Panasonic power supply
  • ricosavy
    • Jul 2012
    • 457
    • united states
    I am looking for diode that is in a panasonic power supply. The diode has a number t3d 64.also the part number is st03-82.if one knows where i can get one or replacement for it.also i test it in diode mode in meter no readings both ways.i am not sure if i can test it with out running current through it.
    Re: Panasonic power supply
    What is the part # of the power board and what model is it frrom? Often you can get schematics for Panasonic boards, we might be able to suggest a replacement.
    • ricosavy
      • Jul 2012
      • 457
      • united states
      The model is th-58px60u and board is etxmm611meh
      • ricosavy
        • Jul 2012
        • 457
        • united states
        Drawing of diode i am made can it be tested in diode mode with multimeter.
        • tw2005
          • Oct 2011
          • 6458
          datasheet, I don't think it will, I see this one posted from time to time. catches people out from time to time, probably not at fault.
          what's the full story of the TV/PSU?
          tom will know
          • tw2005
            • Oct 2011
            • 6458
            I have a ST03D-140 in a 2010 PSU and in cct I just get constant continuity beep both ways. In my cct it sits across a primary winding so hence my reading.
            • ricosavy
              • Jul 2012
              • 457
              • united states
              I know not shorted was not sure if it was open but as big as that diode is i am thinking it might be ok. I did not know if i could read it like regular did. The problem with power supply is i am missing 15v that comes out of mc301.which gives me 10 blink code going to replace tea1610t and caps near it with .1uf 50v see if it will work. Some mentioned that diode possible being bad that is why i was testing it.
              • Agent24
                I see dead caps
                • Oct 2007
                • 5035
                • New Zealand
                I found here: http://www.eevblog.com/forum/chat/whats-the-part-pls/ you can't test this type like a normal diode. But if it reads open circuit both ways (as yours does) it's probably OK.
                You could test the zener function of it though and make sure it's breaking down at the right voltage.
                -David VanHorn
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                  by sam_sam_sam
                  03-31-2024, 02:12 PM
                  by sam_sam_sam
                  07-01-2024, 06:34 AM
                  Panasonic switching power supply daughter board has two 27uf @ 50 volt capacitors which I do not keep in stock
                  by sam_sam_sam
                  I did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
                  This is one of the shit est boards I seen in a very long time and it was the daughter board the traces just lifting off the board I had to use the capacitor leads to repair the the traces and the main board is not any better because I had to repair several traces for the daughter board to the main board
                  After all of...
                  07-13-2024, 08:14 PM
                  Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                  by sam_sam_sam
                  I was working on this CNC machine today found no keyboard functioning no control relay powering on
                  The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                  Found shorted diodes on main controller relays there are 3 of them that...
                  01-07-2023, 05:43 PM
