sony kdl46s4100, 66 volts at bl on with tv off
  • nomoresonys
    • 12192
    • U.S.
    have 66 volts off and 176 volts on, for bl on, thanks for any ideas.
    Re: sony kdl46s4100, 66 volts at bl on with tv off
    BL_ON is 66 volts off and 176 volts on. Are you sure? Meter's battery is good? What do you use for Ground ref? Any pictures? What is it not doing?
    Training manual:
    • nomoresonys
      • 12192
      • U.S.
      tested more, bl-dim starts about 18 v and keeps going up. bl on goes wild from.465 to 186 volts, that is with av board disconected and with power off,
      • nomoresonys
        • 12192
        • U.S.
        Training manual:
        battery is good get proper readings from other connectors, but looks like at least those 2 on cn303 are not right, thanks.
          There is nothing on the main board that can generate that much voltage.
          • nomoresonys
            • 12192
            • U.S.
            I don't have a digital camera for pics.
              That much voltage would have blown out just about all the ICs on the boards. You are not missing the decimal point on the meter?
              • nomoresonys
                • 12192
                • U.S.
                ok, I thought it seemed way too high, funny this meter reads the other pins correctly.
                  Try reading 1.5V and 9V battery. what you are reporting are impossible.
                  • nomoresonys
                    • 12192
                    • U.S.
                    this meter is measuring mvs and sometimes v, I have it on dc auto.
                    • nomoresonys
                      • 12192
                      • U.S.
                      battery is 1.6v
                        So it is varying when measure the battery too? So it is 66mV = .066V. Better get better meter. When meter battery runs low, the readout will show higher reading than it should be. Can't you put it in 20V range instead of auto range?
                        • nomoresonys
                          • 12192
                          • U.S.
                          no its gdt-3200 auto range only, no manual settings.
                            Well, we need to get correct reading first. right now those readings are way off base.
                            • nomoresonys
                              • 12192
                              • U.S.
                              i'll try plugging up the av board to see if it reads better.
                                You should download that training manual. By the way, I still do not know what the TV is not doing.
                                • nomoresonys
                                  • 12192
                                  • U.S.
                                  ok, will do, this meter is a little strange, some it reads in volts the others in mv, plugged in the av board, with power off, sgnd =0, BL DIM=155MV, BL ON=73MV, DET=2.3MV, power on sgnd=18.7mv, bldim=3.31v, blon=182mv, det=3.27v.
                                  • nomoresonys
                                    • 12192
                                    • U.S.
                                    tv is not turning all the way on, it gets steady green light, no picture or sound, if unplug cn303 backlights come on with the multi line then solid screen test pattern loop, I think this is protection mode but not sure, thanks for help.
                                    • nomoresonys
                                      • 12192
                                      • U.S.
                                      followed testing in manual for 301, says replace av board, this board is the third one shop jimmy sent me, and they swore up and down they were all good, I don't know what to think.
                                      • nomoresonys
                                        • 12192
                                        • U.S.
                                        but I did see where other folks were having the same problem and a good av board fixed it.
                                        • Carlos#2003%
                                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                          by Carlos#2003%
                                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                          02-15-2024, 07:52 PM
                                        • Superbee_dad
                                          Sharp 80” long short flash backlight error - Help
                                          by Superbee_dad
                                          Hello Sharp TV experts
                                          Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                          > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                          > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                          01-24-2025, 11:51 PM
                                        • dkneyle
                                          Sony KDL-46HX850 Can't upgrade/update firmware
                                          by dkneyle
                                          Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                          Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                          09-25-2024, 10:44 PM
                                          Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                          This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 05:27 AM
                                          Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                                          This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                                          09-06-2024, 05:30 AM
