Acer Aspire 6920G reboots on AC Adapter
  • lagouzas
    Nemesis3
    • Oct 2013
    • 28
    • Greece
    Hello everybody,
    This is my first thread in this forum, I hope I'll be lucky.
    I 've run into this problem for 4th or 5th time with no success.
    Laptop model is Acer Aspire 6920G and although it works fine on battery, when ac adapter is plugged in it, randomly crashes and reboots.
    Battery is checked to be ok, different power adapters have been used, the power jack checked to be ok, different CPUs have been used, but no solution.
    I am definately sure that it's a common motherboard failure for this model. Some claim that it's a faulty Sata controller, others that there are 2-3 bad caps near the CPU socket.
    The standard fact is that when laptop takes more current than it takes when on battery, it crashes down and reboots. No matter what OS is installed from Linux, to windows XP or Windows 7, it's not a driver problem, but a hardware problem. Any idea wourld be appreciated.
    Seing is Believing
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: Acer Aspire 6920G reboots on AC Adapter
    Sounds like it's loosing power when loaded enough for it to turn off.
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • lti
      • May 2011
      • 2555
      I don't know why a bad SATA controller would allow it to run normally on battery. This seems similar to the problem caused by bad caps in Toshiba laptops.
      • lagouzas
        Nemesis3
        • Oct 2013
        • 28
        • Greece
        After some research, I think that you are right lti. This model has the same cap for regulating power consumption, as Toshiba A300 has, with the same problem. I have ordered it, and I am about to change it next week. Hope it will do my job.
        Seing is Believing
        • c_hegge
          • Sep 2009
          • 5219
          Moved to Troubleshooting Laptops and Notebooks. This kind of thread isn't for the FAQ.
          • rievax_60
            • May 2012
            • 897
            • australia
            Replacing it with the same type of capacitor usually results in near term failure.
            This thread, https://www.badcaps.net/forum/showthread.php?t=8991
            has lots of useful experiences from other members.
            • dj_ricoh
              • 2073
              • uk
              Disable the second core of the CPU in device manager when you run on battery then you connect the charger.
              It won't reboot.
              • dycc
                Vision
                • Nov 2011
                • 625
                • Côte d'Ivoire
                same issue as toshiba L300 . replace NEC TOKIN cap by four tantalum cap (330microfarad)
                • Francisco.s
                  • 686
                  • Spain
                  You can add a 1500 uF 6,3v in parallel (a good quality one (low esr)) and check its behaviour.
                  • lagouzas
                    Nemesis3
                    • Oct 2013
                    • 28
                    • Greece
                    Thank you everybody for your help.
                    Replacing NEC TOKIN cap, with a new one of the same kind fixed problem for me.
                    Seing is Believing
                    • rievax_60
                      • May 2012
                      • 897
                      • australia
                      How did you stick the new one on without melting it?
                      • whaldsz
                        • Apr 2013
                        • 395
                        • Philippines
                        he probably used a bga rework machine.
                        • ghojariya abdul
                          • Jul 2014
                          • 39
                          • india
                          its tokin capasiitor prob. put 4 330uf capasitor .
                            ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                            This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                            09-12-2024, 03:28 PM
                            ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                            This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                            09-12-2024, 02:30 PM
                            ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                            This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                            09-06-2024, 05:27 AM
                            ACER Aspire Aspire G7200 Predator Defender Aspire 9750 Specification for Upgrade or Repair
                            This specification for the ACER Aspire Aspire G7200 Predator Defender can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire G7200 Predator Defender boardview and Aspire Aspire G7200 Predator Defender schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
