Panasonic TC-P54S2 plasma TV--won't turn on, originally 10 blinks, now 7 blinks
  • JoeyB
    • Mar 2015
    • 34
    This is my first request for help here, so I hope I'm following the rules, and my apologies if I err.
    My 2010 Panasonic TC-P54S2 plasma TV worked perfectly until one day it suddenly would not turn on. The power light would blink ten times. I tried various would-be fixes, such as (1)unplugging all the cables and letting it sit for a while, and (2)holding the power button down. The service manual said that 10 blinks indicates the power board, the A board, the SC board, or the SS board.
    I replaced the power board--no change, still 10 blinks. I replaced the SS board--no change, still 10 blinks. I replaced the SC board, and it still wouldn't turn on, but it changed to 7 blinks. The manual said that 7 blinks indicates the SU or SD board.
    This time, I dug out a meter and tested the cables to the SU and SD boards, and they all checked out. Since the SU and SD boards were relatively inexpensive, I ordered both and replaced both--no change, still no power and still 7 blinks.
    I am a novice at television repair, and at this point I have no idea how to proceed. Seemingly the SC board was one problem, but obviously I still have another. Any suggestions would be greatly appreciated. Thank you to all who have read this far.
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TC-P54S2 plasma TV--won't turn on, originally 10 blinks, now 7 blinks
    Crikey, you've been around the block with this one. If only you'd been fortunate to come here first.
    Do you still have the original SC board?
    • JoeyB
      • Mar 2015
      • 34
      Yes, I do--
      • tw2005
        • Oct 2011
        • 6458
        A few things may have happened here. I would almost put money the Sc being the original fault. There's a possibility the replacement Sc is also faulty, also a chance the original SD/SU boards were shorted and damaged the replacement SC but generally they survive but i have had one with SD & Sd shorted and it blew up a new Sc board.
        I think it would be handy to resistance test the original SD/Su boards too.
        How good is your multimeter? Can it get to 6meg ohms ?
        • tw2005
          • Oct 2011
          • 6458
          Originally posted by JoeyB
          Yes, I do--
          On the original Sc board,
          measure resistance across the Sc2 connector pins, could show a few hundred K ohms or go 2-3 meg
          near the Sc20 connector there is a test pad TP82, measure resistance between that and any gnd pad on the Sc board, could be 1350 -1500 ohms
          across C561, also nesr Sc20, small ceramic SMD cap, resistance across that 5.63k.
          • JoeyB
            • Mar 2015
            • 34
            I'm not sure (about my multimeter). I'll have to check it out tomorrow--it's late here and I need to get to bed. Thanks a lot for the responses!
            • tw2005
              • Oct 2011
              • 6458
              Ok, well bummer for me, I'll post up some other checks but a quick check at this point would be to do the SC50 jumper test which involves isolating the SD/SU boards and firing it up but I think it may be useful to gather other evidence to ascertain whether anything else is bad first just in case it was a dud and you can get your money back on it.
              So if the old buffers prove good and the replacement buffers prove good then we can assume replacement SC was bad if in fact it proves to be bad.
              • tw2005
                • Oct 2011
                • 6458
                Once you have this data, repeat on the replacement board, disconnect Sc20 ribbon and SC2 lead first.
                Then on the original SD/SU boards measure the following pins, this is with the boards disconnected from the SC and disconnect the small ribbon that interconects SD/SU boards.
                SU41
                All are in respect to - Vfg(floating gnd, the metal plate the bolt goes through)
                pin 2, or TPSU15 (VFO) 2.2Meg
                pin 4, TPSU16 (VSCN-F (TPSC1)) 221K
                pin 8, TPSU17 (5V_F) 5.7Meg
                SD42
                pin 1, or TPSD29 (VFO) 2.2Meg
                pin 2, TPSD28 (VSCN-F (TPSC1)) 221K
                pin 6, TPSD26 (5V_F) 5.7meg
                repeat for the replacement SD/SU set you got
                The G20,25 guide will be mostly applicable as the 5081 SC board is used throughout that series. slide 43-44 buffer tests
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  Just read this post as joeyb has changed a lot of boards already whilst fault finding would it be best to replace all the boards with the original set ones? just incase some of the new boards have intermitant faults etc that his old boards wouldnt of had? or may even be slightly diffrent part numbers etc.
                  • tw2005
                    • Oct 2011
                    • 6458
                    I think establish evidence first before we go ripping things in and out again. SC is most likely suspect and not too hard to prove bad if they've failed in the typical manner.
                    We could just go straight to Q661 and check for short But I like to see what's happened to the 5v,15v and vsus lines.
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      • uk
                      yes true i guess it could cause unnecessary damaage by keep swoping boards around.
                      • tw2005
                        • Oct 2011
                        • 6458
                        Just reading the first post, his first change was at the SC board swap but 7 blink, pretty much confirms bad SC. From there
                        a good SC + bad buffers = 7 blink
                        may now be bad SC + bad buffers = 7 (bad buffers killed good SC)
                        then replace with good buffers but Sc now bad = 7
                        or used Sc was originally bad and 7 blink but both sets of buffers should still be good.
                        If used was supplied bad, get refund and send original to modulinkpts, confirm both sets of buffers good, sell spare set.
                        All depends on what we can prove but I personally would not mess with that used SC applying power yet.
                        • JoeyB
                          • Mar 2015
                          • 34
                          Thanks a lot for the responses, and especially for the troubleshooting guides. I'm just logging in quickly from work now, and will look more closely later.
                          Thanks again!
                          • tw2005
                            • Oct 2011
                            • 6458
                            yep, and i'm logging out of breakfast for work. LOL
                            • JoeyB
                              • Mar 2015
                              • 34
                              I've got a lot of information to sift through here, so I may not post again soon, but I will report back. Thanks again to tw2005!
                              • tw2005
                                • Oct 2011
                                • 6458
                                Sure, yes it may seem a lot but I'm sure we'll get this on track again and narrow it down. This way we'll be sure .
                                • JoeyB
                                  • Mar 2015
                                  • 34
                                  How do I spot the ground pads? I was hoping they'd be labeled, but no.
                                  Thanks.
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    Thanks.
                                    for the buffers it's where the large bolts came out of, can't miss the metal plate. pretty sure if you read what i've posted i've stated this .
                                    • JoeyB
                                      • Mar 2015
                                      • 34
                                      Sorry, I meant on the SC board. I should have been specific. The holes for the bolts look different on it, but I guess it's the same answer. Thanks.
                                      • tw2005
                                        • Oct 2011
                                        • 6458
                                        almost, any point the bolts mount that has metal contact will do except where the buffers mount which is floating gnd not chassis.
                                        • jm1234
                                          Panasonic plasma TX-P42ST50 - 6 blinks
                                          by jm1234
                                          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                          I checked that board for any obvious faults...
                                          05-22-2024, 06:59 AM
                                        • Alicat
                                          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                          by Alicat
                                          Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                          Model number is TH-50PZ85U
                                          Power comes on and the red power light stays on solid.
                                          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                          I also hear a few clicks.
                                          I also think my parents said there was a thunderstorm and the TV failed after that.
                                          Section 6 in the service manual talks about power and no screen,...
                                          10-30-2024, 10:09 AM
                                        • nick31
                                          Panasonic Plasma ST50 TC-P55ST50 P55ST50 8 blinks
                                          by nick31
                                          My Oct 2012 panny plasma quit working yesterday.
                                          It was on when it happened. It let out a bit of burned plastic/circuit board smell. I was not able to find any burned parts though.
                                          Now it produces 8 blinks. According to the repair manual, that points to SS/SS2 board(s).
                                          I completed the steps in the guide: unplugged SS33, the TV turned on with a black screen, no blinking codes. Then I checked the continuity between pins 1 and 2 of the connectors SS52, SS54-SS57. The continuity is ok in all of them. Guide suggests to replace SS/SS2 boards so I placed an order...
                                          04-21-2021, 09:56 AM
                                        • stecos
                                          Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                          by stecos
                                          Hi everyone!
                                          I happened several times, in the search for help from the web, to consult this very interesting forum.
                                          So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                                          Having said that I come to the gist of my post on the forum as the title suggests.
                                          For my passion for technology I'm now collecting several...
                                          11-28-2022, 11:39 AM
                                        • Biruslapio
                                          Panasonic P58V11B 8 and 12 blinks error "fix"
                                          by Biruslapio
                                          Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                          Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                          04-13-2021, 07:13 AM
