Considering caps at the VRM output.
Using Polymers to replace Low ESR electrolytics on a motherboard.
Polys are small, have very low ESR at lower capacitance and can operate at higher frequencies (up to several Mhz). On an existing board the design is fixed around non polymer and the higher freqency characteristic is of no advantage.
A number of people are using the polys based on the fact that the ESR is low
eg a 820uF has an ESR of 7-8 milliohms compared with
3300uF 6.3V = 9
2200uF 6.3V = 14
1000uF 6.3V = 18
Consider replacing a 3300uF with an 820uF poly the capacitance has dropped by 4:1 increasing ripple and transients to >3 times. With only a small difference in ESR between the two products the output ripple will be far worse with the 820uF.
Replacing a 1000uF with an 820uF the cap ratio is now 1.22:1 so ripple and transients will increase marginally, however there is a drop of ESR of about 2.5:1 therefore ripple current will increase by 2.5 making sure that less ripple reaches the CPU.
Polys are the best for new higher frequency VRM designs.
3300uF 6.3V = 9
2200uF 6.3V = 14
1000uF 6.3V = 18
