Extremely simple class A headphone amplifier
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    One of my classes last spring semester was on transistors, and a big part of that class also covered basic amplifiers. I already took one such class in the previous university I attended, but they never really taught us much about the practical aspects of real-world amplifiers. So I got a little excited one day after class and decided to build my own discrete headphone amplifier. Turned out much easier than I expected and worked surprisingly well too.
    Attached below is a schematic of the amplifier I built, just as it was on the breadboard with all of the weird resistor values and configurations. It consists of simple, straight-up book example class A stages cascaded together. 3 transistors per channel, 6 transistors total for stereo. Simplicity at its finest! I'm sure most of you who have even the slightest of knowledge on discrete amplifiers will probably find my design laughable
    schematic
    Still, it goes to show how little you need to know to make one. And all of this was built from spare / junk parts I had around or collected over the years. As you can see, there are no special transistors used. Just plain old 2222 NPNs for the amplifying stage and a TIP42 PNP in a TO-220 case for the output. I probably could have built this even simpler by using only 2 transistors per channel. But I wanted to keep the gain on the amplifying transistors low for lower distortion. Not sure if that mattered or not, but regardless.
    So how does it sound? Pretty good . I would dare say even much better than many of those popular cheap-n-dirty amplifier ICs. There was virtually no hissing or humming at all. Quite surprising IMO, because I had the gain set fairly high at about 18.7 dB. Moreover, I was using a 9V switching power adapter. You'd think that would introduce some noise… but it didn't. And with this gain, it was more than enough that I didn't need to put the volume in Windows higher than the first bar (both Wave and Main Volume controls).
    And now with the more technical side of things…
    Frequency Response:
    @ 1 KHz
    @ 26 Hz
    @ 212 KHz
    I took the amp with me in one of the labs where I had access to a scope so I could perform some tests. As you can see from the attached scope pictures, the frequency response isn't too shabby – 26 Hz to just a little over 200 KHz at full volume right before clipping point, with a 33 Ohm resistor as the output load. While the high-end response is quite good, the shape of the low-end of the frequency response was kind of ugly. Unfortunately, halfway through the tests I noticed that I forgot to change my output coupling caps from some earlier testing. So instead of 1000 uF as I originally planned (and as the pictures show), I had 470 uF caps. CapXons at that too . But I didn't have any other caps with me on hand, so I just left the test results alone. The low-frequency output would probably have looked better if I used 1000 uF caps. When I was listening to some music with lots of low-end bass, however, I was not able to tell a difference.
    Gain:
    I used the scope to determine that and compared it to my calculated values. Turns out, they weren't too far from each other, with my calculated gain of 18.7 dB (8.6 V/V) being the minimum gain for the amplifier at the above frequency response. At 1 to 10 kHz, the gain was closer to 21.7 dB (12.3 V/V).
    Output:
    The highest output I could get with that 9V SMPS adapter was about 3 Vp-p (peak to peak). This, with a 240-250 mVp-p input from the signal generator. Translating this into RMS values: approximately 1.06 V RMS output with about 0.08662 V RMS input.
    Power:
    With the above output, that means I was getting about 34.1 mW RMS into that 33 Ohm resistor. It's not a whole lot, but still plenty IMO. My headphones (cheap classic Sony MDR-023) are rated for 24 Ohms and input sensitivity of 100 dB per mW. That means I can technically push them up to 46.9 mW with this amplifier, or about 117 dB. More than enough for me.
    Efficiency:
    Not good. Not good…
    I don't exactly remember what current it was drawing from that 9V power adapter, but I remember it was in the ballpark of 100-and-something mA and the calculated power between 1.1 to 1.4 Watts total (so about 550 to 700 mW per channel). With those numbers, that's roughly 5 to 6% efficiency with the 33 Ohm resistor and should be 7 to 9% efficiency with my headphones.
    Yeah, it's pretty low . But again, this is a class A amplifier, so this is more or less normal. I remember reading a while back somewhere that around 10% is generally to be expected. Could get it up to 50% if using impedance-matching transformer… but then there goes the simplicity!
    Unfortunately, I needed my breadboard for a project in another class, so I had to take the amplifier apart. All fine though, because since then, I've built another class A amplifier – this time bigger, slightly improved, and meant to drive actual speakers. It still has similar gain and all but the output stage is slightly different (originally, I wanted to do class AB, but I still can't figure out how to do that properly without distortion).
    Anyways, when I get around to it, I'll draw and post a schematic of this “new” design. It's nothing to brag about either (only capable of about 600 mW into 4 to 8 Ohms), but still quite fun to build and have around nonetheless.
    Re: Extremely simple class A headphone amplifier
    This is a good website on Class A amp.
    https://www.passdiy.com/project/amplifiers
      master hoarder
      • May 2008
      • 12175
      • Bulgaria
      Good info ^
      Believe it or not, I did actually look up quite a few designs on headphone amps before attempting this. The DoZ headphone amplifier seemed pretty good and not very hard to build.
      But I wanted to build something myself I also understand and the amp above was literally made on the spot. No planning, no schematics... nothing. Just a calculator in one hand and a pair of tweezers in the other to handle components on the breadboard. First made one class-A stage and set the bias point to a proper level, then another one, then the final output stage. Finally, I plugged my headphones in and prayed everything worked. Power on... everything ok... so then all I had to do was replicate the circuit to make it a stereo amp. And that's it. The calculations for the gain were made after the amp was completed .
      • dicky96
        What 'class' is this Hill Audio DX3000 Amplifier?
        by dicky96
        Hi guys, this is general query really
        So I have a Hill DX3000 3KW audio amplifier here.
        It has a topology/design like a class A/B but all the banks of output transistors (10 transistors in each 'side' of the channel) are NPN.
        I was wondering what class this is. It doesn't fit the description of class A.
        It also doesn't match class A/B or B amplifiers as all the examples I see have a complimentary output stage desigs (NPN/PNP) and clearly is not G, H or D
        I looked for 'class A push pull' but that didn't tell me anything either
        05-04-2022, 04:20 AM
      • madan1
        DALI SUB E-12F class D, fluctuating power rail
        by madan1
        Good day everyone.
        I have on the bench an amp board from DALI SUB E-12F. It is class D amp with a smps on the same board.
        The issue is that it powers off way before the rated power is reached (the protection circuit kicks in). It has an independent standby power supply, which stays on after the main power supply is turned off via a relay on the primary side (thus there is no reason to believe that the protection is triggered from the smps IC on the primary side).
        The normal value of the positive and negative power rails is +/- 43V.
        The positive rail stays...
        10-15-2025, 10:33 AM
      • MrCommunistGen
        Polk Audio RTi100 Plate Amplifier won't power on and intermittently honks and buzzes
        by MrCommunistGen
        My childhood best friend was killed about 9 years ago. His parents are finally letting go of his things, and they offered me his Polk RTi100 tower speakers. The Polk RTi100 towers are one of a handful of designs from the early 2000s that is a full range 3-way tower with a built-in self-powered subwoofer. This is accomplished with a plate amp integrated into the speaker input panel.
        I think they used them for a while, but they've been sitting for at least a few years now. After about 40 hours of driving to their house and back (both they and I have moved in the last 9 years) I got...
        07-12-2021, 05:11 PM
      • UserXP
        Mackie CR4 amplifier no sound
        by UserXP
        Hi, people.
        I've got an amplifier assembly from Mackie CR4 parts. It's just an amplifier, there was no speaker housing, so I used my set of CR4s to test it.
        Anyway, upon connecting everything and hooking the "new" amplifier to an audio source, the sound played clearly and strongly for the first ten seconds. I was happy it was working. Then the sound started to fade out during the playback until it was no more. After it had "dropped to zero", there were two very short intervals of sound playing at the normal volume, as if the amplifier was trying to...
        10-17-2020, 05:06 PM
      • Coert van Dorsten
        Sansui Integrated Amplifier replacement volume control troubles
        by Coert van Dorsten
        Hi all you clever electronmic gooroos!
        I was wondering if you could help me with the below issues Im having on a Sansui Integrated amplifier. I bought this unit as a project to repair as Im playing around with basic electromics.The unit has a faulty volume control pot. The service maual refers to a 150K Logarithmic pot (A) tapered stereo. Im struggling to find this value. Seem to be a jump from 100K to 250K. Im now trying a 250K pot. It works but the problem is that as the volume is turned up from starting at Min the Left channel will come on first just slightly before the Right...
        10-15-2025, 02:54 PM
