Thermaltake ATX supply goes BANG! - TR2 RX-750
  • bcstedt
    • Jun 2011
    • 59
    This is a new unit that has not been used before.
    I powered this unit on using a jumper in the motherboard connector (grn to blk) and it seemed to work OK. I hooked it up to a PC and everything seemed fine for 10-15mins (load meter was showing power draw around 80-100W) and then there was a loud BANG like a firecracker or a gun went off. PC went dead and the supply was removed for inspection.
    Initial inspection didn't reveal anything obvious but I did see a small black dot on the plastic insulator sheet underneath the main board. It appears that this mark is directly under one of the pins of the small transformer (details to follow).
    Supply shows no signs of life and the fuse seems to test OK. Any idea where to start? Pics to follow.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Thermaltake ATX supply goes BANG! - TR2 RX-750
    As the fuse is good, do you get 5v stby ?
    • bcstedt
      • Jun 2011
      • 59
      Two of these pics highlight the dark-spot on the insulator sheet. It looks like it is centered close to Q7 (on the bottom) and the 3/4 contact of the smallest transformer, L5 (top reads: EE-10-02).
      I do not see (or smell) any smoke-release point.
      http://imgur.com/a/lykEH
      • rievax_60
        • May 2012
        • 897
        • australia
        Have a close look at the 8 pin IC in the standby supply live side. It looks like a PI brand part.
        • bcstedt
          • Jun 2011
          • 59
          Just checked and I get 5.06VDC on purple (+5V standby).
          • bcstedt
            • Jun 2011
            • 59
            It certainly looks like a PI marking but it's a 7-pin (missing #3). It's a bit hard to read but it looks like:
            PI 1119
            TNY279PN
            86905C
            • rievax_60
              • May 2012
              • 897
              • australia
              Sometimes the top blows off. It looks ok then? Is there STBY 5V present?
                • 31283
                TinySwitch TNY279PN
                  • 31283
                  there is a LOT of cracked solder joints on that psu!
                  • bcstedt
                    • Jun 2011
                    • 59
                    Must be the lighting, I don't see any from here.
                    • rievax_60
                      • May 2012
                      • 897
                      • australia
                      It is going to be difficult to go much further. All I can think of for now is to check for shorted power transistors on the live side. I can see the PFC transistors paralleled near the edge. I can't clearly see where the others are.
                      • everell
                        • Jan 2009
                        • 1514
                        Measure the voltage across the 400 volt input capacitor. If it measures 166 volts, the APFC (active power factor correction) circuit is not working. If it measures about 400 volts, the APFC circuit is working. Usually, if the APFC circuit is not working, the pwm section of the 6800 chip will not work. So measure across that big input capacitor and tell us your voltage measurement.
                        Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
                        • RJARRRPCGP
                          • Jul 2004
                          • 6304
                          I definitely notice a gap in the solder joint right under R7!
                          ASRock B550 PG Velocita
                          Ryzen 9 "Vermeer" 5900X
                          Arc A770 16 GB
                          eVGA Supernova G3 750W
                          Alienware AW3423DWF OLED
                          • Stefan Payne
                            • 1267
                            Can't really help but I have a nice photo of a similar Cougar 700W thingy, hope that helps kinda...
                            • Behemot
                              • 4845
                              • CZ
                              Also check the input cap for bulging, the top is rounded. May be just the plastic but better be sure.
                              • locojack
                                • Nov 2018
                                • 4
                                • Argentina
                                Hi! I have a this model and I had the problem that one of the resistances damaged me when producing an electric arc. I wanted to ask you if you can give me the value of the resistance that is in the so-called "R79" space, if you can take a clearer picture of it or the value, of course, thanks mate.
                                  • 31283
                                  2.2ohms
                                  • locojack
                                    • Nov 2018
                                    • 4
                                    • Argentina
                                    Change the smd resistor to a conventional one (it did not have smd) and it exploded again. The previous one also exploded, but apparently the problem is another, some idea? Thank you!
                                      • 31283
                                      of course it exploded,
                                      you didnt fix the cause!
                                      • locojack
                                        • Nov 2018
                                        • 4
                                        • Argentina
                                        The truth that without your comment I would not have noticed, you made a great contribution.
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          by sam_sam_sam
                                          07-01-2024, 06:34 AM
                                        • shamsudeen
                                          Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                          by shamsudeen
                                          Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                          I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                          i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                          07-19-2025, 07:14 AM
                                        • JimBanville
                                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                          by JimBanville
                                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                          09-13-2023, 07:21 AM
