Need Bios dump ideapad s410p
  • kazia
    • May 2015
    • 145
    • indonesia
    Need Bios dump ideapad s410p @8MB
    bord LS41P MB
    12293-1
    any one have it?
  • bhatt
    • Dec 2015
    • 93
    • pakistan
    Re: Need Bios dump ideapad s410p
    [QUOTE=kazia;616972]Need Bios dump ideapad s410p @8MB
    bord LS41P MB
    12293-1
    catch it my dear this is okay bios i give you , and smile,
    • kazia
      • May 2015
      • 145
      • indonesia
      it's for asus, I'm looking for lenovo idepad s410p
      • meritosari
        • Oct 2010
        • 774
        • Indonesia
        bord LS41P MB
        12293-1
        any one have it?
        Have been looking for at several forums, try and post what the result
        • kazia
          • May 2015
          • 145
          • indonesia
          still not working, the second file even not powering on.
          • meritosari
            • Oct 2010
            • 774
            • Indonesia
            This original file that you send it to me, Re-upload here, might be someone can help us to fix it
            ps. backup.rar file from kazia
            • Claudio Silva
              • Feb 2013
              • 94
              • Portugal
              What is the main fault on laptop. Maybe´s not a faulty bios
              • Claudio Silva
                • Feb 2013
                • 94
                • Portugal
                Here you bios totally fixed, if doesn´t work you might consider electronic problem.
                https://mega.nz/#!Nl1gnCrB!Ge0tjTv8y...YL9mcNuzkUFCCk
                • kazia
                  • May 2015
                  • 145
                  • indonesia
                  cannot open site, please upload it here
                  • Claudio Silva
                    • Feb 2013
                    • 94
                    • Portugal
                    Dunno how to upload here, and site is working fine
                    • kazia
                      • May 2015
                      • 145
                      • indonesia
                      now this bord becoming not powering on, even flashed again to it's original bios.
                      • Claudio Silva
                        • Feb 2013
                        • 94
                        • Portugal
                        Check soldering pins, check tracks... Check all connections to bios IC some is failing
                        • sam111
                          • Aug 2015
                          • 2
                          • india
                          thanks for bios
                          • kkmmistry
                            • Oct 2016
                            • 3
                            • india
                            Three short beeps, pause, three more short beeps, and one short beep. on my lenovo s510p
                            plz give solution
                            • kkmmistry
                              • Oct 2016
                              • 3
                              • india
                              1.3 volts coming on ram slot
                              it is ok or not ?
                              • leamlabit
                                • Jun 2012
                                • 4
                                • thailand
                                it is ok or not ?
                                ok ddr3 pc3l
                                • mk praveen
                                  • Aug 2014
                                  • 33
                                  • india
                                  please help me............lenovo ideapad s410p laptop 3 short beeps,3short beepsa and 1 beep no display
                                  i replaced ram....but same.
                                  in ram and ram slot coil showing 1.3v
                                  • fraig
                                    • Nov 2014
                                    • 36
                                    • cairo
                                    bios will solve this problem
                                    • francisruban
                                      • Nov 2014
                                      • 10
                                      • India
                                      Here attached working bios file. its display will come little bit late..
                                      • xam1
                                        • Oct 2017
                                        • 2
                                        • indonesia
                                        sir, is it for s410p nvidia 720m aka 20296?
                                        • Habble7
                                          I need a BIOS dump for the Samsung S49CG934SU monitor
                                          by Habble7
                                          The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
                                          Suspected Cause:
                                          I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • DynaxSC
                                          MSI PRO B660M-G DDR4 - real bios dump from board needed (no stock bios)
                                          by DynaxSC
                                          Hi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
                                          I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...
                                          11-17-2023, 10:56 AM
                                        • jendkkd jeje
                                          Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                          by jendkkd jeje
                                          So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                          I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                          10-11-2024, 03:12 PM
                                        • grimacelord
                                          Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                                          by grimacelord
                                          This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                                          Motherboard model number: DA0PAMB46A1 REV: A
                                          Secondary motherboard model number: 0PAB
                                          SKU: 685K4UA
                                          Serial number is: 5CD3223BJP
                                          Recently reflashed this laptop with latest BIOS and once...
                                          05-07-2024, 08:06 AM
                                        • DynaxSC
                                          Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                                          by DynaxSC
                                          I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                                          It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                                          I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                                          11-06-2022, 05:22 PM
