Jmb jt012200
  • sordids999
    • May 2013
    • 2158
    • uk
    Jmb jt012200
    Hello guys
    got this tv tonight a 22 inch and 19 inch both totally dead power supply and main boards identical
    vestel boards
    17ips61-2
    17mb62-2.6
    anyone come across issues with these tvs
    thanks
  • finntricky
    • Jan 2014
    • 449
    • uk
    Re: Jmb jt012200
    check voltages, on power supply, if all ok, then you know it can only be eeprom, AGAIN,
    should have learnt your lesson with these tv's, lol
    • sordids999
      • May 2013
      • 2158
      • uk
      Re: Jmb jt012200
      ill check and was given both of these free so....
        Re: Jmb jt012200
        Shorted diodes are very common. Easy fix if so.
        • sordids999
          • May 2013
          • 2158
          • uk
          Re: Jmb jt012200
          Replaced diode tv all working again
          • sordids999
            • May 2013
            • 2158
            • uk
            Re: Jmb jt012200
            Just a reference for anyone else having issues with this tv power supply i have attached a image of the diode i changed
              Re: Jmb jt012200
              Just a note, with these VESTEL power boards, I would always replace the other diode in a set with a new diode from the same tape.
              (So when you buy three diodes for example, they come attached on the same "bandoleer" tape. This means they were roughly made at the same time and will be likely to have similar characteristics. The Vestel junk power boards fail because the diodes aren't well matched.)
              • sordids999
                • May 2013
                • 2158
                • uk
                Re: Jmb jt012200
                yep i already done that tom
                • simpt5
                  • Nov 2014
                  • 5
                  • england
                  Re: Jmb jt012200
                  Hi, sorry for the newbie question but I have a totally dead lcd tv with the same vestel 17ips61-2 power board.
                  I'm hoping mine has a faulty diode too?
                  Can anybody point me in the direction of where to buy replacement diodes?
                  Any help will be really appreciated thanks
                  • flocko
                    • Nov 2012
                    • 1121
                    • uk
                    Re: Jmb jt012200
                    Hi As you are in Liverpool OHM Supplies in netherton Flocko
                    • simpt5
                      • Nov 2014
                      • 5
                      • england
                      Re: Jmb jt012200
                      Thanks for the reply!
                      The numbers on the diodes look like SB5B0?
                      Does that mean anything to anyone?
                      • simpt5
                        • Nov 2014
                        • 5
                        • england
                        Re: Jmb jt012200
                        Woohoo I removed the three diodes from the board and there appears to be one that has shorted as it has continuity in both directions?
                        I re-fitted the two good diodes and breifly powered up the tv and it works!
                        My question is, will I be able to get some replacements from the likes of Maplin?
                        Can somebody please point me in the right direction of where to buy them and what part number to ask for?
                        Many thanks
                          Re: Jmb jt012200
                          These will do:
                          http://www.ebay.co.uk/itm/UF5408-Rec...item25789d54dd
                          They are upgrades compared to the original.
                          • simpt5
                            • Nov 2014
                            • 5
                            • england
                            Re: Jmb jt012200
                            Thank you very much for taking the time to reply Tom!
                            I, like many people have stumbled accross this forum whist googling why my tv is dead and what a great forum it is too, I have learnt so much!
                            Thanks again
                              Re: Jmb jt012200
                              To ensure reliability, make sure to replace all diodes in any given set at the same time with diodes from the same strip.
                              • simpt5
                                • Nov 2014
                                • 5
                                • england
                                Re: Jmb jt012200
                                I will do thanks, there seems to be three diodes in the set and according to the schematic diagram they are listed as sb5100 diodes?
                                Interestingly though, the diagram shows three diodes, but the are only two on my board with a vacant place for the third. If I order the uf5408 diodes you kindly linked me to, should I fit all three?
                                  Re: Jmb jt012200
                                  You can fit all three, it may improve the reliability slightly. It can't cause any harm. That diode will have been omitted to save money.
                                  • shagger11
                                    • Feb 2015
                                    • 3
                                    • wales
                                    Re: Jmb jt012200
                                    ive changed my 3 diodes and still no power light or standby or screen, however the dvd player does spin up, any ideas..?
                                      Re: Jmb jt012200
                                      Could be a main board fault. Checked all connections made properly?
                                      • petercam
                                        • Apr 2015
                                        • 1
                                        • Scotland
                                        Re: Jmb jt012200
                                        Hi, just found this site and this forum topic in relation to my Vestel PSU being dead in my TV. Thanks for the concise and clear info, I could be hanging round here lots more in the future.
                                        • Jaime Morillo
                                          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                          by Jaime Morillo
                                          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                          The TV was stuck on the logo and I couldn't access the update menu.
                                          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                          The image result was good, but the image is inverted.
                                          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                          08-18-2025, 11:38 AM
                                        • France_53
                                          Vestel tv, how to flip the image?
                                          by France_53
                                          Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
                                          05-12-2024, 05:22 AM
                                        • FlailingEngineer
                                          Help with Bush Tv (Vestel 17mb95m Mainboard)
                                          by FlailingEngineer
                                          Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
                                          Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
                                          05-31-2023, 06:52 AM
                                        • hazi12
                                          Vestel main board 17MB140TC
                                          by hazi12
                                          Hello, board 17MB140TC, I need to change the remote control in Vestel tool box 1.1. The original is there
                                          Rc48xx_2D and I want to install TOSHIBA-Rc481xx, but the program says that a maximum of 9 characters can be entered. I only entered Rc481xx and the program does not accept the driver I have in the original. Does anyone know how to do this? Other Vestel codes work.
                                          I can send a dump....
                                          Yesterday, 01:28 PM
                                        • massimomax
                                          Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
                                          by massimomax
                                          Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
                                          spero che qualcuno può averlo per riprogrammare eprom. grazie
                                          Post in English !!!
                                          I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
                                          02-28-2025, 07:27 AM
