TC-P50GT25 blinks 4 or 10
  • djw43
    • Mar 2015
    • 95
    Hello Forum,
    Thanks for being a great source for DIYer's
    I have not been lucky enough to find the tech manual/service manual for my exact manual, so I have been referencing a few from 2010 for G25 and another from 2011 for GT30.
    In order for me to complete the diagnostics for my blinks, I have 2 questions:
    1.) When i connect AC, I get a few relay clicks right away, then 15 seconds later i get another few clicks. My questions is whether I power on and view blinks after the first clicks or after the later second clicks? Because right away I get 10 blinks, and if i wait until after 2nd set of clicks, 4 blinks.
    2.) In diagnostics I am checking voltage on pin 9 on P7 in one flowchart, and the tree is "is there 3V present?" when turned on, another chart asks "is pin 9 high (3V) before the TV shuts down?". My question is after I use the start/power button the TV shuts down right away, like in a second. After it has shut i do read 3.13v on that pin, but it is after the one second it takes to shut off (SOS?) Am I a "yes" branch or a "no" branch for whether i see 3v?
    ultimately i am trying to determine what board or boards i need to fix or replace.
    thanks,
    david
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: TC-P50GT25 blinks 4 or 10
    SC Board is the most suspect on recent Panasonics. Power Off, Check for short-circuits on the V-SUS supply on the SC Board.
    --The boards of these sets are rather hard to get (Because they always blow up, due to crap screws and poor cooling) and can be expensive.
    There's Co's in the USA Moduslink? that repair them.....
    TELEFIX
    • tw2005
      • Oct 2011
      • 6458
      Originally posted by djw43
      Hello Forum,
      thanks,
      david
      As per Alastair, The TNPA5081AP SC board is the most likely culprit here and has shorted the P-board.
      Try searching TNPA5081 or your model or any FHD of that era eg 42,50,54 G20 / 25, GT25, V20 and there should be heaps of stuff to read.
      Moduslinkpts repair boards or there's kits or you could try and work it out from the SC repair thread I did.
      the SD/SU boards will have to be checked for shorts as well
      • djw43
        • Mar 2015
        • 95
        thanks very much for the responses !
        I did have another question, because I did check Vsus and Vda and p15V for shorts first, and when i measured resistance they each started low, like a few hundred ohms, but as I keep the multi meter in place the R crept up over 2kohm, but it was weird to watch the resistance increase for 5-10 seconds. Is that normal?
        • tw2005
          • Oct 2011
          • 6458
          ccts charge, try reversing the probes. SC2 should start at around 300Kohms and up to 2-3meg. The P15V may be shorted or dragged down in this one as well on that SC board
          • djw43
            • Mar 2015
            • 95
            Thanks again, I switched from a digital to an analog multimeter, and even though I was getting odd readings with the probes one way, I was getting readings that made sense after switching them. The SC is a few hundred ohms and I will replace or with the spectacular guides, I may try to repair. The SS was reading approx 2k ohms, so perhaps that will be next to go, but I want to see if the TV will turn on after fixing the SC before I change the SS.
            thanks
            • Alastair E
              Chief Womble
              • Mar 2013
              • 1963
              • U.K.
              In some cases--a faulty SS board can kill a new/good SC board--so I would remove both boards and check ALL the IGBT's and MOSFETS on both boards for shorts, and also check both buffers too, before putting power anywhere near the set!....
              TELEFIX
              • djw43
                • Mar 2015
                • 95
                ok thanks Alastair, I will check both boards, I just need to do some research for how to test those transistors. I am happy to have a plan and a road map for some directions, which this site provides!
                • keithf2
                  • Aug 2010
                  • 131
                  i know this is not the correct place to ask this question but I can never find the correct way to start a thread. what I want to know is how do you make a connection on a LG 42PJ550 control board to get the test pattern. Thanks in advance.
                  • tw2005
                    • Oct 2011
                    • 6458
                    Time to learn
                    • tw2005
                      • Oct 2011
                      • 6458
                      thanks
                      I don't think I've read a report of bad SS in these yet. Bad SS in these won't take out the SC as they are not interconnected like the HD models .
                      focus on the SC and making sure the SD/SU boards are good
                      • djw43
                        • Mar 2015
                        • 95
                        Hello again gentlemen,
                        I am in the process of checking the SC/SD on my 2010 TC-P50GT25.
                        Can you guys recommend a handbook, I am not sure whether to follow the 2010 G20 G25 or the 2011 GT30 handbook for checking these 2 boards connected to the SC, I started using the G25 handbook, disconnected the 4 screws and disconnected the 3 - SC41, SC46, SC42, I unplugged SU11-SD11 ribbon, and jumped SC50.
                        as per:
                        https://www.badcaps.net/forum/showpo...0&postcount=15
                        I see 2.5M TPSU15
                        220k at TPSU16
                        but i am getting low reading on TPSU17
                        and TPSU18 to (VF_GND) is in the mega ohms, not grounded (I am using the metal ring around the screw hole for VF_GND not the case in the screw hole.
                        But either way TPSU18 is not grounded, neither is the ring around the screw hole?(VF_GND) with the screw removed.
                        I am struggling some between digital and analog multimeters, I am getting different values on the analog when i switch probes, and with the digital I can get increasing or decreasing resistance depending on the probes reversing.
                        Meanwhile I have at least 6 Qxxx components on the SC that have a least 2 legs shorted. (tone)
                        thanks guys
                        • tw2005
                          • Oct 2011
                          • 6458
                          just use the pin numbers at the relevant connectors on the buffer boards and gnd at the mounting plates. Try switching the probes around but so far for the Su you've listed
                          Vfo states 2.2Meg, you say 2.5 meg, i usually get about 1.9Meg on a fluke 73.
                          This would normally show short on a bad board, I say pass
                          VSCN-F (TPSC1) states 221K, you say 220K, I get 220K- pass
                          5V_F states 5.7Meg, you report ? What is the range limit for your meters? I get as quoted with my meter
                          confirm Su 5V_F,
                          Now repeat process for the SD, looks promising
                          gnd on these has nothing to do with chassis gnd
                          • djw43
                            • Mar 2015
                            • 95
                            thanks!
                            I will measure again, the boards are removed, will the results be useful?
                            Otherwise I can replace them.
                            I really appreciate the help, and I am amazed at your fast responses!
                            thanks
                            dave in NJ USA
                            • tw2005
                              • Oct 2011
                              • 6458
                              thanks!
                              thanks
                              dave in NJ USA
                              I'm bored and just sitting here but going shortly. yes they are as it will save you money and as you start looking you'll find parts are getting more expensive and hard to get but the repair services are now growing as that's the only option or self repair if you're good at this stuff.
                              • djw43
                                • Mar 2015
                                • 95
                                I think i was unclear.
                                I am going to measure the resistances again, it is ok to measure them out of the case?
                                Instead of replacing them back in the case to measure.
                                I have seen your extensive info on TNPA5081 and my plane is to purchase a repair kit for that board and repair it myself.
                                thanks again have a good night
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  for sure out is fine and so is insitu, if you leave them in then you won't have the drama of getting the ribbons in again straight as they can be fiddly to get right.
                                  before you rush off and get a kit , list which ones you're looking at as some do not have everything.
                                  look at IC771,773, q701,702,818 IC521 and see if you reckon you can handle replacing those. what soldering gear do you have?
                                  • djw43
                                    • Mar 2015
                                    • 95
                                    i will look at those, i have a haiko FX-888D soldering iron, the smallest components i have removed and replaced were LEDs on a radar detector.
                                    thank you
                                    • tw2005
                                      • Oct 2011
                                      • 6458
                                      thank you
                                      Hot air may be handy but I used 2 soldering irons, allowed me to heat 2 sides at once , the tracks tear and lift easy if not careful, usually I flood the pins with solder , can usually lay the tip on a low angle to cover more pins to get these off in one hit.
                                      flux helps and i need a magnifier to see what I'm doing
                                      $85 for modus repair, kits look expensive and deficient, utsource if you want to ordr the bits and wait weeks for them to arrive, there maybe other options for supply in the US but that I have no knowledge
                                      • djw43
                                        • Mar 2015
                                        • 95
                                        $85 looks pretty good right now!
                                        As i went down your list they looked more and more difficult.
                                        IC771 with AE on it 3 pins under and one above, doable
                                        773 is smaller and looks like it has 5 solder pins
                                        q701 is small but accessible
                                        702 a little harder
                                        818 even smaller, 3 pins
                                        IC521 chip 1737FP, i would not know how to remove that one, copper braid? hot air?
                                        I salute your skill!
                                        well I am going to look into modus for my TNPA5081, thanks
                                        I will be back...
                                        • Biruslapio
                                          Panasonic P58V11B 8 and 12 blinks error "fix"
                                          by Biruslapio
                                          Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                          Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                          04-13-2021, 07:13 AM
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                          11-20-2024, 08:52 PM
                                        • Taurus12
                                          Optiplex 3050 micro 2 blinks followed by 3 blinks issue
                                          by Taurus12
                                          Does anyone have an idea of what might be the issue with my 3050 micro? I have tried replacing new cmos battery but still the same
                                          I am not sure if its the powersupply that I'm using is the issue since its the original powersupply. its a laptop powersupply with the same specifications with the 3050 micro so i guess it should be fine.
                                          i also tried replacing the bios but with no avail, everytime i try another bios it gives a different blinking lights
                                          Any recommendation on what I have to do next? Thanks in advance
                                          06-10-2025, 05:05 PM
                                        • GRANDGG
                                          LG 42lw4500 flashing red light , wight light , 2 clicks
                                          by GRANDGG
                                          Hi i have an issue with LG 42lw4500 wich after pressing the power button flashes red then goes solid white light 2 clicks and nothing , the weird thing is SOMETIMES if i leave the tv plugged in it would come on and fuction normally (i should mention that vertical rectangle going from the bottom to the top of the screen have some red dot artafacts it only appear in somthing like the tv input menu and any input i give like vga , but not in the system menu , i thought i should mention this , i cannot confirme if the tv had this issue when it was up and running in its previous owner . ) when checking...
                                          05-09-2025, 12:27 PM
                                        • jchon
                                          Sony A1e 5-blinks help
                                          by jchon
                                          Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
                                          I found the service manual, which was critical to know where to probe.
                                          https://www.manualslib.com/manual/20...1e-Series.html
                                          With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
                                          Unfortunately the 5-blinks...
                                          06-28-2023, 11:52 AM
