little help testing smd caps?
  • mattstolte
    • Dec 2013
    • 612
    • usa
    Ok guys I am still learning a few things trying to get down to component level. I know how to regular capacitors. But I'm wondering them little and capacitors that have no value on them how can a person check them? Even smd diodes and resistor like on a main board for example
    Re: little help testing smd caps?
    You can't really test ceramic capacitors for value, as they do not have a printed value. There is no way to determine the value if it is failed. However it is extremely rare for a ceramic cap to fail. If it does fail it will almost always (99.9% of the time) fail short circuit which can be tested with an ohmmeter.
    • mattstolte
      • Dec 2013
      • 612
      • usa
      Are you talking about the little Brown smd ones on a main board? Also what about the little metal smd can shape ones on main board
        • 31289
        the can's are marked.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          The ones Tom are on about are called MLCC's which stands for Multilayer Ceramic Capacitor the ones you speak of are known as Smd caps they are marked with their respective values.
          • SteveNielsen
            Retired Tech
            • Jun 2012
            • 2327
            You test SMD parts exactly the same way as you test any other electronic component of the same type, the mounting doesn't electrically matter.
              Seasonic B12 BC-550 – barely 2 years old and with BAD CAPS already!
              by momaka
              I know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
              For today's considerations, I have a Seasonic B12 BC-550 [A551bcafh] 550 Watt ATX power supply for you (click on links for full size images).
              https://www.badcaps.net/filedata/fetch?id=3591771
              https://www.badcaps.net/filedata/fetch?id=3591772
              It's a modern ATX unit with fixed (non-modular) cables and an 80-plus bronze certificate. Here's the label:
              https://www.badcaps.net/filedata/fetch?id=359177...
              03-12-2025, 03:42 PM
            • Sus256
              HISENSE 65E7KQ PRO - no boot
              by Sus256
              Hi all!
              HISENSE 65E7KQ PRO
              RSAG7.820.13512 - chassis
              MT9618BAATAB - cpu
              RSAG7.820.12059 - power
              HD650Y3U77 - panel
              KLM8G1GETF - emmc
              The TV does not turn on, the standby indicator is on. All voltages are present.
              Emms is dead. Not readable, not detected.
              Replaced emmc.
              But with another dump there is no launch
              Terminal log
              UART
              AC_ON
              RPMB key is not yet programmed
              HASH1_VERSION=0x00000000 64bit
              E-B
              FDE enabled
              layout pattern onebin by SAR7,0...
              06-01-2025, 02:11 AM
            • Paxman_Swede
              Identifying caps on an old Zoom 9000
              by Paxman_Swede
              Hello!
              I have two projects on my work bench. One is a friends dead JBL Xtreme speaker with a blown voltage regulator and corresponding bulged and shorted cap. That cap has clear markings so I know what replacement I need for it.
              The other project however is a whole different deal. It's a Zoom 9000 guitar effect from the 90th that has developed a devil hound howl when there is no input from the guitar. I'm guessing caps problem. So, since I don't really use this effect anymore I thought it would be a perfect project to learn on.
              I have studied the board and...
              01-14-2025, 09:51 AM
            • captain150
              Help with switching power supply caps
              by captain150
              I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
              I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...
              03-16-2025, 07:34 PM
            • Foetuss
              Gigabyte GA-6OXT :: caps question
              by Foetuss
              Good evening
              I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
              Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
              But I was also suprised about the bigger boys, which are 330µF 25V.
              Could it be they used 25V caps because they were cheaper / available at that time?...
              02-11-2025, 12:22 PM
