Samsung PS51D6900 will not switch on
  • Fredcoco
    • Dec 2013
    • 11
    • Uk
    I have a PS 51D6900 that will not switch on, watching TIVO on it when tivo went bang, tv went off, all lights on on tivo and burning smell from it.
    After that TV will not switch on, click when mains applied, green led in back flashing on/off once per second. Ir received light on front flickers when remote signal applied.
    Had a look in back, main fuse ok, nothing obvious.
    Any clues or ideas much appreciated.
    Thanks to all,
    Steve
    Re: Samsung PS51D6900 will not switch on
    Can you post a picture of the boards in the chassis?
    If you left the Samsung melody on (it's an option in the menu which may have been turned off) do you still hear this when turning the TV on?
    • Fredcoco
      • Dec 2013
      • 11
      • Uk
      Unfortunately, I didn't have the melody enabled.
      I have a feeling that a power surge/spike may have been the cause, weather was pretty foul when this occurred.
      Will take some photos tomorrow.
      Steve
        If it's a power surge the most likely candidates will be a main board or power board fault. I'm banking on main board. Faults can enter through the HDMI cable, if your TiVo (Virgin?) is damaged, it could have allowed the transient to reach the TV too.
        • Fredcoco
          • Dec 2013
          • 11
          • Uk
          Hi Tom,
          Please see attached photos of boards.
          Thanks and regards,
          steve
          • Fredcoco
            • Dec 2013
            • 11
            • Uk
            I'll try again using Firefox...
            • Fredcoco
              • Dec 2013
              • 11
              • Uk
              I have taken a more detailed look at the power and main boards and found the attached damage to main board.
              Steve
                As I expected. The damage entered through the HDMI port.
                Can you confirm if there is a light on this board and if it is flashing:
                https://www.badcaps.net/forum/attach...6&d=1388574388
                if so, does it flash about once a second, or about once every 5~7 seconds?
                And, in a dark room, that is nearly pitch black, can you see any glow emitted from the display (though a Series 6 2011 Samsung may be quite dark...!)
                • Fredcoco
                  • Dec 2013
                  • 11
                  • Uk
                  This is HDMI 1, which is the port that was connected to the TIVO box.
                  Regards,
                  Steve
                  • Fredcoco
                    • Dec 2013
                    • 11
                    • Uk
                    Yes, there is a light flashing on this board at about once per second, and there is a faint glow coming from the panel.
                    Regards,
                    Steve
                    • selldoor
                      Slow Learner
                      • Dec 2010
                      • 7870
                      Can you clean it up a bit and see what is left are the components paralleled on a HDMI 2
                        If those components are bad, I suspect that the main processor is completely fried; they're intended to protect that port and they've been completely destroyed in the process. The fix would therefore involve replacing the main board as the damage is probably too substantial to repair. I suspect the main video processor will have been in the very least badly damaged.
                        However, since the panel has a faint glow, it looks like the only fault is the main board.
                        So, test patterns can be activated:
                        https://www.badcaps.net/forum/showpo...61&postcount=2
                        The test pattern jumper is CN2010 on the board with the flashing light. The LVDS cable is the orange one with TOP PANEL printed on it.
                        If these are good all you need to do is replace the main board:
                        http://www.ebay.co.uk/sch/i.html?_sa...04402Q&_sop=15 or
                        http://www.lcd-plasma-parts.co.uk/in...oduct_id=13447 or
                        http://shop.nescom.co.uk/Samsung-MAI...02Q-BN4101605A
                        (last one looks too cheap: confirm with seller first!)
                        • Fredcoco
                          • Dec 2013
                          • 11
                          • Uk
                          Tom thanks very much for your help here
                          Steve
                          • Fredcoco
                            • Dec 2013
                            • 11
                            • Uk
                            Carried out test, pattern is ok.
                            That's a relief, I will order up a main board.
                            Thanks again for your help Tom.
                            Steve
                              Glad to hear -- main board should sort it.
                              • Fredcoco
                                • Dec 2013
                                • 11
                                • Uk
                                Just to let everyone know, the tv is fixed now, main board was goosed.
                                Got a new one from Emos, very helpful.
                                Tom, thanks for the help and guidance received, much appreciated.
                                Now to get some contribution to it from Virgin...
                                Best that I don't hold my breath.
                                Cheers again
                                  Glad to hear, but why should Virgin pay for your TV? The power surge damage isn't their fault, even the best designed box could fail in such a way. Surge protectors don't help as much as you'd think. Insurance/warranty/self repair is only way.
                                  • Mozigs
                                    • Mar 2015
                                    • 1
                                    • Sudan
                                    Hi tom66
                                    i hv the same TV PS51D6900 and i tried turnin on but when i connect power source the red light in the front of the TV flashes 6 times and nothing happens.
                                    there is no glow coming from the screen and no flashing green light from logic panel.
                                    plz help
                                    thnx a bunch
                                    • SluggerB
                                      Tivo HD will not transfer files ....
                                      by SluggerB
                                      Not sure where to post this, thought this might be the best place
                                      Tivo setup:
                                      Tivo 1 - Tivo HD, Monthly service (ancient, over 10 years old)
                                      Tivo 2 - Tivo HD, Monthly service (ancient, over 10 years old)
                                      Tivo 3 - Tivo HD XL, eBay Tivo with Lifetime service (newer but still old)
                                      Yes I am the idiot that paid monthly for all these years. I found a broken Tivo HD XL with lifetime service on eBay for $40 (Tivo 3), I bought it, it was a bad power supply, I re-capped it, good as new. So the plan was to cancel Tivo 1 and use Tivo 3 in it's stead. So I...
                                      07-02-2022, 08:09 AM
                                      09-06-2024, 11:40 PM
                                      09-06-2024, 08:40 PM
                                      Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                                      This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-06-2024, 06:20 PM
