HP x20LED - bright horizontal lines
  • lti
    • May 2011
    • 2553
    This monitor has a bunch of horizontal lines that are brighter than they are supposed to be. The lines fade from left to right, so the right side of the screen looks normal. The lines appear over the OSD and when there is no video signal, so there is nothing wrong with the computer. The lines are always in the same place while the monitor is powered on, but there is a very small chance that some of the lines will disappear or new lines will appear when it is turned off for a while and turned back on. Since these pictures were taken, the brightest line you can see has disappeared and been replaced by several more bright (almost white) lines.
    These lines have been there since the monitor was a few weeks old, and it has been like this for months.
    I haven't seen this kind of failure before. Can this be repaired?
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: HP x20LED - bright horizontal lines
    If it was faulty from new why didnt you take it back? Is it still in warranty?
    • lti
      • May 2011
      • 2553
      I don't remember there being any real warranty, but I could check. All I remember was a 30-day guarantee from Walmart. It worked when it was new, but it lasted about as long as every electronic device I've seen that came from Walmart.
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        Could be a faulty panel, try with the brightness down a notch and check the resolution. You could also try cleaning the connector that goes to the panel
        from the main board.
        • lti
          • May 2011
          • 2553
          The brightness is already turned all the way down, and this appears at all resolutions.
          I'll have to open it and look inside.
          • lti
            • May 2011
            • 2553
            It looks like it has a bad panel. I don't think it's worth repairing. I cleaned both ends of the LVDS cable and looked for bad solder joints or tab bonds. I didn't see anything wrong that I could repair.
            Strangely, the cable to the button board has thicker wire than the LVDS cable or the power cable for the LED driver.
            The panel is an LG LM200WD3 (TL)(C9).
            I can post pictures of the inside if anyone wants to see them.
            • lti
              • May 2011
              • 2553
              Here are the pictures I took last year. They might help someone.
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                Yeah, I think that is a panel issue. Nothing you can do about. Cheap LCD monitors are cheap.
                • Kikerumbo
                  Mi Curved Gaming Monitor 34" - Horizontal lines
                  by Kikerumbo
                  Thanks in advance for any help you can provide.
                  I have a Mi Curved Gaming Monitor 34". A few weeks ago it started to show (or not showing) horizontal lines. Of course, it's outside of the warranty period.
                  After some hours of reading and watching videos I disassembled the monitor and checked the ribbons that go from the TCON board to the panel PCB. If I disconnect the ribbon for the right side of the panel, the other half shows a perfect image. I ordered a "new" TCON, installed it and the issue persists so that tells me it must...
                  03-14-2024, 02:48 PM
                • howardc64
                  by howardc64
                  07-24-2025, 05:17 PM
                  by momaka
                  03-15-2023, 10:17 PM
                • NConstantinou
                  Hp z23n monitor shows horizontal lines
                  by NConstantinou
                  HI ALL
                  i have the above board 715G7282-P01-001-0H3S WHICH SHOWS horizontal lines.
                  on power board i noticed 3 capacitors that changed color.
                  these 3 capacitors are connected to the positive side of main capacitor.
                  i have no schematic and i do not know the values.
                  those are c921,922,923.
                  c921 is removed.
                  how can i substitute.
                  thanks...
                  03-08-2023, 07:19 AM
                • Ihandyrepair
                  Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                  by Ihandyrepair
                  Hi guys
                  I just started fixing 4k TV few months ago. so I am still learning a lot
                  I got this tv from friend complaint is ghosting or horizontal lines on image.
                  never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                  then it started to show the ghosting white image.
                  I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                  it has 3 thin small boards at the bottom of the...
                  12-05-2022, 04:18 PM
