Acer E1-531 bios dump
  • senchire
    • Dec 2012
    • 190
    • Bosnia
    Hello folks, anyone could provide bios dump for Acer e1-531 Q5WVH LA-7912P.
    Thanks in advance.
  • nazrul145
    • Jan 2014
    • 337
    • BD
    Re: Acer E1-531 bios dump
    Try this.
    • shahzad butt
      • Mar 2015
      • 5
      • saudia
      i need bios acer aspire E1-532 bios can u provide me
      • Djosla
        • Dec 2012
        • 246
        • Montenegro
        nazrul145 thank you for dump...it works....
        • oussama
          • Nov 2015
          • 1
          • tunisia
          thank you for dump.
          • Meck
            • Jan 2015
            • 5
            • Bosnia
            Works also on e1-571 Thank you so much
            • ameesh.p
              • Dec 2014
              • 37
              • qatar
              Originally posted by shahzad butt
              i need bios acer aspire e1-532 bios can u provide me
              try this.
              • alas3376
                • Nov 2011
                • 382
                • BENIN
                thank you
                • ytsoc
                  • May 2014
                  • 67
                  • romania
                  can anyone make a clean ME version of this bios from an acer e1-571 la-7912p?
                  With this bios the laptop shuts down after exactly 30minutes
                  • nts28
                    • Nov 2015
                    • 33
                    • türkey
                    thankyou
                    • costty
                      • Oct 2017
                      • 1
                      • romania
                      Its not BIOS problem - its ENE or IT 85xx problem....from the power management
                      (i have the same problem with asus x75vd-aceeasi problema...am cumparat un IT gata scris si a mers)
                      • haritvr
                        • Nov 2016
                        • 22
                        • India
                        Originally posted by nazrul145
                        Try this.
                        hi guys thanks for share ur experience
                        • burjuvas
                          • Feb 2016
                          • 4
                          • turkey
                          thanks
                          • Charlesouma
                            • May 2018
                            • 2
                            • kenya
                            thank you guys
                            • Main2
                              • Feb 2018
                              • 5
                              • morocco
                              thank you
                              • mohham
                                • Sep 2014
                                • 23
                                • indonesia
                                thanks
                                • ninito
                                  • Jun 2017
                                  • 21
                                  • Serbia
                                  • bernard 01
                                    • Feb 2021
                                    • 1
                                    • Algeria
                                    thank you
                                    • dahnking
                                      • Apr 2018
                                      • 262
                                      • kenya
                                      Try this.
                                      perfectly working
                                      • Nynd
                                        • Aug 2022
                                        • 2
                                        Will this file work for a Acer Aspire E1-532-4629? I renamed the BIOS file (due to black screen) and with a USB boot drive, got 3 beeps when doing the FN+ESC reload. Do I have bad Ram? or was there an issue with bios?
                                        • James194zt
                                          Acer Nitro 50-640E Corrupted BIOS Dump
                                          by James194zt
                                          My daughter has accidentally managed to kill her Acer gaming desktop it has a blank screen after updating and when you press the power button the fans spin, light comes on and it makes 1 long and 1 short beep and no attempt to boot.
                                          All basic troubleshooting has been done we replaced CPU, GPU and RAM from a working machine and no joy, I also noticed a post on here with the same issue and it was the BIOS. I am pretty sure also because it was doing a BIOS update that stopped it working, she knocked the keyboard out by accident during the update and the screen just went...
                                          04-28-2025, 03:29 PM
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • Habble7
                                          I need a BIOS dump for the Samsung S49CG934SU monitor
                                          by Habble7
                                          The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
                                          Suspected Cause:
                                          I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • x14nl34l
                                          Acer TravelMate p614 (tmp614-51-g2-5442) bios dump
                                          by x14nl34l
                                          Hi, I need a bios dump for my Acer TMP614 (tmp614-51-g2-5442 bios dump). Thanks.
                                          09-01-2025, 09:54 PM
                                        • ZOrd_Z
                                          Acer Predator P03-650 bios DUMP.
                                          by ZOrd_Z
                                          I need a bios dump to a Acer Predator P03-650 board.
                                          Or to convert the .CAP file o a file to flash.
                                          Thank's......
                                          10-29-2024, 12:06 PM
