Pan TC-50PU54 8 Blinks
  • Ltank
    • Jun 2013
    • 776
    SS board RF2001 and DG302 were both shorted causing P.S.
    to shut down. Shop Jimmy has a repair kit but it does not list the bad parts. I hate to assume that the kit has the parts needed. I could not find a data sheet for getting one capable of higher voltage and currents. Someone listed a 5R6 ohm sad resistor but not the footprint size. And a BD8694152 eight pin
    I but could not find it either.
  • tw2005
    • Oct 2011
    • 6458
    Re: Pan TC-50PU54 8 Blinks
    Pretty sure someone has sucessfully done a repair on these and posted. I believe the mounting screws are part of the issue with poor earthing. Is the resistor good or bad?
    That IC I suspect will be by ROHM, BD8694, C0ZBZ0001936. There's one listed on ebay but you can get those bits direct from Sears, Encompass, Partsimple,Best buy partstore, etc
    Would have to do a search , they may have only replaced that diode and IGBT?
    • tw2005
      • Oct 2011
      • 6458
      Still looking for you, for starters
      https://www.badcaps.net/forum/showth...npa5623&page=2
      with that RF2001, what marking is after that? T3D? The suffix does mean something, 3=300v, D=double diode
      • Ltank
        • Jun 2013
        • 776
        I looked for parts specs for 2 hours without much luck. The only good info was actually from this wonderfull websight! I broke down and ordered the Kit from Shop Jimmy. I hope it has the Dual Switching diode and transistor. It will take a few days to get it. Not long to install. I was hoping for spec sheets. being a common failure items I was hoping to find more durable diodes and transisors.
        What is C0ZBZ0001936 ?
        • tw2005
          • Oct 2011
          • 6458
          Post #58 followed the tech bulletin with sucess, no mention of replacing the driver IC.
          https://www.badcaps.net/forum/showth...=costco&page=3
          C0ZBZ0001936, is the panasonic part number to order if you wanted to go down that path.
          I think you should be safe with that kit, $20 , saves stuffing around.
          I don't think it's a component issue but more to do with the tech bulletin and arcing on the board not being tight and earthed.
          That resistor is M 5.6 OHM,J, 1/3W, So that would be metal film, 5%. Again if you had some scraps boards, fairly common on the IGBTs.
          the diode essentially will be 20A, 300V. if you have any dead SC or SS boards from 2010 good chance there's a RF2001, just needs to be 300V or more.
          https://cdn.badcaps-static.com/pdfs/...01f14d5d91.pdf
          http://www.ebay.com.au/dsc/Electrica...1&LH_PrefLoc=2
          The DG302 which can be smd or TO220 will be 330V 45A
          https://www.badcaps.net/forum/attach...3&d=1374137528
          http://www.ebay.com.au/dsc/Electrica...&_osacat=92074
          • martino
            Not so "senior"
            • Aug 2013
            • 997
            • canada
            I have repaired a few of these...The problem is loose screws to the chassis causing bad earthing....
            Now,I have a shop jimmy kit right in front of me here
            TXNSS1SDUU repair kit
            In the kit are:
            Q051=DG302
            IC501=BD8694
            D041=RF2001
            R051=5R6
            Bag with the 5 screws that have washers on them...
            So far every board i did,it was these 4 components....
            You can see at the places where the screws are,that it has been bad contact(arching)...I always sand thse areas of a bit for a clean contact....
            Hope this helps
            Proud owner of dozens of broken TV's and many,many,many boards.
            Our website and passion:http://hollenhundshepherds.com/
            • martino
              Not so "senior"
              • Aug 2013
              • 997
              • canada
              It's not the diodes and transistors fault,it's the screws and with the screws in the kit,it won't happen again...(check the other boards to for loose screws)
              • tw2005
                • Oct 2011
                • 6458
                In the kit are:
                Q051=DG302
                IC501=BD8694
                D041=RF2001
                R051=5R6
                Hope this helps
                So have you actually found that driver IC bad or just replacing because it's in the kit?
                Any chance you can post a picture of the kit contents for future reference including any documentation supplied?
                • martino
                  Not so "senior"
                  • Aug 2013
                  • 997
                  • canada
                  First one I did,I tried to skip the IC(being lazy) and it told me really fast that YES,I needed to replace the IC as well...
                  The once I did after I just replaced all 4 parts blindly....(A been there,done that thing I guess)
                  I will take a picture of it tomorrow,not much to it,4 parts,each in their own little bag labeled as where they go and a single piece of paper showing what each part is...
                  • tw2005
                    • Oct 2011
                    • 6458
                    yeah, why not if you got the parts. So I guess everything you replaced shorted again with the bad IC?
                    i was curious to see how much detail SJ gave like photos or instructions.
                    I guess the less info given the less liability, onus is on the repairer to know what they're doing.
                    • martino
                      Not so "senior"
                      • Aug 2013
                      • 997
                      • canada
                      It didn't blow the parts but I could hear instantly it wasn't happy. ( had switch on my power bar ready to kill power)
                      There is no info on how to do it. They just labeled the components like they are on the pcb
                      It's pretty straight forward.
                      • martino
                        Not so "senior"
                        • Aug 2013
                        • 997
                        • canada
                        pics as promised...I seem to have lost the piece of paper that was in it,but like I said,no info or "how to" on it....
                        Pic#3 shows the bad connection you need to clean up before installing new screws,I sand them off a bit myself...
                        • Bilbo44uk
                          • Jun 2014
                          • 11
                          Hi everyone, I am new here but also am working on a Panasonic Plasma with exactly the same issues, is there anyway to test the small IC, on the one I have the Mosfet is shorted gate drain and source, the diode is still ok, but the small resistor of 5.6 ohms is toasted too, looks like the screw issue again how silly is this fault, parts are very hard to find and very expensive here in the UK, I am thinking to import them from China from Ali Express, I am already tied in on the quote ive given for the repair so I can't start wasting money, well guys these threads have been very useful indeed, but parts are very hard to find in the UK for these sets. Tim
                          • Biruslapio
                            Panasonic P58V11B 8 and 12 blinks error "fix"
                            by Biruslapio
                            Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                            Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                            04-13-2021, 07:13 AM
                          • Andre Gilbert
                            by Andre Gilbert
                            Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                            Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                            11-20-2024, 08:52 PM
                          • Taurus12
                            Optiplex 3050 micro 2 blinks followed by 3 blinks issue
                            by Taurus12
                            Does anyone have an idea of what might be the issue with my 3050 micro? I have tried replacing new cmos battery but still the same
                            I am not sure if its the powersupply that I'm using is the issue since its the original powersupply. its a laptop powersupply with the same specifications with the 3050 micro so i guess it should be fine.
                            i also tried replacing the bios but with no avail, everytime i try another bios it gives a different blinking lights
                            Any recommendation on what I have to do next? Thanks in advance
                            06-10-2025, 05:05 PM
                          • jchon
                            Sony A1e 5-blinks help
                            by jchon
                            Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
                            I found the service manual, which was critical to know where to probe.
                            https://www.manualslib.com/manual/20...1e-Series.html
                            With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
                            Unfortunately the 5-blinks...
                            06-28-2023, 11:52 AM
                          • nobbnobb1
                            Panasonic TC-P50U50 Powers Off - 8 blinks
                            by nobbnobb1
                            I have a Panasonic TC-P50U50 plasma TV which powers on briefly, then powers off and flashes the power light with 8 blinks. This TV is infamous for this, of which the suggestion that the SS board has failed due to loose grounding screws and requires a replacement of the following components on the SS board:
                            2x DG302 (Q16051)
                            2x RF2001 (D16041)
                            2x 5.6 ohm SMD resistor
                            1x BD8694 IC
                            I have already gone ahead and replaced these components, as well as cleaning off the ground connections on the SS board as well as the associated...
                            03-21-2023, 08:33 PM
