue is NO display on the internal screen
      by DqMagetz
      Good day!
      I have a customer's laptop — Acer Nitro 5 AN515-54 (EH5VF - LA-H501P). It has a display on the external monitor and it's working fine, but the issue is NO display on the internal screen. I already replaced the eDP cable and checked the LCD connector pins.
      Here are the voltage readings:
      • Input – 19V (stable)
      • +LCDVDD – 3.3V briefly, then drops to 0V
      • EDP_HPD – 3.3V briefly, then drops to 0V
      • PCH_BKL_PWM – 2.2–5V briefly, then drops to 0V
      • EC BKOFF# – 1.8V briefly, then drops to 0V
      • PANEL_OD_EN – 0.3V
      Is it possible that the EC chip is corrupted or damag...
      07-12-2025, 09:37 PM
    • corrize
      Nikon D800 camera - flash don’t work and capacitor don’t charge
      by corrize
      Hello, I'm stuck in troubleshooting…
      The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
      In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
      When I press the flash button, it's detected by the system, flash icon appear on LDC display....
      10-01-2022, 10:02 AM
    • Madoy104
      Macbook Pro A1989 - No image, working fine with external monitor
      by Madoy104
      Hi everyone,
      I have a MacBook Pro A1989 that was likely exposed to liquid. It doesn't display an image on the built-in screen, but the screen is backlit (you can't see the Apple logo or any other elements when held up to light). The laptop provides 20V and 1.5-2A, and it works fine when I use it with an external monitor. Currently, the connector for the display (J8500) is disconnected. I'm writing to ask for help in diagnosing the issue. I've heard that when the J8500 is exposed to liquid, the processor pin responsible for the display might short-circuit, and I'd like to know...
      08-15-2024, 10:01 AM
    • amuse619
      Asus G15 5980HX - 6800M - No Display on Laptop - HDMI/Display Port external monitor works fine. Fried Component.
      by amuse619
      Hello!
      Looks like I fried something when my EDP cable got squeezed on the hinge. I replaced the cable but still no display. Laptop works fine with external monitor connected through HDMI and Display Port-USB C port. I took it apart and I see a burnt component. Can anyone help me identify what this component is? I tried to use schematics for another G15 but it does not match on the amount of pins and size. I attached pictures. The component has a label on it - (21A29)
      Laptop is a Asus G15 Advantage Edition 2021 Laptop Ryzen 9 5980HX - 6800M...
      08-14-2024, 01:22 PM
