HP 15 DAR62CMB6A0 Bios file needed
  • salawayon
    • Nov 2012
    • 569
    • philippines
    The mentioned notebook had a no display problem. Power Switch voltage ok and bios supply also ok..
    Thanks...
  • dilip.pawar31
    • Nov 2014
    • 59
    • india
    Re: HP 15 DAR62CMB6A0 Bios file
    try this one i think this file are working
    • Okinavi
      • Mar 2014
      • 3
      • Sri Lanka
      Re: HP 15 DAR62CMB6A0 Bios file needed
      No. Its not working.
      • Okinavi
        • Mar 2014
        • 3
        • Sri Lanka
        Sorry. It's working perfect. Thank you.
        • toufik sat
          • Feb 2016
          • 134
          • los angles
          • ibrahim_yas
            Banned
            • Nov 2015
            • 20
            • 86159159666
            thanks
            • pcnetch
              • Aug 2013
              • 125
              • Sri Lanka
              try this
              • balu457157
                • Oct 2015
                • 18
                • India
                thanks.. but it shows Flashing Boot Block 79% ;/
                • jestin123
                  • Jun 2016
                  • 1
                  • India
                  hello hp 15-r007tx bios file av?
                  • sandros15
                    • Apr 2010
                    • 6
                    Originally posted by pcnetch
                    try this
                    Thank u
                    • toufik sat
                      • Feb 2016
                      • 134
                      • los angles
                      thanks
                      • mdchala
                        • May 2015
                        • 8
                        • Algeria
                        Thank you.
                        • boussaa islem
                          • Nov 2018
                          • 30
                          • ALGRIA
                          thank you good work
                          • ajeeshkvr
                            • Sep 2015
                            • 5
                            • oman
                            HP 15 DAR62CMB6A0 power led blinking,some time power is ok solution pls..........
                            • mibo012
                              • Feb 2019
                              • 23
                              • Slovakia
                              Thank you dilip.pawar31
                              • tano2060
                                • May 2018
                                • 27
                                • Macedonia
                                Nice, it works.
                                • GRACIOUS COMPUTER
                                  • Mar 2020
                                  • 1
                                  • GHANA
                                  please i have HP dar62cmb6a0 rev:a with no display problem.
                                  flashing the two bios chip as proven futile only the one at the SIO chip is detected by my programmer but the other no. please can you help .
                                  • raedinformatique
                                    • Feb 2018
                                    • 24
                                    • algeria
                                    Thank you itworks
                                    • hussaka
                                      • Jan 2015
                                      • 152
                                      • italy
                                      thank you
                                      • mohameda
                                        • Aug 2020
                                        • 6
                                        • eldeep
                                        Thanks..
                                        • Forest79
                                          Lenovo ThinkStation P520 BIOS file needed
                                          by Forest79
                                          I got a Lenovo ThinkStation P520 (Type 30BF) from a friend, asking me for a repair. Windows 11 offered a firmware upgrade as an optional update, and it failed.
                                          The emergency flash procedure from the hardware manual has also failed. So, I asked an acquaintance with better skills to flash the BIOS directly.
                                          However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                                          07-23-2023, 07:39 AM
                                        • Citymin
                                          NT955XED (Samsung Galaxy Book2 Pro - 15.6) BIOS dump file Request
                                          by Citymin
                                          My Samsung Galaxy Book 2 Pro 15.6-inch laptop has no display and won't boot.
                                          The charging red LED lights up, but the charging screen doesn't show any indication.
                                          When I press the power button, the blue LED cycles on and off three times, then the screen doesn't turn on, and the device won't boot.
                                          (I've tried removing the battery and resetting the device, but the issue persists.)
                                          NoteBook Model name : Samsung NT955XED-KK51G(Galaxy book2 pro, i5-1240p, 15.6inch AMOLED)
                                          PCB model name : Venus2-15-5G(REV1.2), Venus2-15 ADL NPC
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
                                        • wakethesleep1111
                                          Bios File Needed for asus tuf15
                                          by wakethesleep1111
                                          Hi im new and I have a question. I am in need of a bios file to flash my bios with preferably without the bios password included. I have a Tuf f15 gaming laptop. The model is a TUF506L. The bios chip is a Winbond W25Q128JV. The size is 16777216.
                                          05-27-2025, 10:56 PM
                                        • kamkam336
                                          Alienware Aurora R8/9 Bios .bin file needed
                                          by kamkam336
                                          I got a new mobo from Aliexpress for my Aurora r9 and everything was working fine until i did a bios update. It did not work and now i get 3x, 7x, 3x, 6x blinking code. Dell says that is a corrupt bios. So i have the ch341 and software required, i just don't have the bios.bin file.
                                          Since the board is from Aliexpress it doesn't have a service tag, I have a copy of the .exe bios and a copy of my corrupted bios attached. Hopefully this is enough, if anyone is able to help me and requires any more information please let me know.
                                          Thanks ...
                                          08-19-2024, 06:59 PM
                                        • maanee11
                                          Help to get Lenovo BIOS bin file for Thinkpad T560
                                          by maanee11
                                          Hello Everyone,
                                          I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                                          https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                                          In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                                          05-15-2022, 11:59 AM
