Polymers to replace wet electros
  • davmax
    • Dec 2005
    • 899
    Considering caps at the VRM output.
    Using Polymers to replace Low ESR electrolytics on a motherboard.
    Polys are small, have very low ESR at lower capacitance and can operate at higher frequencies (up to several Mhz). On an existing board the design is fixed around non polymer and the higher freqency characteristic is of no advantage.
    A number of people are using the polys based on the fact that the ESR is low
    eg a 820uF has an ESR of 7-8 milliohms compared with
    3300uF 6.3V = 9
    2200uF 6.3V = 14
    1000uF 6.3V = 18
    Consider replacing a 3300uF with an 820uF poly the capacitance has dropped by 4:1 increasing ripple and transients to >3 times. With only a small difference in ESR between the two products the output ripple will be far worse with the 820uF.
    Replacing a 1000uF with an 820uF the cap ratio is now 1.22:1 so ripple and transients will increase marginally, however there is a drop of ESR of about 2.5:1 therefore ripple current will increase by 2.5 making sure that less ripple reaches the CPU.
    Polys are the best for new higher frequency VRM designs.
    160Gb WD SATAII Server grade
    Nvidia 8500GT 256Mb
    Samsung 18x DVD writer
    33 way card reader
    Windows XP Pro SP3
    17" Benq FP737s LCD monitor
  • bgavin
    • Jan 2007
    • 1355
    Re: Polymers to replace wet electros
    Davmax,
    I have a number of boards that are hyrbid VRM: polymer + electrolytic. All the Intel boards in my possession are like this. My new Gigabyte GA-P35-DS3 is entirely polymer.
    Nearly all the non-polymer are KZE and KZG, which I replace. I did this last night at a client site for a D845GBV board because the 6.3/3300 KZE were bulging. I don't have 16v/2200 in stock, so I left those alone.
    The KZE have been the failure point on all the Intel boards I've worked so far.
    • Fizzycapola
      • Oct 2006
      • 423
      Voltage uF Height Dia. Pitch Ripple mA ESR Ω Mftr. code
      100Khz 100-300Khz
      100uF 10.5 10 5 3210 30 20SA100M
      Permissable ripple looks very high for 100uF capacitor, better than a 2200uF Rubycon ZL. Despite not being apparent on paper, solid capacitors may be better in high temperature environments than liquid capacitors despite what spec sheets say.
      I think I read somewhere
      For smoothing, a single 10uF Oscon out-performs upto 3 1000uF electrolytics.
      Only drawback of Solid type caps is to do with rush current which can cause damage when rapeatedly switching devices on/off , apparently at a certain point it becomes beneficial to use a resistor to eliminate this issue or a thermistor type thing.
      Rubycon Rubycon Rubycon
      • davmax
        • Dec 2005
        • 899
        This is an extreme statement that is totally misleading. Smoothing has everything to do with capacitance eg no capacitance = max ripple, larger capacitance = less ripple. ESR is related to bypassing ripple current away from the processor. Both the cap and CPU are connected in parallel. A 1.4V 60W CPU is a resistance of 32.6milliohm. For a capacitive filter to effectively to bypass 99% of the ripple the output caps must have a combined ESR of 0.32 milliohms, the caps take most of the ripple away. This is theoretical example 99% is not normally achievable.
        In the quest for low ESR specs it would seem many are forgetting the role of capacitance.
        Nvidia 8500GT 256Mb
        33 way card reader
        Windows XP Pro SP3
        • davmax
          • Dec 2005
          • 899
          Originally posted by bgavin
          Davmax,
          What you are saying is not clear. Hybrid in what way? Wet at the VRM input and polymer at the output?
          Yes my Gigabyte board is all polymer. It is designed that way.
          I hope you got my point about care in replacing wet caps in older designs.
          Nvidia 8500GT 256Mb
          33 way card reader
          Windows XP Pro SP3
          • bgavin
            • Jan 2007
            • 1355
            Yes indeed I got the point. I am quite happy to replace KZE with MCZ because it works for me.
            By hybrid, I mean there exists mixed poly + lytics on the vrm side of the socket. This is the side between the I/O shield and the socket proper. I don't know VRM well enough to know if this constitues In vs Out sides.
            I don't replace any of the polys... just the KZx caps. I have equivalent replacements in stock, so 6.3/3300 is replaced by MCZ 6.3/3300, etc.
            • davmax
              • Dec 2005
              • 899
              Looking at polymer caps available it is clear that the product range is targeted at specific computer sections.
              2.5V for VRM output Athlon XP and Pentium 4 typically 1.5V OC < 2.5V
              4.0V for 3.3volt circuits
              6.3V for 5 volt circuits
              16V for VRM input
              So for replacement of wet caps
              Replace 1000u 6.3V with 820u 6.3V usually these caps are scattered around the main board.
              3300u 6.3V (VRM out) 2700u 2.5V ( next to processor.)
              16V wet caps really have no equivalent polymer for older system designs.
              Nvidia 8500GT 256Mb
              33 way card reader
              Windows XP Pro SP3
              • davmax
                • Dec 2005
                • 899
                It would seem that polymers are for the enthusiast. Their cost seems to be about 3 times higher than the usual wet caps.
                Nvidia 8500GT 256Mb
                33 way card reader
                Windows XP Pro SP3
                • chth96
                  Is it no harm to replace with capacitor without ripple current rating?
                  by chth96
                  When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                  Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                  But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                  Rubycon YK DataSheet (b...
                  04-19-2024, 05:19 AM
                • Antonynl
                  What are typical ripple voltages on a laptop motherboard?
                  by Antonynl
                  I have here a HP pavilion hp 15-cs2975nd with a 1.095v power supply that is driven by a FDMF3035. I do see about 80mV of ripple on my scope. I searched through the datasheet to find possible values of the ripple but I don't understand the datasheet well enough.
                  So I have two questions:
                  1) what is the typical ripple voltages of gpu/cpu on a laptop or pc mobo?
                  2) what would be the max ripple of a FDMF3035 that drives an output of 1.095V?
                  Would be nice to have a rule of thumb of say a percentage of the supply voltage to be an acceptable ripple voltage....
                  12-09-2022, 06:51 AM
                • quickname
                  Cyberpower 1500AVR UPS repair
                  by quickname
                  I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                  I decided to verify that the batteries were...
                  11-12-2023, 09:57 AM
                • Antonynl
                  Lenovo 530 Vcore : what is the maximum ripple?
                  by Antonynl
                  Hi
                  I have a Lenovo 530 14ikb i5 8th gen motherboard and it fails to start Windows: it normally dies after I try to load Windows. Getting into bios screen works fine.
                  Made some measurements and I suspect that there is to much ripple on the 2 Vcore coils.
                  What is normally the maximum ripple allowed on say any of the power supplies? A few %??
                  The ripple is on both Vcore as outlined in red in attached photos.
                  Could be a bad driver?
                  Cheers...
                  04-29-2023, 04:59 AM
                • yuzupatogik
                  Help with replacing Capacitors on Altec Lansing ATP 3
                  by yuzupatogik
                  I have this old (2004?) Altec Lansing ATP3 and i would like to replace the capacitors. I have identified 34 out of the 36 of them as Samxon GR of various capacities and voltages.
                  I can't find datasheets for the Samxon in any of the following variants:
                  10000uF 25 v - this one i really want to replace because i suspect it is what causes a dull hum regardless of the volume knob position or if the source is plugged in. I am eyeballing the Rubycon 25PK10000MEFCGC18X35.5 for this purpose. So if i pay a 10x the price part for shipping i might as well go ahead and...
                  02-14-2025, 04:11 PM
