Panasonic TC-P55GT30 7 blinks - ebay SC repair?
  • rfedeleo
    • Nov 2013
    • 11
    I've been reading through this thread:
    Helpful Stuff!!!
    And am thankful to Tom and tw2005 for all their documentation and skills!
    So my question is has anyone used, or has an opinion on using an ebay repair service to fix my SC board instead of buying one? Found one that would do it for 80 bucks with shipping or should I just buy from Panasonic for 180 (ouch).
    I am a little hesitant on buying a used one on ebay because I don't know the history of the card I would be getting, they also seem to be hard to find.
    This is one repair service I found:
    http://cgi.ebay.com/ws/eBayISAPI.dll...m=171178848646
    and here's another:
    http://www.ebay.com/itm/REPAIR-SERVI...item3387e82302
  • rfedeleo
    • Nov 2013
    • 11
    Re: Panasonic TC-P55GT30 7 blinks - ebay SC repair?
    One of the ebay sellers mentioned that if I had a short on the SC2 connection then the board was bad. Can anyone verify this? I set my MM to continuity test and I touched it to both prongs on the SC2 connection (the board is out of the TV now) and sure enough heard the beep.
    Thanks.
      Hold the probes across SC2 for at least 10 seconds. If the reading doesn't change, or you still get a beep, it's dead.
      • rmalbers
        • Oct 2013
        • 10
        • usa
        See if these guys have the board you need, they are a 'real' component level repair business: ModusLink PTS, Inc.
        I got my sc board from them and it's working fine so far, (fingers crossed).
        • rfedeleo
          • Nov 2013
          • 11
          Thanks for the replies. I will also check out ModusLink
          • apazzolini
            • Nov 2013
            • 7
            Everything I've done seems to indicate I also have an SC failure (7 blinks, had distorted picture as seen in the luminescence error on slide 99 of the 2011 guide, confirmed no shorts on the 1080 SC/SU connectors.)
            I can confirm that my board also measures continuity on the two SC2 prongs, which this thread indicates is an SC failure.
            Unfortunately... nobody seems to have these SC boards in stock, and from the other thread, https://www.badcaps.net/forum/showthread.php?t=25029, it seems like they won't be back in until January, which is a shitty situation.
            I bought http://www.ebay.com/itm/Panasonic-TC.../171178848646? for $80, will ship it to them tomorrow. Hopefully their turnaround is decent and this is in fact the broken board for me. Will report back.
            • rfedeleo
              • Nov 2013
              • 11
              Hey Appazolini, yes please let us know how it goes. I was contemplating using that ebay seller because they were also very responsive to my e-mail questions and he had good feedback as well as the best price.
              Though I am also leaning towards ModusLink because they have gotten a lot of good feedback from this forum. (Just do a search for ModusLink to see what people had to say). This whole experience sucks in general as I only bought my Plasma back in July 2011.
              • apazzolini
                • Nov 2013
                • 7
                Yeah, sucks for me too, I bought in March 2012. Probably the last Panasonic TV I buy.
                • electronicsurplus
                  • Jun 2012
                  • 210
                  You should also try checking the SU and SD (Buffers) for shorts.
                  To test:
                  Using a Multi Meter, set to Diode Mode, Place the + (Red) lead on one of the pads where the buffer screws onto the SC Board and, using the - (Black lead) run the lead over the connector, where the screen ribbon connects to the Buffer, in a zipper like fashion to determine whether there are any shorted IC's, then , you will need to check the mosfets on the SU and AD to make sure there are no shorts. If there are any shorts, you must replace either the corresponding IC or the buffer. BEFORE, ever even trying to replace the SC Board or, you will short the NEW SC Board.
                  Ebay has a kit, which contains the replacement Mosfets to repair the SC Board, if you have the ability to solder surface mounted components(It is not actually very difficult)
                  This should save you a couple of Hundred $$$
                  Hopefully this helps you
                  This Forum absolutely the best and, the most helpful forum I have ever found anywhere. thanks to all the fantastic members here
                  Help keep these from the landfills
                  • rfedeleo
                    • Nov 2013
                    • 11
                    @electronicsurplus, thanks for the tip on testing the buffer boards, I believe Tom mentions this as well and even has a youtube video. Although I wasn't aware to test the Mosfet on the SU and SD. What does it look like or where is located?
                      There aren't any MOSFETs on SU/SD boards on any modern Panasonic plasmas... only older Samsung/LG AFAIK.
                      • Gatedmk4
                        • Nov 2013
                        • 24
                        • New Zealand
                        Agree with Tom here, I am currently in the process of fixing my 7 blinks aswell (panasonic plasma 3d 2011 model). The replacement parts for the fixes on ebay are great however I found none that actually had the right amount of parts. most of the packages come with 3 30F131 and 3 RJP30H2A (Or similar) parts and at the moment I am replacing 12+. These components are IGBT's not FET's although they do have a FET arrangement internally.
                        Best thing to is any and all diagnostics you can get your hands on prior to ordering parts so you save on shipping etc. obviously some diagnostics are not possible without first fixing a board but from what I have found the PCB's are laid out quite well so you can use jumpers etc to diagnose.
                        Also fairly hard to point you the in the right direction of them but they are a rather large surface mount component with 3 legs the center leg is chopped and doesn't connect anywhere. these components should not have a low Ohms reading across any of the pins (including the back of the component which is a pin in itself) Also if you can read the writing on them they will either say 30F131 or RJP30HXX (I have found some peoples have 2E mine say 2A in replacement to the XX)
                        Cheers,
                        • rfedeleo
                          • Nov 2013
                          • 11
                          I put the order in to have my SC board repaired by ModusLink PTS. I will ship it out tommorrow and will report back in a week with my findings. I tested for shorts on the SU and SD boards by placing the red MM connection on the ground and doing the "zipper" test at the ribbon connections with the black probe and no beeps. As Tom mentioned above I don't think there are MOSFETS on my SU and SD and looking at pics of what MOSFETS generally look like I didn't see any.
                          I will post back in a week or so when I get the repaired board back incase anyone is following I'm hoping to get this done before Christmas.
                          • Gatedmk4
                            • Nov 2013
                            • 24
                            • New Zealand
                            Hi RF,
                            Before you send the SC board I would suggest checking the components marked in red (Not only for the SC board but the top right hand board as well) otherwise they will fix the SC only to find the other board has the same fault. The 2 pins and the rear heat sink(collector) pin should not be shorted or low ohms - Mine were 80 ohms
                            • rfedeleo
                              • Nov 2013
                              • 11
                              Hi Gatedmk4,
                              I will be sure to check those out as well. Will report back.
                              • apazzolini
                                • Nov 2013
                                • 7
                                Gated, that image isn't showing up very well for me. Could you please re-upload? Would like to test before plugging in the fixed SC board when it arrives.
                                I've done the "zipper" test and received no beeps, so I'm hopeful SD/SU are ok, but I can't quite make out what you're suggesting.
                                Thanks!
                                • Gatedmk4
                                  • Nov 2013
                                  • 24
                                  • New Zealand
                                  Hi Apazzolini,
                                  I grabbed that picture off another forum however its identical to mine/rfedeleo's model - The picture is of the SC board obviously however the same components are used on the SS board(top right looking from behind). I dont have the TV at work with me otherwise I would take some pictures of my findings.
                                  • apazzolini
                                    • Nov 2013
                                    • 7
                                    I guess what I'm saying is that image is a tiny thumbnail for me - I can't click to expand it to the full size. Was hoping you had the full size version of the pic as well.
                                    • rfedeleo
                                      • Nov 2013
                                      • 11
                                      Apazzolini, did you get your SC board back from the ebay repair service?
                                      • apazzolini
                                        • Nov 2013
                                        • 7
                                        No, but it should be arriving on Friday. I'll probably get to it this weekend sometime
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                          11-20-2024, 08:52 PM
                                        • Biruslapio
                                          Panasonic P58V11B 8 and 12 blinks error "fix"
                                          by Biruslapio
                                          Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                          Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                          04-13-2021, 07:13 AM
                                        • jm1234
                                          Panasonic plasma TX-P42ST50 - 6 blinks
                                          by jm1234
                                          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                          I checked that board for any obvious faults...
                                          05-22-2024, 06:59 AM
                                        • Alicat
                                          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                          by Alicat
                                          Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                          Model number is TH-50PZ85U
                                          Power comes on and the red power light stays on solid.
                                          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                          I also hear a few clicks.
                                          I also think my parents said there was a thunderstorm and the TV failed after that.
                                          Section 6 in the service manual talks about power and no screen,...
                                          10-30-2024, 10:09 AM
                                        • nobbnobb1
                                          Panasonic TC-P50U50 Powers Off - 8 blinks
                                          by nobbnobb1
                                          I have a Panasonic TC-P50U50 plasma TV which powers on briefly, then powers off and flashes the power light with 8 blinks. This TV is infamous for this, of which the suggestion that the SS board has failed due to loose grounding screws and requires a replacement of the following components on the SS board:
                                          2x DG302 (Q16051)
                                          2x RF2001 (D16041)
                                          2x 5.6 ohm SMD resistor
                                          1x BD8694 IC
                                          I have already gone ahead and replaced these components, as well as cleaning off the ground connections on the SS board as well as the associated...
                                          03-21-2023, 08:33 PM
