how to check these surface mount transistors and diodes?
  • mattstolte
    • Dec 2013
    • 612
    • usa
    I have this Panasonic sc board and they make a repair kit for this but I wanna know how to check these transistors and diodes?
    • 31289
    Re: how to check these surface mount transistors and diodes?
    those are fet's
    the good thing here is that fets usually fail by going short circuit.
    meter between the pins - if there arent any shorted they are probably fine.
      Like any other transistor, just check across pairs of pins for shorts.
      The middle pin and tab are electrically connected internally, so you don't have to test that.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8352
        if they are shorted, they are bad.
          Yes, and if one transistor in a parallel "set" is bad, ALWAYS replace other transistors in that same set, as well as all transistors in series.
          Failure to do this can lead to an explosive first power on...
          • Ltank
            • Jun 2013
            • 776
            It takes a lot of heat to remove these mosfets. Chip-Quik can be very helpful. Care must be taken not to damage the foil traces on boards. Practice on a bad board that is not repairable
            • tw2005
              • Oct 2011
              • 6458
              check the IGBTs first in cct. then desolder and lift the 2 legs reconfirm whats shorted. You'll probably find with the shorted IGBTs isolated the diodes often will show as good.
              check the gate resistors too once the bad IGBTs are removed.
                I use 400C temperature with a 65W soldering iron. They come off easily. The pads are very large and hard to damage.
                • tw2005
                  • Oct 2011
                  • 6458
                  No dramas here either, likewise I use a quality broad tip to get that heat Transfer happening on the tabs, in fact I tin the whole tab.
                    • 31289
                    i heat the area from both sides with hot air, then put the iron on the tab with some solder.
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8352
                      x 2
                      • caphair
                        • Nov 2011
                        • 1249
                        I use hot air and flux. It slides off with slight pressure eventually.
                          "how to check these surface mount transistors and diodes?" Same way as you test the Through hole devices. If it does not read right then you have to remove it and test it off the board.
                          Surface mounted device still functions the same way as the through hole device.
                          • mattstolte
                            • Dec 2013
                            • 612
                            • usa
                            So just put in diode mode should read between 400 and 700 one way and open the opposite way?
                              Did you actually read any of the posts above?
                                That will only be true if there are no other components connected in parallel with the two legs of the device you are testing. If it shows conduction in both directions then you will need to remove it and test it again.
                                MOSFET is another story.
                                May be you should get a hold of some good NPN, PNP transistors and some N-CH, P-CH MOSFETS, then look up the pin out and take the readings to see what you get on the good device.
                                  Surface Mount Fuses Fundamentals Datasheet
                                  TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                  TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                  10-07-2024, 06:07 AM
                                  Microsoft Surface Book Surface Book 3 + Surface Dock Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                                  This specification for the Microsoft Surface Book Surface Book 3 + Surface Dock Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book 3 + Surface Dock boardview and Surface Book 3 + Surface Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                  09-06-2024, 08:10 PM
                                  Microsoft Surface Book Surface Book 3 + Surface Dock 2 Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                                  This specification for the Microsoft Surface Book Surface Book 3 + Surface Dock 2 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book 3 + Surface Dock 2 boardview and Surface Book 3 + Surface Dock 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
