HP Office Jet 4500 dose not alway want to print
    • Jul 2011
    • 6040
    Here is the story
    It start about 3 month ago some time you would have to wait a while when you want to print something this would happen off and on
    Then some time you could not find the printer it was not ready to print
    I would have to reload the software for the printer to work again
    The other day the power button would not turn the printer ON I had to unplug
    the power supply for the printer work again
    My wife is taking class on line and uses an I-pad and want to be able to print from it so we bought a new printer so she could do this
    I need a print at work and they will not buy one for me so I said let see what went wrong with this one
    I took the power supply apart and there was no name cap in there I have not
    seen before
    Power supply
    120 uf @ 400 volts did not replace
    330 uf @ 50 volts ESR value a little high 1.5 or so
    47 uf @ 50 volts ESR value a little high 2.3 or so
    Printer
    So I took a look inside the printer and I find 5 more caps
    So I took the printer apart and found Tepo brand cap and some more no name cap in there I have not seen before
    330 uf @ 50 volts a little high 1.4 or so
    330 uf @ 25 volt a little high 1.6 or so
    330 uf @ 25 volts a little high 1.3 or so
    1000 uf @ 10 volts a little high 1.4 or so
    10 uf @ 50 volts a little high 2.4 or so
    Put the printer back together and the power supply and power it up and went to print boy what a difference changing these caps made now this back to the way it was new
    I have two more printer that worse than this that I will recap as well now knowing this is what is causing this problem
  • LDSisHere
    • May 2012
    • 727
    • U.S.A.
    Re: HP Office Jet 4500 dose not alway want to print
    Good save on the printer. It is a nice change of pace for me when I can repair something with only a recap so I enjoy it when it happens.
    • mockingbird
      • Dec 2008
      • 5484
      That's why I only touch Brother and Canon printers and stay far far away from HP... Canon has been going downhill lately though...
        • Jul 2011
        • 6040
        I have Canon printer as well I had this for a while and it has the same problem
        Having to wait a while to print
        Printer not listed reload software
        • mockingbird
          • Dec 2008
          • 5484
          You'll not find substandard caps in most Canon printers... Only the very latest ones probably use cheap caps.
