I have this sony, as soon as i plug it in it turns on and screen is light blue then after about 45 secs it shuts off to a 14 blink code. I have heard 14 blink is panel failure but thats only if the set will not turn on, the set turns on but screen is light blue, im stuck between would this be tcon or main?
SONY kdl-46xbr6 14 blinks
Tags: None
Re: SONY kdl-46xbr6 14 blinks
check tcon 12 volt at fuse both end.
wbr -
can u tell me what to do to check it? just make sure it aint blown?Comment
Show us the good clear pictures of the T-CON board so we can try to locate the SMD fuse. You have meter, right?Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809Comment
TELEFIX
PLEASE DO NOT EMAIL ME PRIVATELY FOR REPAIR ADVICE. QUESTIONS BELONG ON THE FORUM!Comment
checked the fuses there is like 3 of them the little smd fuses I checked them all there good. could it still be tcon? I was thinking main boardComment
--Who knows! Its a bloody Sony--and aint all they cracked up to be!
Never ever liked Sony in all my 40 odd years of messing with electronics....TELEFIX
Try disconnecting the ribbon cables from the LCD panel to the T-CON to see if the error goes away.Never stop learning
Well, let start with this, where are the pictures I requested?
Do you know how to use Volt meter?Never stop learning
There are 3 fuses on the top side of the board (F700, 701, 601) and 3 on the bottom side of the board F602, 603, 604.
To test the Voltages, you will set the meter to DCV, black probe on the chassis, red probe to each end of the fuse and reports the readings.
There are also test points for the Voltages as printed on the board.
Your pictures are way put of focus to see anything clearly but luckily SJ has the goods pictures.
http://www.shopjimmy.com/sony-1-857-...con-board.htm#Last edited by budm; 04-05-2015, 06:18 PM.Never stop learning
Will do today. Should I set dcv on 20 then correct unless its 2rv turn it to 200?Comment
All six fuses has the same Voltage reading?
And again post 15.
So what ever happen to this request?Never stop learning
ok so I disconnected the ribbons from the lcd and yes still same problem, the tv screen lights up then after about 45 secs it shuts down and its a red blink code 14 blinks. so are we thinking its bad lcd?Comment
by AK_777Hi everyone!
I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and... -
by jchonHi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
I found the service manual, which was critical to know where to probe.
https://www.manualslib.com/manual/20...1e-Series.html
With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
Unfortunately the 5-blinks... -
by cheeky2For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...01-08-2024, 05:56 AM -
by EazyBoneSo I got this Sony and purchased it working.. got it home and it was 4 blinks red. Seller actually refunded me thankfully. Now it's massive to take apart and I know 4 blink can be the panel sometimes but not always..
But I found a method through other ways with grounding out the bl error pin on the LD driver board. Now the tv turns on and works.
Pin is number 27. It was either remove the resistor right next to the solder pad or solder the pad to ground. I soldered the pad.
Now what is this going to do to the tv? Is it just going to die shortly down the road?... -
by ivtecHi my old Sony i turn it off and it turns itself back up and many times remote wont work have to unplug tv...
- Loading...
- No more items.
