ViewSonic VP211b
  • Behemot
    • 4845
    • CZ
    ViewSonic VP211b
    It seems mostly there were problems with inverter and/or caps. But my model has japanese caps all over the PSU and inverter. It seems to be working when I disconnect +5 V supply to TCon, I got +5 V on main board and even got backlight in such case.
    When supply is conneted to TCon, I do not get anything, the problem propagates all the way to PSU which probably goes to safe mode. I did not find anything bad, no fuse is bad, all diodes and transistors on TCon are good.
    BTW I got electrocuted two times, the primary heatsinks is alive. I don't know how that is possible, the switching transistor is in TO-220F and the heatsinks is grounded!
    ADD// found some small caps having suspiciously high ESR, one 1 uF/50 V has ESR of 85+ ohm, capacity 0,85 uF, not even ancient tiny Daewoo cap has so incredibly high ESR. Also when powering the TCon with just +5 V from old AT PSU, it did not get shorted so maybe there is some problem on some DC-DC module on the main board because of wore-out caps?
    ADD2// changed the 1uF cap, now PSU works even with TCon supplied but still black screen. However, there is more small caps which seem screwed in similar way.
  • kca
    by kca
    Hello all ~
    08-31-2025, 06:38 AM
  • x_orange90_x
    TCL 50S535 bad tcon or panel issue?
    by x_orange90_x
    Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
    03-29-2025, 11:02 PM
  • advant
    by advant
    02-03-2020, 12:25 AM
  • Hakuu
    by Hakuu
    Hi There,
    More Details
    TV Model - LG OLED77G1PUA
    07-12-2023, 02:37 PM
  • netgearnetgear
    TCL 43S423 TCON OR PANEL FAULTY???
    by netgearnetgear
    Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
    08-20-2025, 06:04 PM
