Hello everyone, I have an Hitachi LE42H508 that I recently acquired that does not have a backlight. At first the TV would not turn on or go into standby. I went inside to perform some preliminary evaluation and checked the voltages on the high capacitor and found there to be the ~300V DC. Then pursued with the 12.4 volt marked on the PS and that was fine. While conducting the measurements I noticed Diode D107 ( was not shorted) was smoking and the cooling rail for the transistors was extremely hot to the touch, needlessly to say i turned off the set. Upon ohm measurement I found rectifier diode to be shorted D305. So i removed it from the circuit and powered on the TV and the TV went into standby mode and turned on and there was video( using a flash light I can see it). after pulling off D107 it seemed the smoke was from the heat coming off the diode and melting the coating on the board.
I ordered the diode D107 ( FR107) and D503(UF5408)....The D107 diode ws part of package of many different types. One type was the 1N5408, I decided to install both diodes and check the TV...at first I did not hook up the LED cabling to the board. I tested it and noticed nothign happening I measured the voltage and only seen a spike..So I hooked up the LED cable and turned on the set, the back lights came on then shut off then no TV...after measuring the ohms across the diode D503 it turned out it shorted again.
I went ahead removed it and replaced a new one but did not hook up the LED cable, turned the TV on and there was no standby LED on or the TV would have picture.. I then measured the voltage going to the LED and there would be a spike to 150V DC and then steadily drop to 0..
I removed the diode D503 and the video worked and standby LED was present..
Does this sound liek there is something on the primary side of the tranformer for the LED backlights? why would the primary get so hot and secondary short? I took the transformer out of curcuit and tested it for shorts, there were no shorts between primary and secondary windings.
Any input would be greatly appreciated..I checked out the board components as best as I can with my limited experience and found no diodes shorted or capacitors with issues, I did check with my ESR on the capacitors and found no issues, unless its happening under load. I have included photos of the PS.
